[Case Gallery] Nemesis Turbine Mod
S
Speed73!
Specs:
- Intel 2160
- Ecs G31T-M
- 4GB DDR2 800 Kingston
- 160 GB Hitachi Deskstar
- Mushkin 550W Modular
- Power Color Radeon HD4850 1GB
- Zalman VGA cooling GV1000
- Zalman MFC2 fan controller
- Matx Firefly as skeletal base
- bosch lights [Strobe lights]
- Sunbeam UV lights.
- Chrome custom design decals
Mods:
Installed 3 black acrylic Vents [left,right,top].
Made 2 80mm blowhole in front of chassis and installed 2 80mm Zalman Fans.
Coated whole chassis with carbon fibre vinyl.
Painted front panel with automotive paint [Anzhal].
Molded Front chassis case.
With only two front 80mm Zalman fans and modded it to a turbine, the airflow have displayed tremendous cooling in the system, regardless of overclocking the CPU to 3Ghz as well as the VGA card to 20%. Played several games like NFS Pro Street and COD4 War of the worlds in maximum specs, and it displayed manificently beautiful.
2,318 (0.40/day)
Texas
System Name Mr. Reliable
Processor Ryzen R9 5950x
Motherboard MSI Meg X570s Ace Max
Cooling D5 Pump, Singularity Top/Res, 2x360mm EK P rads, EK Magnitude/Alphacool Blocks
Memory 32Gb (4x8Gb) Corsair Dominator Platinum 3600Mhz @ 16/19/20/36 1.35v
Video Card(s) MSI 3080ti with Alphacool Block
Storage 2 x Corsair Force MP400 1TB Nvme; 2 x T-Force Cardea Z340; 2 x Mushkin Reactor 1TB
Display(s) Acer 32" Z321QU 2560x1440; LG 34GP83A-B 34" 3440x1440
Case Lian Li PC-011 Dynamic XL; Synology DS218j w/ 2 x 2TB WD Red
Audio Device(s) SteelSeries Arctis Pro+
Power Supply EVGA SuperNova 850G3
Mouse Razer Basilisk V2
Keyboard Das Keyboard 6; Razer Orbweaver Chroma
Really unique case design. 9/10 from me. Pretty sick case work. Love the turbines.
pro-infinity
110 (0.02/day)
Hull,Uk
turbines are what i love about this case. only think id really have done was make the vent holdings on the inside so it looked smoother so you would just see the vents without the edging around if you get me
S
Speed73!
Appreciate the suggestions! I tried the vent holdings on the inside before, but the heat was unsatisfactory. Creating the vents on the outside was inspired by a Raptor pilot I met in the medical mission in Philippines.
After learning how the planes' engine was cooled thru is vent [air intake], I decided to experiment. My main objective on this project was appropriate air ventillation with minimal fans.
ex-dohctor
112 (0.02/day)
South Africa
System Name Caspar.
Processor AMD Athlon 64Bit 4000+ (939).
Motherboard Saphire Pure Innovation PI-A9RX480.
Cooling Coolermaster Hyper 212 Cooler + 6 x 120mm CM Case fans.
Memory 2GB Kingmax - DDR 400.
Video Card(s) XFX ATI Radeon HD4650 512MB.
Storage 2X Seagate Baracuda 500GB SATA - II (32MB Cache).
Display(s) Samsung 19" LCD + Samsung 17" LCD.
Case Coolermaster Centurion 590 (Stock for now).
Audio Device(s) Onboard Audio.
Power Supply Gigabyte Superb 500W.
Software Windows XP Pro. SP3.
Awesome case!
