Need review on this psu
561 (0.24/day)
Canada
System Name HP Pavilion a6552f
Processor Intel Core 2 Quad Q9400
Motherboard Asus IPIBL-LB / HP Benicia-GL8E
Cooling DeepCool Gammaxx 200
Memory 8gigs Kingston 4x2gigs DDR2-800
Video Card(s) Zotac GT630 "Fermi" 2gb DDR3 128bits Synergy Edition
Storage Western Digital Green 7200rpm 1tb
Display(s) LG Flatron EW234 Super LED
Case HP Pavilion
Power Supply Thermaltake TR2 430w
Mouse Razer Abyssus Mirror Special Edition Blue LED
Keyboard Thermaltake Tt eSPORTS Commander Red LED Backlighting Mechanical Keycaps Membrane Gaming Keyboard
Software Windows 7 Home Premium 64bits
8,099 (1.34/day)
Hillsboro, OR
System Name Main/DC
Processor i7-3770K/i7-2600K
Audio Device(s) on board
561 (0.24/day)
Canada
Case HP Pavilion
13,566 (2.01/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
I don't believe that 550W in the Hardware Secrets review is from the same series of PSUs as the OP's 450W. I believe the 82+ in the model number suggests the efficiency, noting that 550W is 80 PLUS Bronze certified. Yet the OP's 450W does not appear to have any 80 PLUS certification at all. Not even basic/White. And it does not have 82+ in the model number.
Would you trust this one for budget build ?
Well, that depends on the power requirements of that budget build and on the criteria you are using for "trust". Honestly, Enermax is not a name that instills trust (at least for me) in the first place. So... ...I start out with a bit of bias against them here.
Budget does NOT imply the connected components will "sip" power. You can still put a power hungry CPU and graphics solution in a "budget build" and perform demanding tasks. So we would still need to know what the supply will be powering AND what tasks the computer will be running before determining whether or not I "trust" the supply has enough power to support those components.
Also,
Do I trust it will not blow up and destroy all my connected components? Yes.
Do I trust it will power my computer economically and efficiently? No.
Do I trust it will deliver good, clean, stable power? No.
Do I trust it will provide many years of reliable service (beyond the warranty period)? No. But this may be where my biases are influencing my judgement. I have seen budget supplies still chugging along after 8, 10 or more years of service.
1,118 (0.57/day)
System Name just ordinary potato system, but dont understimate potato..
Processor ryzen raven ridge 2200g, ryzen 2600 upgrade:)
Motherboard msi b350 pc mate, biostars a320, asrock ab350m micro
Cooling x2 cheap china handmade, i got plenty aigo/fantech rgb fans now heh
Memory klevv dual channel 8gb 3000mhz, trident 16gb 3600mhz, random ddr2 stick
Video Card(s) back to square, using vega 56 now:D
Storage wd green ssd 240gb, 3tb seagate expnasion, random laptop hdd x4, 1tb 3.5
Display(s) acer vgo 22inch fullhd 75hz
Case cheap segotep/dazumba mid atx, alcatroz mini atx
Audio Device(s) genius retro wood style, harman kardon stick iii
Power Supply be quite system power9, powerlogic standar, voltron 300fx, thermaltake smart 1200w
Mouse rexus, genius ps/2, powerlogic ps/2 ball tracking
Keyboard rexus, random china product x3
Software talking abt best software, autodesk/unity3d/notepad yes notepad!!
Benchmark Scores theres nothing to brag abt potato, but it can run decent 30fps fullhd with good setting:)
honestly i wont touch that brand, it also avaiable at here too, mostly bundling a pc case, but if you were running lowprofile setup its alr good enough to handle your pc:)
59 (0.03/day)
System Name MIXED
Motherboard ASUS TUF Gaming X570-Plus Wifi
Memory G.Skill Trident Z RGB DDR4 2x16 3600MHz
Video Card(s) RTX 4080 GameRock
Storage Gigabyte AORUS NVMe Gen4 1TB
Display(s) LG 27GL850-B 27" IPS 144Hz + LG 65" C3 OLED 120Hz
Audio Device(s) iFi Audio Zen DAC V2 + Hifiman Sundara
Power Supply Corsair RM750x
Keyboard X Box Elite2
It's Ok brand, I have Enermax PSU for 6 years already and I had no issues with it. It also powers my new build, which is great.
43,292 (6.74/day)
4,806 (0.96/day)
in a van down by the river
Cooling frostier than yours
Storage more ample than yours
Case fancier than yours
Benchmark Scores up yours
Hi. Would you trust this one for budget build ?
It's a CWT DSA platform using SAMXON caps, think thermaltake TR2 or old Corsair CX line. My two cents, for an office PC or gaming PC with a GPU that pulls all it's power from the mobo it's OK. The platform is solid for what it is and the parts are mediocre but obviously aimed for a specific price point. You can do worse (depending on your market) but you can certainly do better.
Why, when there are so many others out there that have reviews already? :)
That said, here is the 550W... https://www.hardwaresecrets.com/enermax-naxn-82-550-w-power-supply-review/
Old design.. is it that old, or 'new'?
Same platform but better parts to hit 80 bronze.
They used to make solid PSU (like actually build them themselves) and have brought some good units to market. Like CM or Thermaltake, they have a line of hit and misses that the user needs to research. It's a brand, at the end of the day all they really handle is marketing and warranty.
Their new MaxTytan line is flat out excellent (also made by CWT) and if we swapped labels with the Corsair HXi we would all be saying how excellent Enermax is.
1,192 (0.28/day)
Processor 11700
Motherboard TUF z590
Memory G.Skill 32gb 3600mhz
Video Card(s) ROG Vega 56
Case Deepcool
Power Supply RM 850
The review would be this, i would trust this psu to be in a pc that my grandparents use for internet surfing.
43,292 (6.74/day)
Fairly old design and 12v Power and amperage isn't high enough
4,806 (0.96/day)
43,292 (6.74/day)
