New build compter only seams to work with RAM in DIMM-slot B1 and\or B2
23 (0.01/day)
I have a new build computer with the following hard ware…..
Motherboard: ASUS ROG STRIX X570-E GAMING
BIOS: Version 1408
CPU: Ryzen 9 3950X
RAM: G.Skill Trident F4-3200C14D-32GTZR
(Kingston KVR24E17S8/8)
GPU: 2XNvidia GTX1070
M.2 Samsung 970 EVO Plus
M.2 Samsung 860 EVO
The problem is that when have a memory stick in DIMM slot A1 or A2 and try to start the computer I end up with a black screen and the motherboard Q-code displays 0d which according to the manual stands for ”Reserver for future AMI SEC codes” and the Q-LED for DRAM lights up with a steady light.
I have reset the CMOS and tried with a different memory but I still get the same error.
If I put the memory sticks in DIMM slot B1 or B2 everything seams to work ok and I get to the BIOS screen and in this case the Q-code displays 0c which also is a code for ”Reserver for future AMI SEC codes”
So fare I can only run the computer with the RAM in a single channel configuration with the memory installed in the B DIMM-slots.
Any ideas on what might cause this problem?
As the RAM seams to work fine when put in slot B1 and B2 I guess they are ok.
Is it most likely a faulty motherboard or CPU that causing this?
17,164 (2.36/day)
Does both the modules work on their own?
If both modules work on their own, it's most likely a damaged/faulty board. You didn't perhaps slip with a screwdriver when you attached the cooler? This is unfortunately a somewhat common reason why there's a problem.
It's unlikely that you got a faulty CPU, but not impossible.
23 (0.01/day)
If I set the memory sticks according to the manual it does NOT work, it ONLY works with memory in slot B1 and\or B2
And YES both the modules work on their own.
EDIT Thank you TheLostSwede, I will try with a new board later.
17,164 (2.36/day)
Yes, that was obvious from your first post, but my question was, does each stick work on their own in slot B2 or B1? If so, it's not the RAM that's faulty.
Something is seemingly broken.
22,015 (6.01/day)
Mouse XTRFY M42
Dead RAM slots happen, been there done that and it means insta RMA that sucker (board)
Or better yet, return and get new one directly. This is DOA
23 (0.01/day)
Yes. Both memory sticks seams to work, when I put them in slot B1, B2 they show up in the BIOS screen.
Thank you Vayra86, I will get a new M-board when my wallet allows it. :)
22,015 (6.01/day)
Mouse XTRFY M42
What do you mean, can you not send it back? This is a money back or replacement case... has to have warranty.
23 (0.01/day)
I have modded the chipset cooling so sending it back is not an option I'm afraid. I think I will try to run it with the RAM in single channel configuration if that will work.
1,168 (0.21/day)
Austria, Europe
System Name Bang4Buck
Processor AMD Ryzen 9 5900x
Motherboard MSI PRESTIGE x570 CREATION
Cooling Fractal Design Celsius S36
Memory 32Gb 4400Mhz Patriot Viper Steel(Samsung B-die) @ 3800Mhz 16-16-16-32-48-1T @ 1.38v
Video Card(s) MSI RTX 3080 Ti Suprim X
Storage Adata SX8200Pro 512Gb/2x Crucial P1 1Tb/Samsung 840 EVO/6Tb Raid -HGST Enterprise/2x IronWolf 8Tb/
Display(s) Samsung UE49KS8002 4K HDR TV (US - 9 series)
Case Fractal Design Define R6 Black Usb-C
Audio Device(s) HDMI out to Denon X4400H reciever, 2x Dali Zensor 7, Dali Zensor Vokal, 2x Dali Zensor 1, Yamaha Sub
Power Supply Seasonic Prime Ultra 750W
Mouse Logitech G305 Lightspeed
Keyboard Logitech K520
Software Windows 11 Pro x64
Benchmark Scores https://www.3dmark.com/spy/26216445
Modded in what way? Have some pictures maybe? Are you trying to run 2 different sets of memory together?
17,164 (2.36/day)
And here we go... I bet you scratched some traces off that board...
5,929 (2.90/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
Why did you do it?
11,878 (2.23/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
1,168 (0.21/day)
Austria, Europe
Well i would try and RMA it anyway.
17,164 (2.36/day)
I bet I didn't as it was the air intake I modded and not while it was mounted on the board. ;)
Easily done...
Ex colleague of mine even managed to shave a few SMT/SMD components off a board, as he was watching footy on telly while building his system...
23 (0.01/day)
I usually make modifications when I build a new computer, in this case the stupid air intake to the chipset cooler that get totally blocked by the graphic card.
My mistake was that I did not waited until I had all the parts, motherboard, CPU and ram, so I could make a test run.
It sucks but Its not a catastrophe, it still works, just not in dual channel. :)
5,929 (2.90/day)
Poland
Yeah maybe if you waited a bit you'd realize that the chipset fan is not spinning at all for most of the time. But hey, you live and learn.
23 (0.01/day)
I can hear the chipset fan a little but I expect it to be worse as I will run this computer on full load all day with heat coming from 2 graphic cards that blocks a lot of the air intake.
But hey, you live and learn. ;)
13,881 (3.82/day)
Sunshine Coast
Processor AMD 5650GE
Motherboard Lenovo
Memory 32 GB DDR4
Mouse Lenovo
Keyboard Lenovo
Software W11 Pro 64 bit
Indeed it appears he has mixed ecc ram and non ecc ram.
23 (0.01/day)
No. I have tried BOTH types of memory, 1 stick only and put in DIMM-slot A2 and non of them worked in that slot.
I use the Kingston memory in my Threadripper build where they works just fine.
22,015 (6.01/day)
Mouse XTRFY M42
Easily done...
So now there is picture in my head of some hairy dude standing in front of a TV with a shaving device applied to a motherboard.
Thanks
I can hear the chipset fan a little but I expect it to be worse as I will run this computer on ful load all day with heat coming from 2 graphic cards that blocks a lot of the air intake.
That's what's up. :rockout: If it can't be fixed, move on.
7,207 (1.03/day)
Processor AMD Ryzen 7 7700 Raphael \ i5-1135G7 Tiger Lake-U
Motherboard ASRock B650M PG Riptide Bios v. 2.02 AMD AGESA 1.1.0.0 \ Lenowo BDPLANAR Bios 1.68
Video Card(s) Asus GeForce RTX™ 4070 Dual OC GPU: 2325-2355 MEM: 1462| Intel® Iris® Xe Graphics
Display(s) LG UltraGear 27GP850-B 1440p@165Hz | LG 48CX OLED 4K HDR | Innolux 14" 1080p
Software Win11 Pro 23H2 UK | Win11 LTSC UK / Arch (Fan)
Why is it that everytime people have a problem with their Ryzen system and I look at the specs I see a Asus board and more and more "ASUS ROG STRIX xxxx-E GAMING" board :confused:
Mostly it's the B450 variant of the Strix E Gaming but now it's the X570.
