- Jan 3, 2015
- 2,989 (0.84/day)
System Name | The beast and the little runt. |
Processor | Ryzen 5 5600X - Ryzen 9 5950X |
Motherboard | ASUS ROG STRIX B550-I GAMING - ASUS ROG Crosshair VIII Dark Hero X570 |
Cooling | Noctua NH-L9x65 SE-AM4a - NH-D15 chromax.black with IPPC Industrial 3000 RPM 120/140 MM fans. |
Memory | G.SKILL TRIDENT Z ROYAL GOLD/SILVER 32 GB (2 x 16 GB and 4 x 8 GB) 3600 MHz CL14-15-15-35 1.45 volts |
Video Card(s) | GIGABYTE RTX 4060 OC LOW PROFILE - GIGABYTE RTX 4090 GAMING OC |
Storage | Samsung 980 PRO 1 TB + 2 TB - Samsung 870 EVO 4 TB - 2 x WD RED PRO 16 GB + WD ULTRASTAR 22 TB |
Display(s) | Asus 27" TUF VG27AQL1A and a Dell 24" for dual setup |
Case | Phanteks Enthoo 719/LUXE 2 BLACK |
Audio Device(s) | Onboard on both boards |
Power Supply | Phanteks Revolt X 1200W |
Mouse | Logitech G903 Lightspeed Wireless Gaming Mouse |
Keyboard | Logitech G910 Orion Spectrum |
Software | WINDOWS 10 PRO 64 BITS on both systems |
Benchmark Scores | Se more about my 2 in 1 system here: kortlink.dk/2ca4x |
Just a simple question to ask.
Does any one use a noctua nh-l9x65 se-am4 cooler on a Ryzen 5 5600X or similar cpu and can tell me about temperature or if it is even a feasible achievement?
It's because I will put it in a asus b550 strix mini-itx baord with a limited space between cooler and a vertical mounted gpu. Hence I am cooler size limited. But it also seems despite 5600X is a 65 watt tdp cpu, it can run quite hot.
