New case, old problems. ESD/EMI issues with new chassis.
2,501 (1.17/day)
Olympia, WA
System Name Sleepy Painter
Processor AMD Ryzen 5 3600
Video Card(s) MSI RX580 8GB
Case NZXT Gamma Classic Black
Audio Device(s) Asus Xonar D1
Mouse Logitech MX518 Legend
Keyboard Red Dragon K552
I just re-built into a new case (Geometric Future Dharma) with 2 big glass windows on it, and when I get up or sit down into/out of my chair about 60% of the time the ESDs (between clothing and chair) are disconnecting a device in/on my PC (2-3ft from chair, under desk). I haven't been able to pin down what device(s). (I'm suspecting data link to the monitor and/or NIC (based off duplicate hidden devices in device manager)
Note: The PC is connected to an always-online double conversion UPS, and it did *not* do this with my old Fractal Design Focus G (even w/ its smaller and singular acrylic window)
At first I assumed the big glass windows are the issue (since the same occurred on old case, w/o a side panel at all) but,
this case does re-orient the I/O to the top of the case w/ a metal mesh cover over the top.
I've considered some Metallic Window Tint Film or actual EMI shielding film from Holland Shielding Systems
but
if it's just a 'bad' cable, I'd rather just replace or 'choke' the offending one.
Thoughts? Insight?
43,583 (6.77/day)
I just re-built into a new case (Geometric Future Dharma) with 2 big glass windows on it, and when I get up or sit down into/out of my chair about 60% of the time the ESDs (between clothing and chair) are disconnecting a device in/on my PC. I haven't been able to pin down what device(s). (I'm suspecting data link to the monitor and/or NIC (based off duplicate hidden devices in device manager)
but
Thoughts? Insight?
What chair?
You might consider changing to a different chair or clothes and getting an anti static mat, ive killed 2 usb drives via esd on the back of a motherboard, thank God the mobo wasn't damaged but the drives were toast.
You might need to consider bare metal bonding between the chassis and power supply. There is a thing used for electronics called a bonding strap
2,501 (1.17/day)
Olympia, WA
What chair?
Some generic cloth and 'technical mesh' chair. It certainly doesn't help wearing polyester, either; you're right.
The ambient humidity is definitely too low, too. but, I really don't want to have to run a humidifier.
Over the last decade+, I've sent at least 2 PCs into 'conniption fits' of flashing colors, from ESDing a USB port directly. Thankfully, neither was an (immediate*) casualty.
*I'm well-aware ESD damage is somewhat 'cumulative', and 'still working' does not mean "undamaged".
My personal conundrum is, that this was not an issue w/ my old case, as long as I had it 'buttoned up' (side panels on and tightened)
The screws, threads, and the facings the screws pull down onto, all have their paint/coating worn away. -Probably not a good enough of a bonding though...
If I were to install a bonding strap between the PSU's casement and the chassis of my case, where should the chassis-side mount go? Would *any* existing threaded screwhole work (sanded bare, torque'd down), or would the rough-center of the chassis' mass be better?
43,583 (6.77/day)
The relative humidity is definitely too low, too. but, I really don't want to have to run a humidifier.
A unpainted/uncoated "bare" metal spot can be used for bonding.
A co-worker had to remove some paint on an aircraft part in a certain spot to get less than 20 milliohms (0.020Ω) of resistance for proper bonding continuity.
I use a Modern 'Megger' at work for insulation resistance and continuity.
429 (1.59/day)
System Name Kuro
Processor AMD Ryzen 7 7800X3D@65W
Motherboard MSI MAG B650 Tomahawk WiFi
Memory Corsair DDR5 6000C30 2x48GB (Hynix M)@6000 30-36-36-76 1.36V
Video Card(s) PNY XLR8 RTX 4070 Ti SUPER 16G@200W
Storage Crucial T500 2TB + WD Blue 8TB
Case Lian Li LANCOOL 216
Power Supply MSI MPG A850G
Software Ubuntu 24.04 LTS + Windows 10 Home Build 19045
Benchmark Scores 17761 C23 Multi@65W
For what it worth, the matting on my chair has some kind of synthetic material that produces so much static electricity when I sit down and stand up, that it gives painful shocks and I've managed to fry the balanced output ports of two DACs, and a (thankfully non-critical) touch button on the control panel of a water heater, before figuring out to ground myself first. It does not appear to have done anything to the computers on my table - though now I'm wondering whether it might have anything to do with some of the freezes I've been occasionally getting. My current case has one large glass panel on it at the usual location.
Back on topic, I'd be worried about grounding somewhere along the chain to your setup's internals, and not just the case, if it is that bad.
