Never ending G502 Hero problems
4,213 (0.72/day)
Vietnam
System Name Gaming System / HTPC-Server
Processor i7 8700K (@4.8 Ghz All-Core) / R7 5900X
Motherboard Z370 Aorus Ultra Gaming / MSI B450 Mortar Max
Cooling CM ML360 / CM ML240L
Memory 16Gb Hynix @3200 MHz / 16Gb Hynix @3000Mhz
Video Card(s) Zotac 3080 / Colorful 1060
Storage 750G MX300 + 2x500G NVMe / 40Tb Reds + 1Tb WD Blue NVMe
Display(s) LG 27GN800-B 27'' 2K 144Hz / Sony TV
Case Xigmatek Aquarius Plus / Corsair Air 240
Audio Device(s) On Board Realtek
Power Supply Super Flower Leadex III Gold 750W / Andyson TX-700 Platinum
Mouse Logitech G502 Hero / K400+
Keyboard Wooting Two / K400+
Benchmark Scores Cinebench R15 = 1542 3D Mark Timespy = 9758
Hi all,
I'm just posting this to see if anyone else has the Logitech G502 and has experienced problems with it, or if I am just really really unlucky?
I bought one about a year ago, within 6 months, the left mouse button died. Got a warranty replacement that lasted 3 months before the left mouse button died again. I'm not on my second warranty replacement (so 3 brand new mice) and now the scroll wheel has begun squeaking which is annoying as hell.
To top it off, warranty support has gone downhill in my country and I have to rely on the retailer for warranty support.
I've always used Logitech mice for their software, support and build quality, but for my next mouse, I think I'll go with a different brand. What manufacturers build the best quality mice these days?
241 (0.15/day)
System Name Yin/Yang
Processor Ryzen 7 3700x
Motherboard msi mag x570 tomahawk
Cooling CoolerMaster ML240V2 / asiahorse fs9002 120mm fans
Memory 2 x 16gb g.skill trident z neo 3600
Video Card(s) msi gaming X 2070 super 8gb
Storage 1tb sabrent rocket nvme / 1tb samsung evo 860 sata ssd / 3tb Toshiba hdd
Display(s) lg ultragear 2560x1440 144hz 1ms 27"ips
Case nzxt h510i
Audio Device(s) logitech g635 / creative sound blaster
Power Supply evga supernova 750ga 80 plus gold
Mouse logitech g402 hyperion fury
Keyboard corsair k55
I've had two g502 heros and i really like that mouse. The right click was the first thing to go on both of them. The first one last damn near 2 years and the second lasted less than a year and they both endured relatively similar usage so not much consistency there. It's definitely a little bit on the heavy side. i don't like heavy mice but i don't like super light ones either.
A few moths ago after my second one broke i switched up to the g402 because it's cheaper and I wanted to give it a try. It's really average compared to the g502 in my opinion. The side buttons feel really chintzy and i cant adjust the weight like with the g502. Who knows though, maybe despite the feel it will hold up for longer. When my g402 sh1ts the bed I'm going to switch up brands as well, nothing against logitech i just like trying different stuff and i've been using logitech for long enough now
4,213 (0.72/day)
Vietnam
The one good thing about Logitech mice is that there are usually lots of guides that help fix them, though I have killed a couple this way as well. It's not too difficult to change out the brass/metal spring inside the buttons, with a little patience, and it's safer than soldering. I do like the style and feel of the G502 and when it's out of warranty, I'll likely fix it and use it on a second computer while looking for something else that's more durable.
241 (0.15/day)
Case nzxt h510i
Well kudos to you for even attempting to fix a mouse. I will be honest and say I'm usually too lazy and don't like going without so generally when a mouse breaks i instantly buy another one. I've been thinking about grabbing an ifixit kit though since i just built a new system and i still have my old g502 so that option is not off the table =)
edit*
what do you think of this one? Seems like it ought to be sufficient for pulling apart smaller devices like mice and controllers right? I have zero functioning controllers and like 6 old broken ones so it would be cool if i could put together a working one or two plus like i said i have one of my old g502s that would be a nice bonus as well. Either way this toolkit would be nice to have and it's a very reasonable price.
