No Audio on left Headphone plugged at the front panel
20 (0.01/day)
System Name Shogun
Processor i5 3570
Motherboard GIGABYTE B75M-HD3
Cooling Standard Boxed Version
Memory 8 GB Kingston KHX 1600C9D3/4GX
Video Card(s) Sapphire HD 5770
Storage WDC WD15EARX-00PASB0
Power Supply Corsair CX600M
Software Windows 7 Ultimate
Hello,
I have no sound on the left speaker of my headphone when it is plugged at the front panel.
when plugged rear it works.
when plugged headphones into the desk speakers logitech 2+1 it works.
my desk speakers logitech 2+1 are plugged at the rear panel it works fine.
when I plug the headphones at the front I get sound only from the right speaker of the headphone.
System newly setup with all drivers.
Attached picture of systemspecs.
I have changed front panel audio connector settings from hd audio to AC97 and vice versa.
I would appreciate it very much if anyone have an advice, as I do long gaming sessions after everyone is asleep and I cant hear from desk speakers at night, not to make all neighbours and family upset.
1,450 (0.34/day)
Israel
Processor AMD Ryzen 7 5800X
Motherboard B550 Aorus PRO V2
Cooling Corsair H115i RGB Platinum
Memory Gskill Trident Z Neo 3600 2x16GB
Video Card(s) MSI RTX 3070 Trio X
Storage WD Blue SN550 1TB NVME/Supertalent Teranova 2x1TB
Display(s) Dell AW3423DWF
Case Corsair 4000D Airflow
Audio Device(s) Schiit Audio Modi+\Magni+
Power Supply Corsair HX850i
Keyboard SteelSeries Apex Pro
Try connecting the speakers to the front panel, do both speakers work?
FordGT90Concept
"I go fast!1!11!1!"
26,259 (4.55/day)
IA, USA
System Name BY-2021
Cooling Scythe Mugen (rev 5)
Mouse Nixeus REVEL-X
Keyboard Tesoro Excalibur
There might be something wrong with the jack or it may not be fully inserted. From the tip down, it's left, right, ground. If the tip isn't long enough to make contact with the inside of the jack, you won't get left channel sound.
20 (0.01/day)
System Name Shogun
Processor i5 3570
Hi if one of both deskspeaker and headphones plugged back work properly.
if one of both plugged at the front panel, only sound from right speaker either deskspeaker or headphone.
checked by using slider in realtek audio menu.
1,450 (0.34/day)
Israel
467 (0.14/day)
South Africa ,Lions Everywhere..
System Name Ground Control
Processor Intel i5 2500k 4 Ghz
Motherboard MSI P67A-GD80 B3
Cooling Cooler Master Hyper 212x
Memory 2 x 4GB DDR3 1600mhz Apacer Black Panther
Video Card(s) Msi GTX 1060 OC 3Gb
Storage 2 x 250Gb WD Blue raid 0 + 1Tb Wd Green
Display(s) Samsung BX2450 24" Led
Case GMC X7 X-Station
Power Supply HEC Raptor 500watt
Mouse Logitech G9
Software Windows 8.1
Benchmark Scores Power Level over 9000
What case are you using? How is the front panel connected to the motherboard?
Possible who ever built the pc wired up the front panel incorrectly .
Check if wired correct,check on the case in front if the connector is loose(behind the front audio ports) will have to remove front of case
12,305 (2.32/day)
Oregon
System Name Juliette // HTPC
Video Card(s) ASUS RTX4070 OC// GTX 1650
Mouse Cooler Master MM710 53G
AsRock
TPU addict
18,960 (3.04/day)
UK\USA
i was thinking the same or that the front panel is not connected right.
20 (0.01/day)
System Name Shogun
Processor i5 3570
front panel connected proporly, checked multiple times.
as far as ı can say either the wire or the front panel has an issue, but ı dont know how to control that.
except that a silly ıdea.
ı dont have professionell tools but what if ı check with a wrench like the ones you use to check if the socket has electriticity.
there is a small led and if a socket has power the led turns on. so ım gonna touch the wire from the connector with such wrench and look if the led turns on.
of course this is a little bit silly because the wrench ım gonna use is for household sockets where is normally 220 volt.
