need help with graphic card AMD Radeon R5 M330
kingkrick
2 (0.00/day)
hello everyone
i have this problem on my laptop ,i already installed the amd radeon setting and did the switchable graphics,but it seems i can't get the games working on my dedicated graphic card even if i set up the profils for performance
when i went and installed the gpu z to check what is the probleme its gave me this
http://gpuz.techpowerup.com/18/05/20/z59.png
http://gpuz.techpowerup.com/18/05/20/3wz.png
the graphic card dosn,'t show in my dxdiag,but it shows in dysplay adapter as it working,i m using windows 7
i don't know if there is a problem but all my games are using my intel chip
http://gpuz.techpowerup.com/18/05/20/8uk.png
any ideas how to remedy this
thanks a lot
The GPU-z screenshot shows it idle when taken, was that during gaming?
Download and run Unigine Heaven, that will show frame rates and GPU used during it's run to confirm which is being used.
hello everyone
thanks a lot
What model of laptop are you using?
hello good sir
hp notebook
product number: P1E29EA#BH4
i checked starcraft 2 it says in graphic that is using intel chipest
will download unigine heaven and will do some tests
thanks a lot
