New Drivers for Sound Blaster Z / Zx / ZxR / Z SE
Regeneration
NGOHQ.COM
3,081 (0.45/day)
Attached below is an official driver version 6.0.102.0078 for Creative's Sound Blaster Z series. Works with Z, Zx, ZxR and Z SE. Still not listed on their website, but the release notes as follows:
Fixes:
* On some system, encoder no audio while using External Dolby Digital decoder.
* With Windows 11, toggling direct mode some times will cause distortion or no sound.
In addition, a new version of Sound Blaster Command is also available:
http://files.creative.com/creative/.../release/CreativeSBCommandSetup_3.5.06.00.exe
Version 3.5.6.0,
* Better handling of Direct Mode in Windows 11 for AE series and Z series.
  • SBZSeriesDriverInstaller.exe
3 (0.00/day)
The driver is broken, it does not contain the proper digital signature (the developers accidentally inserted cthda.cat from a previous version):
Regeneration
NGOHQ.COM
3,081 (0.45/day)
Try again. I've updated the file above with the original fetched by Sound Blaster Command auto-update.
Filename: SBZSeriesDriverInstaller.exe
MD5: d50632606613fa9b2d1dc0d15070bf99
3 (0.00/day)
Same hash and it's broken: Sound Blaster Command asks for an update after every reboot, and Device Manager shows the old version.
Regeneration
NGOHQ.COM
3,081 (0.45/day)
I just re-installed it myself and it works fine:
Make sure you run it as admin, and try to first update SB Command to version 3.5.6.0.
You can try to install it with "disable driver signature enforcement" from the boot menu.
3 (0.00/day)
Looks like the issue only with Windows 8.1, on Windows 10 driver is properly signed.
7,242 (1.46/day)
Rīga, Latvia
System Name HELLSTAR
Processor AMD RYZEN 9 5950X
Motherboard ASUS Strix X570-E
Case Lian Li O11 Dynamic EVO
Mouse Razer Basilisk
Software FEDORA 40
I updated the driver with no problems also. Seems like an old OS problem.
AAF Optimus
Account Closed - Will not update Projects
1,163 (0.43/day)
Rio de Janeiro, Brazil
System Name NEW AAF OPTIMUS RIG
Processor AMD Ryzen 5 5600X (6C/12T)
Motherboard ASUS TUF Gaming B550M-Plus
Cooling DEEPCOOL Gammax L120T
Memory CRUCIAL Pro Gaming 32GB DDR4-3200 (@3733) (2x16GB)
Video Card(s) NVIDIA GeForce RTX 3060 12GB MSI Ventus 2X OC LHR
Storage ADATA Legend 700 PCIe Gen3 x4 256GB; ADATA Legend 800 PCIe Gen4 x4 2TB; GoldenFir SSD 1TB
Display(s) AOC VIPER 27" 165Hz 1ms (27G2SE)
Case DARKFLASH DK100-BK
Audio Device(s) REALTEK S1200A (ALC1200) with AAF Optimus Audio
Power Supply REDRAGON RGPS 600W 80 PLUS Bronze Full Modular
Mouse CLAHM CL-MM386 7200DPI
Keyboard MOTOSPEED CK-108 Mechanical Keyboard
This means that the package has a specific signature for Windows 10 or higher. This parameter is set when generating the security catalog.
2,798 (2.15/day)
I'm guessing that's to do with the sha1 and sha2, sha1 then dual sign (1+2), then sha2.
kluyt007
2 (0.00/day)
Fixes:
Version 3.5.6.0,
I've updated the driver of my Z serie, and the Sound Blaster Command to the new versions, but now Command says there is no supported device to find, please connect?
it works on Windows 11, the previous version worked fine, all setting availlable, but now it is empty screen........
can you help?
Regeneration
NGOHQ.COM
3,081 (0.45/day)
can you help?
Make sure to reboot and all drivers were installed correctly in the device manager.
If you have antivirus/firewall like Kaspersky, try to give Sound Blaster Command permissions, or run it manually as admin.
kluyt007
2 (0.00/day)
done, all oke, antivirus is the Windows internal, no extra, and installed as administrator, stil blank......
is I go back to the old version, it is active again..... version 3.4.98 is working.......
Regeneration
NGOHQ.COM
3,081 (0.45/day)
So try to clean reinstall... remove everything from the contron panel, and ensure drivers are removed too from the device manager, and then try DDU from safe mode.
