Hey guys,
So recently I built a new PC - I'll list the parts below. Everything set up, I decided I will test performance on some games. So I downloaded a couple of high end-ish games and what I noticed is my CPU on game load (less than a minute after I started the game) the temp goes 75 C degrees. After 10 minutes of playing it escalates gradually to 95 C. Which is insane. Read some articles about a bug in AMD Balanced Power Plan so I manually updated the drivers, but no difference. Tried undervolting, no success. Same happened when I went and bought a good quality thermal paste and replaced it with the stock one.
However I had some kind of success when I turned on power saver mode but it only slowed a bit down the progression of CPU heating up, I mean it goes up to 90-95 again, but it takes a bit more time.
One thing I'm not sure if it's okay or not - CPU cores rapidly change their clock speed going up to 4250MHz, even though CPU is 3.6GHz.
Please share your opinions, hope I can get rid of this problem soon and start using my PC normally.
PC specs:
CPU: AMD Ryzen 5 3600
GPU: Gigabyte RTX 2060 Super
Motherboard: MSI B450 GAMING Plus Max
RAM: 2x8GB G.Skill Trident Z
PSU: CORSAIR RM650X 650w
Case: FD Focus G
CPU Cooler: Wraith stealth (stock one)
Note: Yup, I am considering changing the cooler but even with the stock one it's insane to have this experience..
Thanks!
PC specs:
Case: FD Focus G
Thanks!
