New build will not power on.
19 (0.03/day)
UK
Processor AMD Ryzen 7700
Motherboard MSI MAG B650 TOMAHAWK WIFI
Cooling Wraith Prism
Memory Corsair Vengeance 32GB (2 x 16GB) 5600Mhz C36 DDR5
Video Card(s) Sapphire Radeon RX 7800 XT NITRO+ 16GB
Storage Samsung 970 EVO+1TB,Integral 1TB NVME M.2
Display(s) EG 32" QHD 75hz IPS
Case Lian Li Lancool 216
Audio Device(s) Creative GigaWorks T40 Series II
Power Supply Corsair RM850X V2 Modular 80+ Gold
Software WINDOWS 11
Hello all,I have just finished a new build and and nothing at all happens when I try to power it up.
Any ideas how I can sort it?
AMD Ryzen 7 7700
MSI MAG B650 TOMAHAWK WIFI ATX AM5
Kingston FURY Beast RGB 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory
Crucial P3 Plus 2 TB M.2-2280
Sapphire NITRO+ Radeon RX 7700 XT
Montech AIR 903 MAX ATX Mid Tower Case​
Corsair RM850x (2024) 850 W Fully Modular ATX Power Supply​
TIA
4,790 (0.96/day)
in a van down by the river
Cooling frostier than yours
Storage more ample than yours
Case fancier than yours
Benchmark Scores up yours
as in no power to the mobo, no lights or fans?
make sure the mobo and CPU power cables are fully in on both ends and you are using the CPU power and not a PCIe 6+2 cable
make sure the case power switch is properly connected to the mobo
43,223 (6.74/day)
AMD Ryzen 7 7700​
MSI MAG B650 TOMAHAWK WIFI ATX AM5​
Kingston FURY Beast RGB 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory​
Crucial P3 Plus 2 TB M.2-2280​
Sapphire NITRO+ Radeon RX 7700 XT​
TIA
Is your power strip/ups,and power supply power switch turned on on?
Have you connected the power switch from the case to the motherboard correctly- that means reading your motherboard manual. Maybe swap to reset switch for troubleshooting.
Have you ensured all atx power connectors are hooked up per your motherboard manual?
You might need to consider bench running you stuff out of the case and have your motherboard elevated so you can run the gpu correctly.
Make sure the cpu pin 1gold arrow is lined up with lga pin 1 on motherboard.
Please see this
1,170 (0.71/day)
System Name Gamey #1 / #3
Processor Ryzen 7 5800X3D / Ryzen 7 5700X3D
Motherboard Asrock B450M P4 / MSi B450 ProVDH M
Cooling IDCool SE-226-XT / IDCool SE-224-XTS
Memory 32GB 3200 CL16 / 16GB 3200 CL16
Video Card(s) PColor 6800 XT / GByte RTX 3070
Storage 4TB Team MP34 / 2TB WD SN570
Case Corsair 4000Air / TT Versa H18
Power Supply EVGA 650 G3 / EVGA BQ 500
I can't say for you but here's what has prevented my builds from powering on:
Case power button lines into USB header pins
Case power button lines into HDD LED pins
PSU switch still clicked off
Power strip off
PSU not plugged into power strip
Honorable mention:
GPU 8-pin power not plugged in (many many times, lol). PC will power up this way but you get no video out.
2,234 (2.63/day)
Brazil
Processor AMD Ryzen 7 5700X3D
Mouse Razer Viper Ultimate
Power strip off
Honorable mention:
I could add a sticker isolating the CMOS battery to this list.
19 (0.03/day)
UK
Software WINDOWS 11
Thanks for your replies.
I looked at how to bench test but did a short with a screwdriver in situ and it powered on.
After a bit of fiddling with the power switch at both ends it has fired up.
Thank you.
