Noctua NH-D15 and my Ryzen 7 1700X.
trickson
OH, I have such a headache
7,595 (1.03/day)
Planet Earth.
System Name Ryzen TUF.
Processor AMD Ryzen7 3700X
Motherboard Asus TUF X570 Gaming Plus
Cooling Noctua
Memory Gskill RipJaws 3466MHz
Video Card(s) Asus TUF 1650 Super Clocked.
Storage CB 1T M.2 Drive.
Display(s) 73" Soney 4K.
Case Antech LanAir Pro.
Audio Device(s) Denon AVR-S750H
Power Supply Corsair TX750
Mouse Optical
Keyboard K120 Logitech
Software Windows 10 64 bit Home OEM
It has arrived, The Ryzen 7 1700X and I finally mounted (this time with out bricking a CPU.) the Noctua NH-D15. First impression of this cooler?
AMAZING! I haven't yet Over Clocked the CPU just running it stock settings.
Ran Cinabench 20 and was very impressed with the temps I was seeing.
Granted it is not the 1700 I had so my results are going to be very different.
I am going to post test results once I can, get some time. But so far it is doing wonderful!
Did a R15 Extreme run. At stock.
phill
17,212 (3.44/day)
Somerset, UK
Power Supply EVGA 1600W T2
Mouse Corsair thingy
VR HMD No headset yet
I've a 14D on mine, single fan.. Works well but not as well as a Phantek's cooler, a few degrees difference, same room, same air temp etc.. but either way, when under 100% load, they are quiet... With the AMD cooler, it was similar temps but massive noise and that was just too much for me..
I'd love to get some time on clocking them both but I get the impression, that's not going to happen any time soon :(
Toothless
Tech, Games, and TPU!
9,756 (2.45/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x24 Klevv Cras V RGB
Power Supply Corsair HX850
Mouse Corsair Harpoon
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
How would you get "very different results" from the same chip? The difference is literally a small clockspeed bump and an X in the same.
757 (0.35/day)
The 1700X pumps a little more voltage through it than the 1700 to compensate for the higher boost and base clocks. The temps will vary, slightly, but not by any significant amount.
2,963 (0.82/day)
Long Island
The top coolers are so close that secondary considerations will often be the deciding factor. These are our Top 5
1. Scythe Fuma
2. Noctua NH-D15 / D15S
3. Cryorig R1
4. Phanteks PH-TC14PE
5. Noctua NH-D14
The Phanteks aesthetic has many uses shoosing their heat sink for the abodized finishes w/ colors to match the build theme. There's no bad choices in the bunch, it's hard to igniore the Fuma's best performance at half the price combo.
5,717 (0.92/day)
Processor Undead CPU
Motherboard Undead TUF X99
Memory GSkill 128GB DDR4-3000
Display(s) 32'' 4K Dell
Case Fractal Design R5
Audio Device(s) BOSE 2.0
Power Supply Seasonic 850watt
Mouse Logitech Master MX
Software Windows 10 P
Been using D15 for the past ~4yrs. It was good but it is getting old comparing to new air and aio coolers.
trickson
7,595 (1.03/day)
Planet Earth.
Cooling Noctua
Mouse Optical
OH MAN I HAVE TO JUST SAY THIS.
Thank You All so much! To all the wonderful TPU members here I want to thank you for giving me the best air cooler ever!
I am still just Amazed and I haven't even started to OC yet!!!
Um there should be a bit of a difference in temps for sure.
The Ryzen 7 1700 uses less power at stock setting 1.2Volts (Do not know how much voltage is going to be need to OC the 1700X).
This one the 1700X looks like it can crank it's self up to WTF????? 1.5Volts!!! OMG! Yeah so this NEW CPU is going to be fun to OC!
Personally I do not see any way this CPU is going to over heat AT ALL! OMG It is AMAZING.
I have NOTHING to say but good about the new CPU cooler! Just AMAZING! And it looks so sweet too!
Thanks AGAIN TPU you made my entire YEAR~!
hat
Enthusiast
21,750 (3.26/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
Glad you're feeling better about your rig. :toast:
trickson
7,595 (1.03/day)
Planet Earth.
Cooling Noctua
Mouse Optical
truth be known it is only thanks to the help I got here at TPU.
I could not be happier, at all. You eggheads really hit it out of the park this time!
:rockout::respect::clap::lovetpu:
2,207 (0.78/day)
1. Scythe Fuma
3. Cryorig R1
5. Noctua NH-D14
If I was going to buy a D15, I would go for the "S" version & buy the extra fan(s). You never know, you may need that first PCI slot in the future.
freeagent
9,801 (4.17/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
Jeebus, that thing takes take's up a little bit of real estate. Glad you are satisfied. Should be good for a bit now..
trickson
7,595 (1.03/day)
Planet Earth.
Cooling Noctua
Mouse Optical
Yeah looks like Trump Tower went up inside my case.
Can't wait to do some OC on it this weekend.
Preliminary OC run one. Got this so far.
Can you give me you thoughts?
I think the cooler looks great! The CPU Vcore is higher than a 1700 for sure, Power hungry CPU when over clocking.? (Not sure that is the right way to view it).
2,160 (0.33/day)
Metro Manila, Philippines
System Name Zangief (Reborn) 2.0 AM4 not dead yet!
Processor AMD Ryzen R7 5700X3D (tweaked PBO)
Motherboard Gigabyte GA-AX370 Gaming K7 Rev 1.0 BIOS F53d
Cooling Noctua NH-D15 Push / Push Config | 2x ML120 | 2x Phanteks 120 mm
Memory 2x16GB G.Skill Trident Z Neo RGB @ 3600mhz CL 18 -> running 3800mhz @ 1.37v
Video Card(s) Asus RTX 3080 Rog Strix Gaming OC
Storage 250 GB Samsung Evo 850 / 1tb WD Black / 4tb WD Blue / 512GB Adata XPG Pro SX8200
Display(s) Acer Predator XB271HU |Asus VX239H 23" AH-IPS Led
Case Phanteks Enthoo Pro M TG
Audio Device(s) On Board Realtek HD / Steelseries Arctis Nova Pro Wireless
Power Supply Corsair HX750i
Mouse Logitech G903
Keyboard Corsair K70 RGB MK.2 Cherry Browns | Akko 3908N Purple v3 Tactile
Software Windows 11 Pro 24H2
Nice! I rock the same cooler and same chip, but due to temperature (ambient TOO HOT, summer here). I can only push to 3.8-3.9 ghz on all cores @ 1.35v with the LLC on high with a gigabyte x370 K7
Had to push a bit high on the vcore and soc voltage to make it stable (for ram to hit 3200mhz xmp values with a tighter timing).
The NH-D15 can manage the temps.
If you have more time to OC this weekend, find the perfect spot for the cpu, then tweak ram after.
You can use the ryzen ram calculator to get a baseline and experiment from there.
Overall good build! :love: Glad you are loving your new set up :) :toast:
1,701 (0.77/day)
Motherboard MSI X670E Carbon
Cooling MO-RA 3 420
Memory 32GB 6000MHz
Storage 4x 2TB Nvme
Display(s) Samsung G8 OLED
Case Silverstone FT04
Using an U12A on my 1800x
4GHz with 1.41v
Reaching 78c for a R20 run.
The smaller U12A simply can't beat the pure mass giant beast :roll:
Deleted member 24505
Just got a D15 myself on a 1800x, replaced a H100i Gtx which imo was better but noisier.
2,207 (0.78/day)
When overclocking you may want to run something like "Prime95" for at lease 6 hours to confirm stability.
FreedomEclipse
~Technological Technocrat~
24,464 (3.76/day)
Hong Kong
System Name WorkInProgress
Processor AMD 7800X3D
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
Prime95 is out dated. I would much rather use Asus Realbench as it simulates regular usage
hat
Enthusiast
21,750 (3.26/day)
Ohio
Back when I was learning how to overclock. stress tests were never designed to simulate "regular usage". They were designed to simulate extreme situations. That way, your unstable rig doesn't bite you in the ass later because you ran it like that because it didn't crash when you were playing Battlefield 2.
Prime95 w/ AVX is actually quite good for a stability test. It'll look for those pesky errors while running one of the hottest running workloads you'll ever come across. Your average gamer doesn't run programs like that every day, but passing Prime95 and keeping temps under control is a pretty good indication that your rig won't fail unexpectedly. But one test isn't enough. That's why when I'm working on a rock solid overclock, I'll actually start with bootable Linpack Xtreme, then, if it passes that, I'll run Prime95 for at least 12 hours, preferably 24.
757 (0.35/day)
The only thing that bothers me about that fan orientation is the fact that I’d rather have the second fan on the other side of the heat sink to push air through it more efficiently. That’s just personal preference, though. Makes next to no difference from a performance aspect.
521 (0.20/day)
Dang this thing is a beast. It's so beautiful too. Very impressive. I bought one for my friend about 7 years ago and his mobo is now permanently bended because of the weight of this cooler.
2,207 (0.78/day)
There's another program call "Intel Burn Test". I'v never tested it or seen it running, but it's another good program from what I have read in forums.
My first choice will always be Prime95. (personal perference).
461 (0.21/day)
Western NY, USA
Processor AMD Ryzen 7 3700x
Cooling Scythe Ninja 5
Memory G.Skill Ripjaws V 16GB (2 x 8GB) (F4-3600C16D-16GVKC) @ 3733 MHz 16-19-19-19-36-56
Video Card(s) MSI RTX 2060 Super Armor OC 8GB
Storage 1x Samsung 970 EVO 500GB / 3x Crucial MX500 / 4 HDDs
Display(s) Dell 23" LCD S2316M
Case Rosewill Rise Glow
Power Supply CORSAIR RM650
Mouse Cooler Master MS120
Keyboard Cooler Master MS120
That thing is a Monster !!!!!!!!!!!
It makes my Arctic 33 Esports cooler look compact. LOL
I'm glad to hear you are happy with it.
Have fun OC-ing that 1700X.
trickson
7,595 (1.03/day)
Planet Earth.
Cooling Noctua
Mouse Optical
Actually I only did this so I can see my sweet RAM! The fan blocks the lights LOL and really there is no diffrence in performance at all, Air is still flowing the way it should.
Yes it is, I remember a Turnq Tower 112 that I had, It was just like this a MONSTER!
I must say the thing is an absolute dream come true, I think I am going to get 3 more of them for the other systems.
I recommend this Cooler to EVERYONE! This cooler fits in a MID tower case PERFECTLY!
Why I did not just get this thing in the past is beyond my 2 brain cells. Man this thing is really amazing and quiet very silent in fact I have it set to just that the fans don't even come on till it hit 50c! LOL! Haven't even hit that gaming!
7,104 (1.01/day)
USA
Case Lian Li O11 Air Mini
Mouse Zowie EC3-C
Software Win 10 LTSC 21H2
Wow, but mobo still works right?
21,785 (3.41/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Memory 128GB (4x 32GB) G.Skill Flare X5 @ DDR5-4000 (Running 1:1:1 to FCLK)
Case Thermaltake Core X31
Software Windows 11 Enterprise
Outdated? No. It was updated just this month and supports all the latest instructions. Realbench is probably more dated.
Unrealistic, now? Maybe... It's true no game will generate a small FFTs grade heat load.
