Need help with RX 480 8GB
Comixguy
4 (0.01/day)
Hello guys, im new here. I need help with 5 of my RX 480 8GB Asus strix cards. Ive been using them for mining, and they are still able to mine just fine.
Now, i would like to sell them, cause im done with mining. So i tried testing them, they are able to project picture in Win 10, howevver when i tried running Furmark to test them it shows an error. Also, in device manager there is a yellow triangle next to the card.
Why is that so? Could the bios have been changed for more efficient mining? I dunno, i bought this rig years ago.
Can you guys help me?
All screenshots are attached/
1,835 (1.56/day)
Romania
System Name Gaming1 / Office 2
Processor Intel i7 7700k@4.8ghz / Ryzen 7 5700G
Motherboard MSI 270 SLI PLUS / MSI MAG X570S - TOMAHAWK MAX WIFI
Cooling ID-Cooling Frostflow X 120 - Liquid / ID-Cooling SE-903 V2
Memory 2x16GB Corsair Vengeance LPX 3600 Black / 2x16GB Corsair Vengeance RGB Pro SL - 3600Mhz
Video Card(s) XFX RX 5700XT THICC III Ultra 8GB / XFX RX 6600XT 8GB
Storage 1st : 1x SSD Samsung 870 Evo 1Tb + 4x SAS HDD in RAID / 2nd : 1 Tb SSD Nvme Samsung 970 EVO PLUS
Display(s) 2x Dell 3008 WFP
Case CoolerMaster HAF 932 / GENESIS IRID 300
Audio Device(s) Soundblaster XFI / Onboard
Power Supply Thermaltake Smart RGB 700W / Thermaltake Smart RGB 700W
Mouse Logitech G502 HERO / Logitech G5
Keyboard Dell SmartCard Reader SK 3205 / Dell SmartCard Reader SK 3205
Software 1st - Win 10 Pro X64 / Win 7 X86 / Ubuntu / 2nd - Windows 11 Pro x64
Hello.
For sure "miners" have the BIOS modded.
Those BIOS-es were modded in such way to provide more compute compared to default BIOS.
Based on your card's ID and sub ID here you have the right BIOS:
Comixguy
4 (0.01/day)
Hello.
OK, so i have a noob question.
Are you saying that my bios is modded and i should flash a stock one, so that GPU works normally for gaming and easier selling?
Or are you showing me photos of bios that i currently have?
1,551 (0.26/day)
System Name Ryzen5900X
Processor AMD Ryzen 5900X
Motherboard Gigabyte B550 AORUS PRO AC
Cooling NZXT Kraken X62
Memory 4x G.Skill F4-3600C17D-8GTZ
Video Card(s) AMD Radeon RX 6800XT Midnight Black
@Comixguy
You bought a mining rig a couple of years ago. It has modified bios on those cards since it will be more efficient with mining.
Since the bios signature is fucked up due the modified bios, the drivers will not load normally. To fix that, you need to reflash the orginal bios which Imperator provided.
When the original bios is flashed, the cards might still work but can also be mined to dead.
For flashing please follow the instructions below:
For RX 500 Series (Polaris) and Older:
Get amdvbflash 2.93
Then look for Version 4.68, underneath 4.68 you will see a link to show older version, click that and you should see version 2.93
Follow these steps carefully:
1. Open your "C:" drive in Windows, create a new folder, call it atiflash.
2. Extract the contents of atiflash_293.zip to the "C:\atiflash" folder
3. Find the bios file you downloaded and rename the bios file to 5 digits with .rom on end Example RX 580, change file to rx580.rom (r****.rom)
4. Move r****.rom to the "C:\atiflash" folder
5. Open the start menu, type cmd, when cmd.exe appears right click it and hit "Run as administrator"
6. At the command prompt type in cd\ and press enter until only C:\> is on the screen.
7. Type in cd/atiflash and press enter, you should see C:\atiflash>
8. Type in amdvbflash.exe -i to identify the gpu you want to flash with a 0, 1, or 2)
9. At the C:\atiflash> prompt type in
amdvbflash.exe -unlockrom 0
(there is a space between the e and -unlockrom and 0)(0 is the number zero)
press enter and you will be prompted that the "ROM Unlocked" (or 1, 2)
10. At the C:\atiflash> prompt type in
amdvbflash.exe -f -p 0 r****.rom
(there is a space between the .exe and -f, and a space between -f and -p and 0).
(Or 1, 2)
Press Enter
Follow directions on screen and if flash is successful exit the command prompt and restart, windows should show up on screen
1,835 (1.56/day)
Romania
@Comixguy
Yeah...the right words..."it might" work.
All depends on the way the previous owner (it could be yourself) used them to "mine".
If you have luck, those card will function as it should.
1,835 (1.56/day)
Romania
You are most welcome.
We are happy that you did it!
1,835 (1.56/day)
Romania
Well, you came in the right place.
Trust me when i tell you that you find here the help you need.
Again we are happy to help.
Cheers
40,531 (6.52/day)
You better replace the thermal compound on the gpu core and thermal pads, and dust the fan and better mark them as ex mining cards so people can make an informed decision.
1,835 (1.56/day)
Romania
ha ha....long time no see.
Welcome back mate!
@eidairaman1
