Need replacement USB port
501 (0.14/day)
So the USB3 port on my laptop (yes, there's only one, it's an older Toshiba) broke. The Vss contact broke off and I don't see any way of MacGyvering something so it has to be replaced. It's many years old, but it still works fine for what I do with it. Used motherboards on ebay - even parts boards - go for far more than I'm interested in spending on it. I have tried to find a replacement port but nothing I've found is of the right design to fit the board. They're all either offset mounting (port ends up lower than the board), which won't work, or they are the right design and size but they have the 5 pins at the back. I found a Lotes catalog and found what I think is the correct part number (ABA-USB-124-P01), but get no results on search... Anyone have any suggestions?
354 (0.09/day)
Oztralia down under
System Name K9
Processor i9 9900K @ 5.1Ghz and 32deg C - delid + Grizzly Conductonaught LM
Motherboard Gigabyte Aorus Z390 Gaming X
Cooling Custom water cooling loop - GPU + mobo (+VRM's) + CPU
Memory G Skill - Trident Z RGB DDR4 - 3866Mhz x 32Gb @ 3800Mhz
Video Card(s) Gigabyte Aorus 11Gb GTX 1080 Ti Waterforce Extreme @ 2250Mhz
Storage Samsung 500Gb M2 970 EVO + Samsung 850 Pro SSD + ADATA 512Gb SSD + Samsung 1Tb & 3T + WD 1Tb + 3Tb
Display(s) ASUS 27" ROG Swift 1440p @ 165Hz & BenQ 27" LED
Case Thermaltake Core P7 - Open frame
Audio Device(s) Logitech Z906 - 5.1ch
Power Supply EVGA 1200W
Mouse Roccat LeadR + Razer Nagar V2 Pro
Keyboard Corsair K70 LUX with Cherry Red switches
Software Win 10 Pro 64bit
Benchmark Scores v/fast
hi taz420nj
A bit of a bummer - How's your soldering skills ??
I would grab my soldering iron (do u have one ??)
regards
501 (0.14/day)
hi taz420nj
regards
The pics are of the port I need... Detached the board... So yeah I can solder lol. The problem is I can't find a replacement part.
229 (0.09/day)
Australia
Processor Intel Core i7-13700KF
Motherboard GIGABYTE Z690 AORUS ELITE
Cooling Dark Rock Pro 4
Memory G.Skill Ripjaws DDR4-4000 32GB (4x8GB)
Video Card(s) ASUS TUF Gaming Radeon RX 7900 XT OC Edition 20GB GDDR6
Storage Various
Display(s) GIGABYTE M32U 4K 144hz
Audio Device(s) External Amp
Software KDE Neon
Get on ebay and search for "PCB Mount Right Angle 9-Pin USB3.0 Female Type A DIP Socket Connector".
501 (0.14/day)
That brings up the right size but they all have the 5 pins at the back. The one I need has 4 pins on the outside, 5 on the inside...
229 (0.09/day)
Australia
Storage Various
Software KDE Neon
501 (0.14/day)
Getting closer.
Click on "48392-0003 Datasheet", then on "Drawing (PDF)" or use this link: https://www.molex.com/pdm_docs/sd/483920003_sd.pdf
You could make it work if you're feeling creative ;)
That looks promising. I'll check measurements against the data sheet when I get home from work. Thanks!
Got a chuckle out of the fact that it's a real company name.. but that's a 13 pin. I think the one Candot linked is possibly the one I need, just have to check the measurements of the one I have. Thanks though!
9,771 (3.47/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
If there are electrical supply stores in your neighborhood that would be a good place to start. Otherwise Ebay or ALi Express may help you.
18,119 (2.45/day)
I'm wondering if people have problem reading the brand and model number on the part.
It's a Lotes 1123 connector and it has been discontinued.
501 (0.14/day)
Electrical supply stores? Really? Come on.
Thats literally the first thing I did. It turned up nothing except mexican real estate hits. The printed number is a date code, not a model number. And in the OP, I did say that I located it in the Lotes catalog, and there is no Google result for it.
229 (0.09/day)
Australia
Storage Various
Software KDE Neon
Very helpful. Good job. :rolleyes:
Ntwlf
3 (0.00/day)
If you have any USB Hubs laying around you could open them up and see if they have a matching port that can be robbed. If that happens to work remove it cleanly and the hub will still work fine with 1 less port than it had.
18,119 (2.45/day)
Well, it's a discontinued part, so yes, it's actually helpful, as it tells the OP that he/she isn't likely to find a like for like replacement easily. And knowing the manufacturer and model isn't helpful? :kookoo::wtf:
229 (0.09/day)
Australia
Storage Various
Software KDE Neon
We already knew this.
7,607 (1.46/day)
Rīga, Latvia
System Name HELLSTAR
Processor AMD RYZEN 9 5950X
Motherboard ASUS Strix X570-E
Case Lian Li O11 Dynamic EVO
Mouse Razer Basilisk
Software FEDORA 41
Actually it is normal for them to be so.
They are made once. Fill the hangar that is enough for years.
9,771 (3.47/day)
Cooling In Win SR36
Well I live in the Toronto Area in Canada and there are 3 electrical supply stores near to me that have this kind of equipment. There are also plenty of Chinese malls in the Toronto area that have shops that have these types of parts for sale.
