New case loop order?
  • Thread starter Deleted member 24505
  • Start date
Well my o11D XL Rog case should be actually here in morning. Here is the loop order i have settled on. Fans will be as white arrows. Only thing im not sure on is the two 140 fans i have for the side positions, in or out?
3,127 (2.33/day)
Motherboard Apple proprietary
Cooling Apple proprietary
Case Apple proprietary
Mouse Apple Magic Trackpad 2
Software macOS Sonoma 14.7
I have a similar build (Lian Li O11D Mini -- the one listed in my system specs) and my loop order is identical.
The only differences is that A.) my bottom radiator is 360 mm and B.) my two side fans are 2 x 120mm (both intake).
At some point i may change the bottom rad to a 360 too, top one ill be a EK 360 PE. bottom is EK 280 CE. Not even sure if the 140mm fans will fit at the side yet.
thx
14,338 (3.80/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
Side fans as intake for positive pressure.
If it were mine I wouldn't bother with the rear fan and just leave top exhaust only.
4,531 (0.81/day)
Denmark
System Name The work PC /2700x/5950x
Processor 3900X stock/ 2700x stock/ 5950x 4200 MHz fixed @ 1,056-1,08V
Motherboard Gigabyte AORUS Master X570/2xMSI X470 M7 AC
Cooling Custom WC XSPC RX480, Laing DDC, XSPC Laing DDC Top V3 and EK Velocity/NH15/NH-U12S SE
Memory 32 GB Viper 3600/14 /16 GB Trident Z F4-4000C18D-16GTZSW 3600 /32 GB G Skill Flare CL14 3400
Video Card(s) 2070 Super X MSI/GTX 970 MSI/ GTX 970 MSI
Storage 1 TB SSD+500 GB NVMe / 500 GB SSD/ 2 TB 990 Pro
Display(s) Dell UltraSharp U2518D/2408WFP
Case Corsair 800D / Lian test bench/NZXT 500
Power Supply AX 850 Titanium/AX 860i/AX 760
Software Dual boot/Win 10 / Linux / Win 10+Linux
Remember that it is warm air coming from the bottom and that if you remove the airflow over the VRMs on the back they might get on the warm side. The extra flow going out at the backside of the case could be needed. Well it is easy to find out - fan on and off. I could easily be wrong...test it. The extra noise will be on the back and the case will reduce it.
14,338 (3.80/day)
Sunshine Coast
Memory 32 GB DDR4
Mouse Lenovo
Air flow from the bottom to top will be more direct without it, just my way of thinking.
4,531 (0.81/day)
Denmark
It needs to be tested, not a big problem.
3,127 (2.33/day)
thx
My O11D Mini accepts 140 mm fans in the side.
However I went with the 120 mm size because I wanted to run those two intake fans and the back exhaust fan on the same fan header and the case will not accommodate a 140mm fan in the back. My mini-ITX motherboard only has three fan headers (the other two headers are for the CPU radiator fans and GPU radiator fans respectively).
If I recall correctly, 280 mm radiators and 360 mm radiators have comparable cooling capability. There is more selection and variety available in the 360 mm radiator size though. Same with the 120 mm fan size.
My top CPU radiator is 20.5 mm thick, the XSPC TX360 Ultrathin. The bottom GPU radiator is 30 mm thick, an Alphacool NexXxos ST30. The case has enough clearance for thicker radiators in both locations but I (correctly) estimated that these two radiators would be quite sufficient for cooling their respective components.
My O11D Mini case was a dream to build in. My loop has plenty of cooling capacity and the fans run quietly even when the system is maxed out, whether it's a Handbrake encode or a gaming session. Mission accomplished.
Hope you have fun building yours!
ir_cow
4,767 (0.79/day)
USA
Loop order for cooling purposes does not matter. If you have a good flow rate, the temps between blocks will be 1-3c difference. So setup the look whatever way you like.
If the flow rate is poor, yeah it can matter for those higher overclocks. For mild or stock, it makes zero difference what is first in the loop. I'm running my test benches with the Radiator first because the tube runs are shorter.
11,017 (1.75/day)
Austin Texas
System Name stress-less
Processor 9800X3D @ 5.42GHZ
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply Corsair SF750
Keyboard 65% HE Keyboard
XL case - loop order looks good...
I would put both rads as intakes (one on the side) -- you can still mount the fan there.
Top and back open exhausts.
Thx guys. i will take pics as i build it. I have 4 90 degree rotarys to use in the loop too, as i'm using Ek black tubing, thought it might stop some tight bends.
4,531 (0.81/day)
Denmark
Yes please and some of us I'm sure would like to see some serious testing of VRM temperature :)
I'm actually looking forward to new temp tests as i am changing out the cheap 240 radiator with the EK 360mm PE 45. So my loop will be a EK 360 PE and a EK 280 CE. Temps should be pretty sweet.
4,531 (0.81/day)
Denmark
Your temperature will not be limited by the radiators but by the heat transfer from the IHS to the block(s). In my younger days I would have backed that up with data, now it's just a gut feeling. :laugh:
Well i will see if they are better than they are now.
I'll either post pics here or i might do some build pics in a new thread.
dgianstefani
TPU Proofreader
5,288 (2.03/day)
Swansea, Wales
Benchmark Scores Legendary
It's true. I have a single 240mm rad on my 5950x that keeps the temps below 60 most of the time due to my optimus block.
Might also be due to the mayhems XTR but that's minor I think.
2,261 (0.99/day)
south wales uk
System Name 1.FortySe7en VR rig 2. intel teliscope rig 3.MSI GP72MVR Leopard Pro .E-52699, Xeon play thing
Processor 1.3900x @stock 2. 5950x undervolted . 3. i7 7700hq 4 E5-2699 V3
Motherboard 1.aorus x570 ultra 2. Rog b550 f,4 MR9A PRO ATX X99
Cooling 1.Hard tube loop, cpu and gpu 2. Hard loop cpu and gpu 4 360 AIO
Memory 1.Gskill neo @3600 32gb 2.corsair ven 32gb @3200 3. 16gb hyperx @2400 4 64GB 2133 in quad channel
Video Card(s) 1.GIGABYTE RTX 3080 WaterForce WB 2. Aorus RTX2080 3. 1060 3gb. 4 Arc 770LE 16 gb
Storage 1 M.2 1tb +1tb , 2 3tb HDs 2. 1tb m.2 3tbHD 3. 256 m.2. 1tb ssd 4. 2gb ssd
Display(s) 1.LG 50" UHD , 2 MSI Optix MAG342C UWHD. 3.17" 120 hz display 4. Acer Preditor 144hz 32inch.z
Case 1. Thermaltake P5 2. Thermaltake P3 4. montech king 65
Audio Device(s) 1 Onboard 2 Onboard 3 Onboard 4. onboard.
Power Supply 1.seasonic gx 850w 2. seasonic gx 750w. 4 RM850w
VR HMD rift and rift S and Quest 2. rog ally 2tb m.2 1tb SD.
Software 1. win11 pro 2. win11 pro 3, win11 home 4 win11 pro
Benchmark Scores 1.7821 cb20 ,cb15 3442 1c 204 cpu-z 1c 539 12c 8847
looks good to me i see no problem with how your doing it and wish you the best of luck not that you will need it .
4,531 (0.81/day)
Denmark
We need some apple to apples here. I can throw in some numbers as well but we need a common standard test :)
I run 100 % CPU (WCG/Rosetta mix) on my 3900X and see 66°C. My rad is outside the case :D and the fans are not at 100% since the last RMPs doesn't move that number. Equipment in SS.
dgianstefani
TPU Proofreader
5,288 (2.03/day)
Swansea, Wales
My 100% cpu is OCCT and see no more than 63c
Or cinebench, get around 29k.
4,531 (0.81/day)
Denmark
Right done. lots of pics. When i took the CPU block off the paste spread was very good.
