No video signal? Graphics card giving up?
Seeknay25
18 (0.00/day)
Processor 2.60 gigahertz AMD Athlon 64 X2
Motherboard Acer F690GVM
Video Card(s) VisionTek 900244 Radeon HD 4870 512MB
Power Supply PC Power & Cooling S75QB 750W
alright so I got my new power supply and graphics card and after a while of putting a huge graphics card and psu in my minitower I tried everything and it didnt work. I turned it on and after about 3 mins the screen went blank and said no video signal, but everything else was still running fine. I restart and only got about 1 min. And then 45 seconds. Then I let it sit for half hour nad got 2 mins out of it. SO i put in my old graphics and make sure i fully uninstalll it, and i did. Try it again, samme thing. So idk. My psu obviously works because I'm using my old graphics card atm. And when I took out the new one it was VERy hot. I had to let it cool for little before i could remove it. Im guessing that the graphics card gets too hot and just shuts down? I would like to try as many solutions at once o I dont have to keep taking it in and out just to test one little thing. Any help/tips is helpful. :)
psu= PC Power & Cooling S75QB 750W
grpahics card = VisionTek 900244 Radeon HD 4870
ok when I put my old card in it was fine for about 4 hours now it seems to restart between 5 mins and a couple hours. So i thought that maybe some cords r in the fans way, so i shoved all the cards in hard drive slots and hopefully my old graphics card will stop reseting. I also get a blue screen sometimes but its only for 2 seconds and its when my computer is starting up It restarts and i have to shut it down and wait like 10 mins b4 starting up again. After playing with the cords it hasnt happened but idk if this is related to my other problem.
12,453 (1.90/day)
Yankee lost in the Mountains of East TN
Processor 5800x(2)/5700g/5600x/5600g/2700x/1700x/1700
Motherboard MSI B550 Carbon (2)/ MSI z490 Unify/Asus Strix B550-F/MSI B450 Tomahawk (3)
Cooling EK AIO 360 (2)/EK AIO 240, Arctic Cooling Freezer II 280/EVGA CLC 280/Noctua D15/Cryorig M9(2)
Memory 32 GB Ballistix Elite/32 GB TridentZ/16GB Mushkin Redline Black/16 GB Dominator
Video Card(s) Asus Strix RTX3060/EVGA 970(2)/Asus 750 ti/Old Quadros
Storage Samsung 970 EVO M.2 NVMe 500GB/WD Black M.2 NVMe 500GB/Adata 500gb NVMe
Display(s) Acer 1080p 22"/ (3) Samsung 22" 1080p
Case (2) Lian Li Lancool II Mesh/Corsair 4000D /Phanteks Eclipse 500a/Be Quiet Pure Base 500/Bones of HAF
Power Supply EVGA Supernova 850G(2)/EVGA Supernova GT 650w/Phantek Amps 750w/Seasonic Focus 750w
Mouse Generic Black wireless (5)
Keyboard Generic Black wireless (5)
Software Win 10/Ubuntu
Definately not a power issue. I had something like this happen when I tried to run a 2900xt with my monitor. I thought it might be a heat issue, but it ended up being a problem with my monitor firmware. That particular monitor did not like the 2900xt for some reason, and there were several other people who had the same problem. Do you have another monitor you could try with the card?
1,737 (0.24/day)
Canada
System Name death machine
Processor intel 6600 quad core cooled by scythe mutgen 2
Motherboard dfi lanparty UT P35-T2R
Cooling air
Memory crucial ballistic tracer 4 gb
Video Card(s) nvida 260 gtx
Storage segate baracuta 500 GB , western digital blue 1TB
Display(s) asus 23.6 vh242h
Case lian-li pc-a70 full tower
Power Supply 650 watt Antec Earth Watts
Software windows 7 and lots of other titles
try reseating your gpu cooler o and is there any overclocks on your card or did u flash it other then that all i can see is to rma if u can
Seeknay25
18 (0.00/day)
If i HAD to i guess but kinda a last resort
um...what? I'm jus learning little bits here and there about this stuff, so simplify pl0x. And how would I go about reseting my gpu cooler.
12,453 (1.90/day)
You should really switch out your monitors to rule out stuff. I think Dr. meant to try reseating your graphics CARD.
Seeknay25
18 (0.00/day)
But if i try to do anyhting with my new graphics card I dont know if ill have enough time because i usually only get 30 seconds on my desktop, if im lucky and if it doesnt work i have to wait another half hour.
3,051 (0.50/day)
Pontaic Michigan
System Name The Netbook
Processor Intel Atom n270
Memory 1GB DDR2 533mhz
Video Card(s) Intel G945
Storage 250GB
Display(s) 10.1" LCD
Software Microsoft Windows 7 Starter x86
Just a shot in the dark, is the six pin plugged into the card?
Seeknay25
18 (0.00/day)
both the 6pin plugs were connnected. But one thing i meant to ask, do i use the 6pin connectors that came with the graphics card or would it be fine i just used the pcie6pin plugs that were with the psu. I used the psu ones.
3,051 (0.50/day)
Pontaic Michigan
Storage 250GB
You're right using the PSU ones, the ones that came with the card are for if you don't have enough 6-pin connections for the card you have.
Seeknay25
18 (0.00/day)
Wel playing around with the cords and moving them out of the way made it so my computer does freak out with my old graphics card. I wanna put it to the test but the only thing i can try atm is a new monitor. Id like to try more than just that, so i don't have reassemble everything if thats not my problem.
ya that was what i thought
Seeknay25
18 (0.00/day)
Just to save me from finding another monitor. If I can use the monitor for a couple mins and then it shuts down then its clearly not the monitor? I could understand if the monitor never works but it does work for a little. Could the monitor still be the problem?=\
