Noctua NH-D15 Heatsink/Fan Will Fit
250 (0.16/day)
Texass
System Name 1.EXTREME-FLIGHT SIM//2.LIAN-LI/HOME
Processor 1.AMD RYZEN 7 9800X3D 4.7GHZ 8-core 120W
Motherboard 1.ASUS ROG X670E Crosshair EXTREME BIOS V.2403
Cooling 1.be quiet! Silent Loop 2 360MM
Memory 1.G. SKILL Trident Z5 RGB 32MBx2 DDR5-6000 CL32/EXPOⅡ
Video Card(s) 1. ASUS ROG Strix RTX4090 O24
Storage 1.2TB CRUCIAL T705 M.2, 4TB Seagate FireCuda 3.5"x7200rpm
Display(s) 1.Samsung Odyssey Neo G9 57" 5120x1440 120Hz DP2.1
Case 1.be quiet! Dark Base Pro 900 Rev.2
Audio Device(s) 1.ROG SupremeFX ALC4082
Power Supply 1.be quiet! Dark Power Pro 12 1500W
Mouse 1.LOGITECH Pro Superlight2
Keyboard 1.CORSAIR K100 AIR
Software 1.WINDOWS 11 x64 PRO 23H2, MSFS2020, DCS
On an ASUS TUF Gaming x570-Plus motherboard with 128GB of G.Skill Trident Z RGB Memory in a Corsair 450D case. Swapped the front 140MM Noctua fan with a be quiet 120MM fan. The rubber mounting grommets made it simple using the supplied fan clips. Also installed a front grille. Looks good in spite of different fans and is quiet.
4,578 (0.93/day)
in a van down by the river
Cooling frostier than yours
Storage more ample than yours
Case fancier than yours
Benchmark Scores up yours
looks good
FreedomEclipse
~Technological Technocrat~
24,044 (3.74/day)
London,UK
System Name DarnGosh Edition
Processor AMD 7800X3D
Memory G.Skill Trident Z5 NEO DDR5 6000 CL32-38-38-96
Storage WD SN770 1TB (Boot)| 2x 2TB WD SN770 (Gaming)| 2x 2TB Crucial BX500| 2x 3TB Toshiba DT01ACA300
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
you should do a before and after test to see if it was worth it.
I have a Bequiet DRP4 and a lot of folks say it runs just fine with just the 135mm centerfan.
250 (0.16/day)
Texass
Nice cooler, but can i ask why 128gb of ram?
'Cause I can. Waiting to get more memory in the future, that matches, is often difficult.
250 (0.16/day)
Texass
So 128gb of ram with only a gtx 1650, i guess you don't game much. 32 with a better GPU would have been better, but your cash i guess.
Waiting for ASUS TUF RTX 3080 or 3090 GPU to finish the project for MS Flight Sim 2020. Also waiting for Flight yoke, throttle quadrant and rudder pedals.
7,254 (1.03/day)
Video Card(s) Asus GeForce RTX™ 4070 Dual OC (Waiting on RX 8800 XT) | Intel® Iris® Xe Graphics
250 (0.16/day)
Texass
