- Jan 2, 2024
- 580 (1.72/day)
- Seattle
System Name | DevKit |
Processor | AMD Ryzen 5 3600 ↗4.0GHz |
Motherboard | Asus TUF Gaming X570-Plus WiFi |
Cooling | Koolance CPU-300-H06, Koolance GPU-180-L06, SC800 Pump |
Memory | 4x16GB Ballistix 3200MT/s ↗3800 |
Video Card(s) | PowerColor RX 580 Red Devil 8GB ↗1380MHz ↘1105mV, PowerColor RX 7900 XT Hellhound 20GB |
Storage | 240GB Corsair MP510, 120GB KingDian S280 |
Display(s) | Nixeus VUE-24 (1080p144) |
Case | Koolance PC2-601BLW + Koolance EHX1020CUV Radiator Kit |
Audio Device(s) | Oculus CV-1 |
Power Supply | Antec Earthwatts EA-750 Semi-Modular |
Mouse | Easterntimes Tech X-08, Zelotes C-12 |
Keyboard | Logitech 106-key, Romoral 15-Key Macro, Royal Kludge RK84 |
VR HMD | Oculus CV-1 |
Software | Windows 10 Pro Workstation, VMware Workstation 16 Pro, MS SQL Server 2016, Fan Control v120, Blender |
Benchmark Scores | Cinebench R15: 1590cb Cinebench R20: 3530cb (7.83x451cb) CPU-Z 17.01.64: 481.2/3896.8 VRMark: 8009 |
It's no mystery to anyone here that I run my systems well beyond EOL and typically only replace parts as they fail.
While this is fine for general turn-key operation, it turns troubleshooting into a nightmare as I struggle to diagnose this and that.
I am at a crossroads with upgrades which goes against that usual 2/3 step process and need recommendation on a new power supply.
This should be a single purchase and lasts multiple years/loadouts as I experiment with a mix of enterprise and enthusiast hardware.
At the moment I'm operating a single RX 580 GPU and considering giving the 7900XT another try (if not something newer).
This is after AMD, ASUS, PowerColor and Newegg support all missed there's a 62A floor to operate the card and I don't meet that.
My RX580 only needs a single 6-pin to power on, which is why I can swap it into the rack for quick testing. The 7900XT requires 2x8-pin.
Ironically I had to look up the full specs and rating on PowerColor's site just to confirm the real minimum, which is how I found out.
The entire reason I locked in on this product in the first place is an easy check of 750W minimum, which I still use for this system.
Welp, time to change that.
I do a lot of enthusiast overclocking and sometimes bizarre cooling experiments that tread lightly into AHOC territory minus refrigeration.
So I'm currently interested in two products that stand out, both made by a co called Super Flower: A 850W and 1200W unit.
Those rating charts look like this:
Aside from the mess of fully modular pinouts and excessive PCI-E 8-pin options that I'm likely never going to use, 70-99A output sounds great.
There may be a slim chance I switch up to a Liquid Devil that calls for using three full 8-pins but I don't know how that future goes at the moment.
We've seen GeForce cards push well beyond 400W and earlier rumors mentioned 600W as possible for 5000 series, probably engineering samples.
Still, we always somehow get here. I don't foresee another ARES III or Devil 13 situation happening where I go for that but I should be ready to test.
I could ignore everything and pick up a 7800XT or 4070 but they are the bare the minimum to carry my workloads and I need something that works.
So what do?
So what do?
