Need new laptop.....going insane trying to decide.
2,873 (0.51/day)
Corpus Christi, Texas
System Name FumoffuFumoffu
Processor Intel i7 4770K
Motherboard Gigabyte Z87X -UD3H
Cooling Corsair H100i
Memory 16GB DDR3 1600 Crucial Ballistix
Video Card(s) Sapphire AMD Radeon HD 7970 OC
Storage 1- WD 500GB 1- Samsung F2 1.5TB 1- Crucial M4 128GB SSD 1-256GB ADATA XPG SX900 ASX900S3 SSD
Display(s) Hanns-G HZ281HPB 27.5'' 3ms Full HD 1920x1200 WideScreen LCD Monitor
Case Corsair Graphite Series 600T
Audio Device(s) Creative Soundblaster X-Fi Titanium
Power Supply Corsair HX 750W Gold
Software Windows 7 Pro x64
Hey guys,
So I have been using my current laptop since 2012. It is a Lenovo G570-4334.
I have repaired it so many times it is now held together with Super Glue and Epoxy. For example, the screen hinges broke. Initially I was able to fix it. Then that fix failed when the hinge mount on the chassis broke off. So I epoxied it to the chassis and it was good. Then the hinge mounts stripped so the screws dont stay.....I epoxied the screws and hinges together. Then the fan grill broke off and the frame near it cracked. Super-glue fixed that. I had been taking it apart and putting it back together so much nearly all the screw holes were stripped. Also it seemed that every time lately, 1 or 2 screws would go missing even when putting them all in a magnetic container. The thermal paste is Noctua NH-1. I upgraded the RAM to 8GB Crucial DDR3-1600 CAS-9. The chassis is not being opened any more outside of the doors on the underside for RAM and CPU. The chassis has been epoxied together with an extra sealant on the outside of super glue by Gorrilla Glue.
As you can probably tell, this laptop has been in service for a while and unfortunately has seen some dangerous times. It usually rides in my backpack at work and is pulled out to update service tickets in the field or to assist with Router and Switch maintenance. The specs are a Sandybridge Core i3 23xx something I think. 8GB Dual Channel DDR3 1600. 1x 120GB Kingston HyperX 3K SSD. It runs Linux as Windows sucks hard on this machine at this point. Yes I tried 10 on here and NO,,,,,Hell No.
So, I am here asking for assistance as I have been looking through my options and am going insane.
The requirements I have are simple but sound. No, this is not a gaming computer. I do not game on a laptop if I can help it. I would be fine if it could game at the same time but I primarily watch streaming video, read E-Books, maybe Blender Modeling but also use for work in the field.
I use Linux so keep in mind that I will most likely be wiping that virus of an OS (windows 10) off my machine.
  • It needs to be friendly to Linux aka works OOTB with all hardware BT/Wifi etc
  • Must be charged over USB-C/Thunderbolt - I am sick and tired of replacing the barrel port or replacing barrel dongle power bricks. USB C is supposed to have a longer life and stronger port.
  • Should be 15.6" or smaller. At the smallest of 13". 13 or 14" is preferred but 15.6" is acceptable.
  • Touchscreen is optional (not preferred) but if it is touchscreen, it needs to be able to fold over like a tablet so Im not poking at a screen like an idiot but instead using it like a tablet before I flip it back over and use the laptop like normal.
  • I Prefer a Matte screen so I dont have to deal with glare from the sun at work.
  • 1080p or higher -- at Most 1440p.
  • NO NVIDIA graphics - Nvidia's drivers on Linux Suck hard. And when they dont, they are a beotch to install and break as soon as you update the kernel.
  • If dedicated graphics are in it, they must be Intel or AMD (preferably of the Vega series aka Intel's Vega M iGPU series or a Ryzen 7 series or RX Polaris chip like the 580.)
  • Intel or AMD - If AMD - Ryzen 2700U/2500U with Vega 10/Vega 8. If Intel - UHD 620/HD620 or Vega M (ex: Intel Core i7-8809G)
  • Wireless AC
  • Bluetooth 4.1 or higher
  • at minimum 8GB of RAM. Preferably 16GB. Ability to upgrade RAM would be ideal.
  • SSD - m.2 nvme is preferable.
  • DVDRW - not necessary
  • Not heavy - this sucker is riding in my backpack with all my tools. I dont need any additional weight if I can help it.
  • Sturdy/Durable materials
  • able to take it and keep ticking.
  • Max price ~$1800.
  • Newegg. I use my Store card. I do not have an Amazon card at this time. So please keep it to Newegg. i have 12 months 0% APR on every purchase over $500. I have not had any issues with Newegg since I started using them in 2008.
***I would like to clarify this: I am not specifically looking for a 2-in-1 as I am less likely to use it as a tablet. I am also not specifically looking for a Kaby Lake-G. I am however specifically looking for USB-C Charging. I would like to be able to find one with a Ryzen chip like the 2700U. Or, an Intel 8th gen chip. Based on what I can find, Ryzen 2700U Vega10 is better than Kaby Lake-G Vega M. I am less likely to use touch screen than most people seem to think. I have never need to before and didnt really desire the option. The way I see it, if I want touch pad stuff, Ill get a WACOM writing pad. ***
If it has the ability to have a WWAN card added for mobile computing, that would be nice to have so I dont have to tether my phone. But again, not a requirement.
My laptop has been running into issues more and more as time goes on and I fear that it will break soon in a way that I can not solve at the office.
I am Lenovo, Dell, HP certified for computers. HP has been on my watch list but as long as HP stays away from joining the FWUpdate group for Linux firmware updates (Dell and Lenovo are part of that group) then HP unfortunately is not in the running. FWUpdate allows you to upgrade the firmware from the Linux OS automatically like you are installing software packages. No more downloading either an ISO or booting to a Windows USB or partition just to install a BIOS update or something like that.
I do like to Blender render from time to time. When I do game on this old laptop, I am playing games like Breach & Clear, Company of Heroes 1 & 2, and other top down RTS games like Warzone 2100. Not super demanding but they work. Hence my request of it being Vega graphics or at the least AMD RX Polaris series like a 580. Not simply because of gaming but also because I can use it for Blender Rendering. Can you imagine making the stuff I have with 5000 samples on a i3-Sandybridge chip? It takes HOURs to render.
newtekie1
Semi-Retired Folder
28,473 (4.06/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
Just looking at the connectors should tell you that is false... USB-C is way more fragile than a barrel connector. If you are breaking barrel connectors, you're definitely going to break USB-C and they are way more of a pain in the ass to fix.
2,873 (0.51/day)
Barrel connector power adapters are also expensive (i know because I have replaced mine 3 times). Whereas, I can charge a laptop over USB as long as my adapter is 60W.
847 (0.35/day)
Haswell, USA
System Name Bruh
Processor 10700K 5.3Ghz 1.35v| i7 7920HQ 3.6Ghz -180Mv |
Motherboard Z490 TUF Wifi | Apple QMS180 |
Cooling EVGA 360MM | Laptop HS |
Memory DDR4 32GB 3600Mhz CL16 | LPDDR3 16GB 2133Mhz CL20 |
Video Card(s) Asus ROG Strix 3080 (2100Mhz/18Ghz)|Radeon Pro 560 (1150Mhz/1655Mhz)|
Storage Many SSDs, ~24TB HDD/8TB SSD
Display(s) S2719DGF, HP Z27i, Z24n| 1800P 15.4" + ZR30W + iPad Pro 10.5 2017
Case NR600 | MBP 2017 15" Silver | MSI GE62VR | Elite 120 Advanced
Audio Device(s) Lol imagine caring about audio
Power Supply 850GQ | Apple 87W USB-C |
Mouse Whatever I have on hand + trackpads (Lanchead TE)
Keyboard HyperX Origins Alloy idk
Software W10 20H2|W10 1903 LTSC/MacOS 11
Benchmark Scores No.
Check out notebookreview forums, they seem to know whats up. Also check the GS65 from MSI, don't be stupid and get a Razer Blade
Edit: just reread your thing, "NO NVIDIA GPUS" good luck with that, might want to check out the GL702
Durvelle27
6,813 (1.48/day)
Memphis, TN
System Name Black Prometheus
Processor |
Cooling Thermalright PA120 SE |
Mouse Logitech Trackman
Keyboard Logitech K350
Software Windows 10 EDU x64
Yea but with the USB C chargers I’ve used they are flimsy as hell. If I were you I’d stick to original barrel chargers, you’ll definitely get more time out of those. I’ve broken 3 USB C chargers and had one port already become loose after a year of usage.
It will also make recommending you a laptop a lot more easier as well since not many options out there that use USB C with decent specs that don’t cost an arm and a leg.
2,873 (0.51/day)
Why are you recommending a gaming laptop? I'm NOT mobile gaming.
Well then the laptop needs at least a USB C ports.
Barrel chargers or the Lenovo charger.
Toothless
Tech, Games, and TPU!
9,732 (2.45/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x24 Klevv Cras V RGB
Power Supply Corsair HX850
Mouse Corsair Harpoon
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
Gaming is just a selling word. It most likely will be labled as gaming with your requirements on the GPU side.
2,873 (0.51/day)
I can understand that. But, I don't want to sacrifice battery too much. I need decently long life. Say 5+ hrs
Durvelle27
6,813 (1.48/day)
Memphis, TN
Processor |
11,880 (2.18/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
2,873 (0.51/day)
@Killer_Rubber_Ducky
You are literally asking WAY too much of a Linux based laptop.
And if you're breaking barrel jacks, you're being too hard on your laptops.
How is it asking too much of a Linux laptop? It is a laptop with windows preinstalled. Also, I used this in the field so it gets knocked around from time to time.so yes, the power port takes a beating.
2,873 (0.51/day)
I use laptops in the field also. Never broken one. All I'm saying with that is make a delivered effort to be more careful.
I am about as careful as I can be. I carry it in a padded backpack. Sometimes the cord gets pulled by other objects or people who h puts strain on the port. It's not like I'm throwing the laptop across the parking lot. Also, I feel the need to point out that I have had this laptop since 2012. It is now 2018. This is a 6 year old laptop.
17,503 (4.65/day)
Motherboard B650 Steel Legend
Cooling Frost Commander 140
Case NZXT H710 (Red/Black)
2,873 (0.51/day)
Again......I'm NOT gaming as my primary focus. It is the LAST thing I use a laptop for. Also, as Linus Torvalds has said.....Nvidia, FuckYou. Intel or AMD ONLY. I will take any Nvidia laptop and put it through the shredder we use for hard drives.
17,503 (4.65/day)
fk nvidia? bro, we are all fkers in this life. you use a phone and a computer and a tv right? guess where the minerals to build those electronic devices came from? pain and suffering beyond imagination from exploitative mining / warlords in those regions. we are all fkers. or maybe I just been reading to much Nietzsche lately.
2,873 (0.51/day)
How does this apply? I do not use Nvidia in my laptop. Simple
28,938 (6.84/day)
Fair enough. Wasn't trying to attack you. Barrel jacks are stronger that USB-C jacks, especially the larger diameter jacks used by Dell, HP and many OEM's.
2,873 (0.51/day)
Just saying my Lenovo jack thankfully is replaceable without solder.
17,503 (4.65/day)
2,873 (0.51/day)
It's not an illusion. I DO NOT tolerate Nvidia in my laptop. So drop it and please stop suggesting Nvidia chips.
9,659 (3.28/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
Honestly 1800$ would be an absolute waste on a laptop if it's not for gaming, actually you're not even going to find much in that price range if it's not for gaming and no Nvidia GPU.
Unless you have a thing for overpriced ultrabooks, in which case the options are plenty.
17,503 (4.65/day)
Microsoft Surface Pro 6 just went on preorder yesterday. just get that. tho i never had any issues with Ubuntu and my gtx 1070 laptop, meh. it all good g unit
2,873 (0.51/day)
I'm just listing the 1800$ price because most of the thin-n-lite laptops run about that for 8th grade Intel and usb-C. And 16gb of RAM. This laptop is expected to last another 5-6 years.
