Need help with my brother's CPU
145 (0.03/day)
System Name Aurora MK III
Processor AMD Phenom II X4 925 Processor @ 2.8GHz
Motherboard MA785GMT-UD2H
Cooling Stock
Memory 2x2GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
Video Card(s) Radeon HD 5770
Storage 2 500 GB, 320 GB & 160 GB HDDs
Display(s) H19W Envision 19'' @ 60 Hz 5ms
Case Case from Microcenter with a multitude of vent holes and ROM slots.
Audio Device(s) Realtek HD Audio output
Power Supply OCZ StealthXStream OCZ700SXS 700W ATX12V
Software Windows 7 Ultimate
I really can't find any specific spot. My brother has 4 GB DDR2 Ram, a Pentium D, And a NVidia GeForce 9600 GT. I don't know the mobo. The issue is his computer lags with games he should have no lag with. L4D2...L4D1...Mass effect 1 (a bad port, sure....but it still shouldn't be that bad). He passes recommended of all of em, and tons of other games. We have no idea what could be causing it...IE Is the processor half dead like what happened to my celeron D? Is there some connection issue between the CPU n Mobo (FSB or w/e) or is it something else? If there's a program we could use to test, or something we could do, I would be very appreciated....My brother's PC REALLY shouldn't be lagging on Half Life 2 with medium/low settings with those specs -.-
2,894 (0.47/day)
South Carolina
System Name KILLER
Processor Intel Core i7 4790K
Motherboard MSI Z87 G45 Gaming
Cooling Water Cooling
Memory 2x8GB Gskill 2400mhz
Video Card(s) EVGA GTX 980
Storage SSD Samsung 500GB
Display(s) 24" Asus 144hz
Case Cooler Master HAF
Audio Device(s) X-Fi Platinum
Power Supply Antec 1200 Watt Modular
Software Windows 10 64 Bit
Benchmark Scores 3DMark Vantage 51342
What kind of FPS is he getting with that setup?
Has he updated his graphic and mobo drivers to the latest for his hardware?
Fourstaff
10,089 (1.80/day)
Home
Processor 3570K // 10400F
Cooling Stock // Stock
Maybe the harddisk is full of junk? too many applications running in the background? Plenty of plossibilities.
145 (0.03/day)
Cooling Stock
Nah. It lagged with 20% free, 40% free, even 60% free. Its a 300 GB HD. Yes he has the latest graphics card drivers. I actually didn't know mobo's got continuously updated drivers, and his response is 'Dunno...'....And we can't remember/dont remember what his mobo was ^^;. Any way we can check?
The fps was in the range of 5-15 or maybe 20 when standing still/walking inside Normandy on Mass effect. 20, MAYBE 30 FPS on L4D2....even worse on L4D1 until ive been on it n playing for bout 20-40 minutes...Occasionally, the game will freeze or drop REALLY low for a few seconds, or it'll just drop to id say 3-7 FPS or so if more than 10 zombies show up in some/most levels beyond Dead Center x.x
Checkin somethin now to see if it found what his mobo was...(xfire rig upload xD) it didn't work lol....
4,628 (0.74/day)
where everyone wants to be
System Name Everchanging
Processor AMD Ryzen 9 5900X
Motherboard ASUS ROG Crosshair Dark Hero
Cooling Arctic Cooling Liquid Freezer 2 420mm
Memory 2x16GB Corsair DDR4 3600 CL16
Video Card(s) eVGA RTX 3090 Ti FTW3
Storage Samsung 980 Pro 256GB, Samsung 980 Pro 2TB
Display(s) 2xSamsung 28" 4k HDR 144Hz
Case Fractal Meshify 2 XL
Audio Device(s) fiio K9 to Hifiman Sundara's via 4.4mm balanced cable
Power Supply Seasonic Prime TX 850w
Keyboard Corsair K70 RGB PRO
Software Windows 11 x64
download CPU-Z from cpuid.org and it will have a tab that should tell you the info for the mother board.
1,539 (0.27/day)
Canada/Québec/Montreal
System Name Main PC
Processor PII 925 x4 @3.724GHz (266x14) 1.525v NB 2660 1.425v
Motherboard Gigabyte AM3 GA-890XA-UD3 (790x+SB850)
Cooling Scythe Mugen 2 rev.B
Memory Hyperx 8GB (2x4) 1600@1418 8-7-7-20-27-1t
Video Card(s) GTX 680
Storage 256GB SSD / 2TB HDD
Display(s) LCD Samsung 24" 16:9
Case Cooler Master HAF 912
Audio Device(s) On-Board HD
Power Supply CM 750w GX |3.3v@25a|5v@25a|12v@60a
Software Kubuntu dual boot /Windows 7 Ultimate 64bit
Benchmark Scores later...
1-Pentium D as far as i know Pentium D were cpu's with high temps maybe yours is over heat?
2-Virus or spyware? (Ccleaner won't be a bad idea as well)
Install Avast & SuperAntispywares free & scan the drives if you don't already have one?
3-Your HD may be dying?
4-Drivers or softwares that causing this? (i doubt it)
5-when was the last time you did an defrag?
For how long that your bro got this computer?
145 (0.03/day)
Cooling Stock
1. I can check the temp later, but I don't think so.
2. We have Norton 360.
3. 2 years old. Possibly...He has a spare 300, but games seemed to run as slow, if not a lil slower on the secondary 300 gb one.
4. Dunno. Haven't looked much, but I do know the latest nvidia cards caused issues with bioshock n I suppose a few other games.
5. He says he defrags it every month.
1,539 (0.27/day)
System Name Main PC
Uninstall Norton crap & go get the free version of Avast & also superantispywares
Defrag once a month that's good , keep it up
Does your 9600 overheat?
install GPU-z to see if it does (you can monitor temps all the time during windows or games)
http://www.techpowerup.com/gpuz/
If your bro have this computer for a long time 1 year or more & been never cleanup?
Then there is a chance that it's full of dust bunny's & overheat?
You can buy an can of compress air & cleanup the inside case (even if not overheating it wont be a bad idea to clean it free of dust)
I usely clean my inside case once every 3 months (every seasons change) 4 times a year
145 (0.03/day)
Cooling Stock
We have a can of air, so I might try that.
I'll have him check the temperatures later.
He refuses to use free stuff, as to quote, "Unlike free stuff, Norton hasn't tried to eat my hard drive." He hasn't used Avast specifically, but out of all the bad experiences, he refuses.
1,539 (0.27/day)
System Name Main PC
The problem with Norton crap is that it takes to many resources (heavy on Ram ,etc...) it always works in the background & most of the time it will still miss a virus or two ...:rolleyes:
As for free anti-virus they are good enough to protect you the only thing is that some free version doesn't do auto updates or scan email or you got to manualy scan you HD from time to time (once a week) but other then that they'll take care of the virus in the same way as the paid version.
http://freebies.about.com/od/securityfreebies/tp/best-antivirus.htm
But one thing you & your bro should get is SuperAntiSpyware the best one out there i did some test with lots of other anti-spywares... & superantispyware caught all spywares that other miss & that was with the free version.;)
http://www.superantispyware.com/
145 (0.03/day)
Cooling Stock
Told you he won't use any free stuff.
Also,he has 4 gb of DDR2 ram...even with XP, that shouldn't be a drain on memory. And Norton wouldn't cause 5 year old games to lag as if I was trying to run them on a 2.4 ghz singlecore...
1,539 (0.27/day)
System Name Main PC
To bad for him he's missing on a lot here.. & the way you wrote it that sound rude..?
That can still happen even more with an single core , imagine Norton or other background services using 50% or more of the CPU (for what ever reason) then that doesn't let you much for the game...
Anyhow i believe more on heat issues then anything else but will see as soon as your bro will monitor temps
BTW:pentium D is for dual core , is it not?
I didn't know there were Pentium D single core...:confused:
145 (0.03/day)
Cooling Stock
K I've got CPU-z ready....anything specific I might need to list?
Also, Mobo Model is NF570_SLIT-A
145 (0.03/day)
Cooling Stock
Yeah, it is dualcore. I meant his CPU is that bad. To explain to you....My Celeron D 3.33 GHz Singlecore ran TF2 n just bout every game better than his Pentium D, and I don't care how bad of a dualcore it is....it shouldn't be outperformed by a singlecore on something like HL2....
EDIT: Ack, sorry for the double post. Meant to edit. And sorry if it sounded rude. Its just he won't use free stuff, same as me. We get our comps screwed up n require reformats more often than we have with Norton....
1,539 (0.27/day)
System Name Main PC
Got the last nforce driver from nvidia site?
you got a single core 3.33 ghz & your bro an dual at 2.4 ghz?
you're still faster even if he got an dual core he would need about 2.8/3.0 ghz to "equal" your cpu (although you dont really compare single vs dual core but..)
Cpu-z was to get all the infos cpu, board , ram ,etc...
What you need is GPU-z to monitor graphic card temps
As for your CPU & board you can use Asus Probe that would tell you temps of cpu & chipset also volatges you can d/l at Asus site or you may have it on your cd that came with your board
It's really a shame that you & your bro think that bad of free stuff i guess no Ccleaner or defragler for you guys...
145 (0.03/day)
Cooling Stock
No o.o.
He's a Pentium D 2.8 Ghz. I just said that. I said the 2.4 GHz single core would run better than his Pentium D right now....as an EXAMPLE. He has a 2.8 Pentium D dualcore.
And the Celeron D fried half way. So now I have the Pentium E6300, but im gettin a complete upgrade (hopefully to a quadcore) in feb.
Well, I opened up CPU-z I was just curious if it listed any info that might identify if it was a CPU, mobo, or connection issue between CPU & something else or w/e....
EDIT: Nope. I'll try that now. I honestly didn't know mobos had to be updated. Lets see if that works.
EDITEDIT: So Im guessing nForce 5 series, nForce 570 SLI AMD, download type = driver?
295 (0.05/day)
Las Islas Filipinas
System Name SynChron
Processor Intel Core i7 3820
Motherboard ASROCK X79 Extreme 9
Cooling CoolerMaster Hyper 212X with 2 Noctua NF-F12 fans in push/pull
Memory 4x2gb Corsair Vengeance LP 1600 CL9
Video Card(s) Asus GTX 770 DCu2
Storage Samsung 830 128gb SSD, 1TB Western Digital Velociraptor, Seagate Barracuda 320gb 7200rpm SATAIII
Display(s) HP x2301 LED
Case Corsair Obsidian 750d
Audio Device(s) Asus Xonar Essence STX
Power Supply Seasonic X - 660Watt Gold
Software Windows 7 Home Premium 64-bit
I think you should download CCleaner(Free) or TuneUp Utilities2010(Paid) to clean your system of unwanted/unneeded programs or registry keys. I use both of these to speed up aging pentium 4 rigs and they do work as far as I'm concerned!:D And I also use them to maintain the orderliness of my new system! Here are the links if you need them:
CCleaner: http://www.filehippo.com/download_ccleaner/
TuneUp Utilities 2010: http://www.tune-up.com/products/tuneup-utilities/
Hope this helps Bro!:toast:
145 (0.03/day)
Cooling Stock
Personally, I don't like CCleaner. Didn't work too well for me, and If I remember right, it was actually pointed out to be a virus not only by windows, but by Mcafee AND Norton...Whether or not it's true, my comp screwed up a few times, and Norton 360 can clean registries, I can scour the list for unneeded programs, and 360 can help with registry files as well.
1,745 (0.25/day)
The Nevada Wasteland
System Name 9th Level
Processor AMD Ryzen 5 5600X
Motherboard MSI X570 Carbon wifi
Cooling EK Basic 360, x2 250mm, x1 140mm, x1 120mm fans.
Memory 32GB Corsair Vengeance 3200mhz.
Video Card(s) EVGA RTX 3080 12GB FTW3
Storage 500gb ssd, 2tb ssd, 6tb HD.
Display(s) MSI 27" Curved 1440p@165hz
Case HAF 932
Power Supply Corsair HX850W
Software Windows 10 64bit
disable norton antivirus and then run the games. See if the FPS change, And use GPUz to see if the video card is overheating.....
145 (0.03/day)
Cooling Stock
So wait....you're facepalming because me and my brother have both used free programs and been burned? HEAVEN FORBID DIFFERENT PEOPLE WITH DIFFERENT PC'S HAVE DIFFERENT EXPERIENCES. I'm not here to ask if Norton is the cause, or what you think is the best anti virus. I'm asking what I can do to check what the cause is. I'll see if he's willing to try disabling it without internet on later. I'll check GPU temps later, and I've got CPU-z ready for whatever info, if any, is useful. I'm not here to argue on what's the best option.
1,539 (0.27/day)
System Name Main PC
You probably download the wrong files you shopuld try once more & get the good files this time
Ccleaner & superantispyware
What about those temps i ask for... comming soon?
You got Asus Probe & GPU-z already? (NOT CPU-z)
BTW:Your board use Intel cpu not AMD so d/l nforce 570 sli intel
145 (0.03/day)
Cooling Stock
Ah crap. Didn't even notice. Just installed the AMD one x.x. Installing Intel now....That wrong install won't cause issues, will it? >.>
I'll go for temps now.
1,539 (0.27/day)
System Name Main PC
Uninstall the nforce/amd driver first & then install the new one (better to restart after an uninstall)
EDIT:Reread your post about what type of mobo you got & i have no idea why i was thinking that was an Asus board?
Now star CPU-z once more & check in mainboard & see if you can find who makes that board ,asus , gigabyte, etc..?
Can't find the maker of that board with google on 570_slit-a...
295 (0.05/day)
Las Islas Filipinas
360 is a scam and kills computers.
I tend to agree with your point Bro that it kills computers! Seen it happen on several of my friends' laptops that came preinstalled with Norton 360. Was'nt sure at first with the cause of hang ups and lagging till I saw that Norton eats up a lot of CPU and Memory resources in the Task manager!:eek: What I did was uninstalled Norton and installed Kaspersky IS instead! Problem fixed for my friend and laptop runs faster! :) Im just not quite sure why Norton runs that way though! :confused:
145 (0.03/day)
Cooling Stock
The driver isn't listed in Add/remove programs...How would I go bout remove it?
