T
twilyth
I have a couple of old SCSI devices I'd like to hook up to my computer. These are SCSI 1 and connect via a 50-pin HD external connector or internal ribbon cable.
I can find plenty of PCI cards that can do this but none seem to be supported under W7-64bit.
I can go with an Adaptec 29320 but that will set me back at least $150.
I figure there has to be at least one manufacturer out there that has a low end SCSI 1 PCI card that is supported under W7, but I've had no luck trying to find it.
Any help would be appreciated.![Toast :toast: :toast:](https://tpucdn.com/forums/data/assets/smilies/toast-v1.gif)
