- Oct 9, 2007
- 47,074 (7.59/day)
- Hyderabad, India
System Name | RBMK-1000 |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
Nexus announced the newest addition its case lineup. The Nexus EDGE, measuring 64.2 x 23.9 x 57.6 cm (L x W x D) is a full-ATX tower, compatible with most Flex-ATX, M-ATX, ATX, and E-ATX motherboards. The case has a fine brushed-metal finish with polished, rounded-off edges. The external drive bays can be locked off behind a metal front-door. Although the exterior reveals 13 5.25" bays, only 8 of them are accessible. The bottom five bay covers protect the 4-bay 3.5" drive cage inside, which neighbours two 2-bay drive racks that hang above the PSU area. This area is separated from the motherboard area, and shares room for a 120 mm fan with it.
The motherboard tray has room for 7 expansion slots. It has an opening where most motherboards have the CPU socket, which provides accessibility to CPU coolers with bolt-through retention mechanisms. Another 120 mm fan bay is located above the rear-panel, an a 140 mm fan to ventilate the entire case from its top. The case provides a degree of noise control with its noise-absorbtion wave foam padding. The utility panel is located on the top, and is a standard issue with a couple of USB ports, an eSATA port, and audio connectors. The Nexus EDGE is expected to retail for around 160 EUR.
