New year pc problems.
1,227 (0.19/day)
United Kingdom
Processor Intel 10 Core i9 10900K Comet Lake CPU/Processor
Motherboard Gigabyte Intel Z490 AORUS MASTER ATX Motherboard
Cooling Noctua Intel/AMD NH-D15 Silent CPU Cooler
Memory Corsair 32GB ( 4x8) DDR4 Vengeance LPX 3000MHz Memory
Video Card(s) Zotac NVIDIA GeForce RTX 3080 8GB AMP! Extreme Turing Graphics Card
Storage Samsung 970 EVO PLUS 500GB M.2, Samsung 970 EVO Plus 1 TB PCIe NVMe M.2
Display(s) ASUS ROG Swift PG279Q 27" 2K WQHD 165Hz IPS G-Sync 2K Gaming Monitor, Sony Bravia 49" 4k uhd tv
Case NZXT Phantom 410 Black Orange Special Edition
Audio Device(s) Sound BlasterX AE 5 RGB PCIe Gaming Soundcard
Power Supply Corsair RM1000
Mouse Roccat ROC-11-812 Kone EMP Max Performance Razer Basilisk x Hyperspeed Wireless Gaming Mouse
Keyboard Roccat isku/ fx
Hi first day of the year and I got problems, I unplugged my tower to install a second ssd which is no problem but when I plugged it back in nothing happened so I reversed what I done and still nothing happened. I checked the sockets and there is power going to the tower I noticed the little red button on the top right of the motherboard flashes when I turn the power on but that is all, any ideas.
9,781 (2.17/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
Your best bet is to disassemble and then reassemble. In the process of which you can check that everything is in order and make sure all switches are set to on etc. also power bars and then the other devices in between your computer and it's power source
Whenever I get into a situation that has my computer not turning on I tend to disassemble it down to just the processor and a single stick of RAM and then work up from there
2,097 (0.52/day)
System Name Ryzen 2023
Processor AMD Ryzen 7 7700
Motherboard Asrock B650E Steel Legend Wifi
Memory G Skill Flare X5 2x16gb cl32@6000 MHz
Video Card(s) Sapphire Radeon RX 6950 XT Nitro + gaming Oc
Storage WESTERN DIGITAL 1TB 64MB 7k SATA600 Blue WD10EZEX, WD Black SN850X 1Tb nvme
Display(s) LG 27GP850P-B
Case Corsair 5000D airflow tempered glass
Power Supply Seasonic Prime GX-850W
Mouse A4Tech V7M bloody
Keyboard Genius KB-G255
Software Windows 10 64bit
What does the debug LED say?
Sometimes my PC wont start but it does after hitting the reset button.
2,344 (0.44/day)
Processor Intel i7 970 // Intel i7 2600K
Motherboard Asus Rampage III Formula // Asus P8P67 Deluxe
Cooling Zalman CNPS9900MaxB // Zalman CNPS11X
Memory GSkill 2133 12GB // Corsair V 2400 32GB
Video Card(s) ASUS GTX1080 // MSI GTX1070
Storage Samsung 870EVO // Samsung 840P
Display(s) HP w2207h
Case CoolerMaster Stacker 830se // Lian Li PC-9F
Power Supply Seasonic X 850w Gold // EVGA 850w G2
Mouse Logitech G502SE HERO, G9
Keyboard Dell
Software W10 Pro 22H2
Bad PSU, best guess. When the power was drained, that was it.
1,227 (0.19/day)
United Kingdom
Where do I find the LED, as for the re-assemble i will leave that till tomorrow and keep my fingers crossed about the power supply.
2,097 (0.52/day)
It should be in the top right corner of the motherboard. Is that your motherboard?
1,227 (0.19/day)
United Kingdom
Thanks I will go have look
Sorry it's not lit but when I turn the switch on the power supply on the push button PW SW flickers, no fans no nothing.
2,097 (0.52/day)
It seems to be the power supply. I have a similar issue. I hit the power button to turn on the PC and the led on the button starts flickering or blinking then I hit restart as fast as I can and the PC boots fine.
43,571 (6.77/day)
Get a spare psu of equal or greater rating and test,
1,227 (0.19/day)
United Kingdom
the only PSU I can get my hands on is a Corsair TX750 is that any good or else I will have to buy one.
1,901 (0.32/day)
Processor 5930K
Motherboard MSI X99 SLI
Cooling WATER
Memory 16GB DDR4 2132
Video Card(s) EVGAY 2070 SUPER
Storage SEVERAL SSD"S
Display(s) Catleap/Yamakasi 2560X1440
Case D Frame MINI drilled out
Power Supply Corsair TX750
Mouse DEATH ADDER
Keyboard Razer Black Widow Tournament
Software W10HB
Benchmark Scores PhIlLyChEeSeStEaK
Its good!
1,227 (0.19/day)
United Kingdom
Hi installed the 750 power supply a minute ago and no joy not even a flicker, I am going to give it another go tomorrow if no joy tomorrow help what could it be.
43,571 (6.77/day)
If its no go its possible the board is bunk
2,097 (0.52/day)
If it wont turn on still I would take it out of the case and try the bear minimum (cpu, mobo, psu, and 1 stick of ram) no HDD no SSD. Could it possibly be the power button on your case? Try starting the pc with a screwdriver or just disconnect the power and reset switch and connect the reset as the power switch.
43,571 (6.77/day)
Some boards should have a built in power switch
2,097 (0.52/day)
I forgot about that but as it can be seen on the picture I posted he's boards has that button.
43,571 (6.77/day)
Yeah if it doesnt work after that, it might be plausible to check the cpu socket for bent pins or burn marks, if there are none the board probably bit the dust.
1,227 (0.19/day)
United Kingdom
Hi just got round to testing my power supply and the fan started straight away so my PSU is okay is there anyway I can test the motherboard.
3,016 (0.52/day)
MN
System Name Personal / HTPC
I had a similar issue about 14-16 months back. Shut the system down and unplugged all the cables. Moved the tower to the table and just did some general cleaning. I didn't remove anything other than dust filters, I didn't use canned air on the tower and used a tooth brush to clean up some fan fins. I plugged everything back in and not a thing from the MB.
I tried multiple PSUs.
I pulled everything apart and tested just the MB, 1 stick of RAM and CPU on a cardboard box - nothing.
MB kicked the bucket on me.
If you test the MB with multiple PSUs while she's just sitting on a cardboard box with the CPU, heatsink, 1 stick of RAM and a you can't get power through the board, she's toast.
1,227 (0.19/day)
United Kingdom
1,227 (0.19/day)
United Kingdom
Hi I have just tried the motherboard on a box but nothing happened other than the power switch top right on the motherboard it flickered as I turned the power on and I tried it with two working power supplies.
43,571 (6.77/day)
cookiemonster 1 last thing to try, take the board out of the case, put on a non metal surface, hook up the minimum equipment, take cpu out and inspect for burnt or damaged/bent socket pins. If none, put cpu back in with 1 module of ram in applicable slot, if you have a spare rig that is compatible swap in gpu, ram, if no boot replace the rig and sell off the cpu. It really sounds like the motherboard but only testing your parts in other rigs or putting in known good parts in yours can help
1,227 (0.19/day)
United Kingdom
Thanks I will try the cpu in my grand daughters if it works it will be a nice upgrade for her.
1,227 (0.19/day)
United Kingdom
