No anti-aliasing most of my games.
HarveyOsull
2 (0.00/day)
I recently bought a zotac gtx 1050 ti mini and for a while i was really impressed for how well it performed with such little power. Recently i have noticed a lack of anti aliasing in most of my games: Pubg, Just cause 3, Tf2, Csgo and so on. However i did not notice any problems playing the recent Sea of Thieves scale test. I have tried turning it on to the max in the Nvidia control panel and that fixed the problem for tf2 only. Please help me.
Specs
I7 2600Hz
16g DDR3
Gtx 1050 ti
3 tb HDD
(i have overclocked my GPU) It is also quite hard to see in these photos.
*sorry its an I7-6700 3.40GHz
42,478 (6.66/day)
Specs
I7 2600Hz
16g DDR3
Gtx 1050 ti
3 tb HDD
View attachment 98027View attachment 98028View attachment 98029View attachment 98030
Restore game and Control panel settings to stock.
Patch direct x up, turn up refresh rate if possible, set monitor to native resolution, make sure your monitor driver is installed, chipset driver too. Get Display driver uninstaller and the specific graphics driver, make sure games are patched too.
Disconnect ethernet cord or disable wifi, Run Display driver uninstaller twice follow directions to the T, reinstall chipset driver, then graphics driver, restart, check to ensure monitor resolution and refresh rate are correct. Then adjust graphics settings in game only, remember you are using a budget card so some settings may not work like on higher cards.
Make sure your games are patched
1,451 (0.29/day)
[Formerly] Khartoum, Sudan.
System Name 192.168.1.1~192.168.1.100
Processor AMD Ryzen5 5600G.
Motherboard Gigabyte B550m DS3H.
Cooling AMD Wraith Stealth.
Memory 16GB Crucial DDR4.
Video Card(s) Gigabyte GTX 1080 OC (Underclocked, underpowered).
Storage Samsung 980 NVME 500GB && Assortment of SSDs.
Display(s) ViewSonic VA2406-MH 75Hz
Case Bitfenix Nova Midi
Audio Device(s) On-Board.
Power Supply SeaSonic CORE GM-650.
Mouse Logitech G300s
Keyboard Kingston HyperX Alloy FPS.
VR HMD A pair of OP spectacles.
Software Ubuntu 24.04 LTS.
Benchmark Scores Me no know English. What bench mean? Bench like one sit on?
I have no experience with those titles you play, but tbh, I don't see much diagonal jaggies in those shots you've uploaded, seems AA is working decently on those. Most of the alisaing I see is thing-geometry aliasing. And afaik, typical AA approaches don't work well on those, specially your simple post-process techniques a la FXAA. You'll need something more serious to deal with those (SSAA or Nvidia's DSR).
Try testing simpler scenes if you suspect your card not doing AA probably. Graphical demos, software that uses opengl/direct3d viewports or simple, browser-based tests like this.
I'd suggest you follow eidairman's advice of resetting control panel to stock first though.
7,412 (2.76/day)
Poland
System Name Purple rain
Cooling Noctua D15S
Benchmark Scores A LOT
Haven't played those games you mentioned, but aliasing is a problem for some of the recent games I played. As games get more complex geometry, GPUs just can't handle high quality antialiasing and smaa/taa just isn't enough. Another reason is just sloppy developers. I'm playing at 1440p and 24" display, and even then I do notice a lot of aliasing in some games, if I had to choose the worst that'd be Destiny 2 and WatchDogs2. Only thing that helps is increasing scaling/pixel density, the games look amazingly sharp again but that takes a huge toll on fps. I played Titanfall 2 and some others like Wolfenstein,Dishonored 2 and they look fine tho. I'll say most of them still look fine but there are exceptions, like the two I mentioned.
43,609 (6.49/day)
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
Since you mention using the Nvidia control panel for things reset it to default. If that doesn't do it, uninstall your drivers, run Display Driver Uninstaller utility and reinstall your drivers.
28,143 (6.73/day)
My advice is going to differ from the rest. I never use AA. At 1080p and above it's not really needed and is a waste of GPU resources. As @Shihabyooo was saying, the "jaggies" aren't really that noticable and are not going to affect game-play. Plus you have a 1050ti, it will be bogged down by AA anyway. So my advice is to leave AA off entirely and enjoy your games at higher frame rates.
7,412 (2.76/day)
Poland
Cooling Noctua D15S
I notice jaggies at 1440p 24" and you're saying AA is not needed at 1080p. Depends on the person, most, I mean the vast majority, would still need it @1080p or even 1440p.
rtwjunkie
PC Gaming Enthusiast
13,996 (2.34/day)
Louisiana
Processor Core i9-9900k
My advice will be even different, based on my own experiences. I do not ever set in the control panel, mostly because it means having to go and set up everything separately for each different game. I just want to play. I always only optimize game settings in the game. I work with whatever the game provides, get the antialiasing I want and am satisfied with visual results.
9,781 (2.20/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
5,047 (0.94/day)
Iberian Peninsula
and then we have Geforce Experience to setup eeeeeeeeeeeeeeeverything :rolleyes:
10,885 (1.57/day)
Manchester, NH
System Name Senile
Case Rosewill
Power Supply Corsair HX750
Mouse Logitech G5
Software Win 10
My Advice will be the MOST Differentliest! pull out the GPU, blow on it like an old Nintendo cartridge, re-install. 10/10 problem solved ;)
Lol
I see jaggies... You have AA on in game + NV controls?
7,412 (2.76/day)
Poland
Cooling Noctua D15S
I just wanna say this is a curse. I mean the sharp eye for aliasing. If you're put off by jaggies you really need a lot of GPU horsepower to run higher scaling/pixel density to achieve good image sharpness.
3,014 (0.64/day)
Zagreb, Croatia
System Name Windows 10 64-bit Core i7 6700
Processor Intel Core i7 6700
Motherboard Asus Z170M-PLUS
Cooling Corsair AIO
Memory 2 x 8 GB Kingston DDR4 2666
Video Card(s) Gigabyte NVIDIA GeForce GTX 1060 6GB
Storage Western Digital Caviar Blue 1 TB, Seagate Baracuda 1 TB
Display(s) Dell P2414H
Case Corsair Carbide Air 540
Power Supply Corsair TX v2 650W
Mouse Steelseries Sensei
Keyboard CM Storm Quickfire Pro, Cherry MX Reds
Software MS Windows 10 Pro 64-bit
This is the case when Anti Aliasing algorithm tries not to blur too much like FXAA, and the result is perceived as lack of AA
10,885 (1.57/day)
Manchester, NH
System Name Senile
Case Rosewill
Mouse Logitech G5
Software Win 10
This even drives me crazy:
1,606 (0.35/day)
Northamptonshire, UK
System Name Main / HTPC
Processor Ryzen 7 7800X3D / Ryzen 7 2700
Motherboard Aorus B650M Elite AX/ B450i Aorus Pro Wifi
Cooling Lian-Li Galahad 360 / Wraith Spire
Memory Corsair Vengeance 2x16 6000MHz CL30 / HyperX Predator 2x8GB 3200MHz
Video Card(s) RTX 3080 FE / ARC A380
Storage WD Black SN770 1TB / Sabrent Rocket 256GB
Display(s) Aorus FO32U2P / 39" Panasonic HDTV
Case Fractal Arc XL / Cougar QBX
Audio Device(s) Denon AVR-X2800H / Realtek ALC1220
Power Supply Corsair RM850 / BeQuiet SFX Power 2 450W
Mouse Logitech G903
Keyboard Drop Sense75 with WQ Studio Morandi's
VR HMD Rift S
Software Win 11 Pro 64Bit
The games you've mentioned have the simplest AA implementation, meaning it only makes the jaggies blurrier, but not actually removing them. If you really want to force AA, I would suggest trying Nvidia Inspector, and change some settings there.
HarveyOsull
2 (0.00/day)
Is Nvidia inspector better than MSI Afterburner?
9,781 (2.20/day)
Massachusetts
Processor i7-11700K
I'd say no simply because it's Nvidia only , but maybe on some off chance it offers more function for those cards then after burner does
42,478 (6.66/day)
1,606 (0.35/day)
Mouse Logitech G903
VR HMD Rift S
MSI Afterburner doesn't deal with in-game settings, it's just for monitoring and overclocking.
43,609 (6.49/day)
2,707 (0.75/day)
On The Highway To Hell \m/
How do you make perfectly curvilinear objects composed of perfectly square pieces(such as pixels)?
Answer = You don't. Throwing time/money at it will only get you so far. Perfection is unattainable. Period. End of story.
Not sure why that's so difficult of a concept to grasp for so many people.
1,451 (0.29/day)
Nvinspector is a cool tool, but I don't really think it'll be a simple solution for anything but overpowered hardware or old (or based on old code) games, and it's not quite guaranteed in the former.
Games have gotten complicated, ye ol' MSAA doesn't work like it used to (or at all) in them. That leaves you with little choice other than SSAA and co, and those WILL BUTCHER performance, even on high end card.
But pixels are not perfectly square...
Reduce pixel size to less than the least wavelength of visible light? :|
1,606 (0.35/day)
Mouse Logitech G903
VR HMD Rift S
Throw more pixels at the problem? Duuh
