Need help with Lian Li Controller Cable
chris2203
2 (0.20/day)
I need help finding a replacement cable for my Lian Li fan controller.
I cannot find how this cable is called.
Hope someone can help me.
INSTG8R
Vanguard Beta Tester
8,087 (1.10/day)
Canuck in Norway
Case TT Kandalf L.C.S.
Mouse G502 Hero
Keyboard G19s
VR HMD Oculus Quest 3
Software Win 11 Pro x64
Is this not something you could just order from Lian Li? I mean I would at least reach out to them and see.
13,380 (1.99/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
I agree with INSTG8R. It certainly is a proprietary cable designed by Lian Li. It many use industry standard connectors, but finding a pre-made cable on the 3rd party market with those specific connectors already attached in that specific (proprietary) configuration is highly unlikely.
Do you have the user guide for the controller? The name Lian Li uses for that cable, and maybe even a Lian Li part number, may be in the guide.
If you don't have the user guide/manual, you need to determine the exact model number of the controller, then (if lucky) you might be able to download the guide from Lian Li's website and get the Lian Li part number.
Good luck.
chris2203
2 (0.20/day)
Thank you both. I wrote Lian Li customer service a email. Hope they get back to me soon. I will share here what they say.
Thanks again
348 (0.22/day)
Texass
System Name EXTREME-FLIGHT SIM
Processor AMD RYZEN 7 9800X3D 4.7GHZ 8-core 120W
Motherboard ASUS ROG X670E Crosshair EXTREME BIOS V.2506
Cooling be quiet! Silent Loop 2 360MM, Light Wings 120 & 140MM
Memory G. SKILL Trident Z5 RGB 32MBx2 DDR5-6000 CL32/EXPOⅡ
Video Card(s) ASUS ROG Strix RTX4090 O24
Storage 2TB CRUCIAL T705 M.2, 4TB Seagate FireCuda 3.5"x7200rpm
Display(s) Samsung Odyssey Neo G9 57" 5120x1440 120Hz DP2.1 #2.Ulrhzar 8" Touchscreen(HUD)
Case be quiet! Dark Base Pro 900 Rev.2 Silver
Audio Device(s) ROG SupremeFX ALC4082, Creative SoundBlaster Katana V2
Power Supply be quiet! Dark Power Pro 12 1500W via APC Back-UPS 1500
Mouse LOGITECH Pro Superlight2 and POWERPLAY Mouse Pad
Keyboard CORSAIR K100 AIR
Software WINDOWS 11 x64 PRO 23H2, MSFS2020-2024 Aviator Edition, DCS
Benchmark Scores fast and stable AIDA64
13,380 (1.99/day)
Nebraska, USA
Mouse Logitech M190
Nice find, @Hankieroseman!
I note if you scroll down, it describes the cables too.
42,781 (6.69/day)
ir_cow
4,588 (0.77/day)
USA
Sadly I had the same problem. I could never find a replacement either for V1. I ended up ditching the included controller and used a ARGB hub and buying cables. Good news is V1 and V2 have the same pin layout so you can take V1 connectors on V2 by swapping shells.
348 (0.22/day)
Texass
Just got another Lian Li case so I've been on the site lately. I was checking out the "strimers" and my memory was working that day. I also just installed an SL and TL Controllers in my O11 PCMR Edition. Stole the SL controller and new fans from it for my new O11 EVO XL and then proceeded to breakoff the lousy right angled, single RGB Header on my HIGH DOLLAR EXTREME board. I swear those are the worst connectors on PC's.
