Noctua NH-U14S, looking for fan
1,246 (0.19/day)
Repentigny, QC, CANADA
System Name CTG Computer
Processor AMD Ryzen 5 7600
Motherboard Asrock B650M PRO RS WIFI
Cooling Thermalright PA120 SE
Memory 2x 16gb G.SKILL F5-6000J3038F16GX2-FX5
Video Card(s) Gigabyte RX6800XT Gaming OC
Storage WD Black SN850X 2TB
Display(s) MAG274QRF-QD | Asus vg248qe
Case SAMA IM01
Audio Device(s) Creative SoundBlasterx G6
Power Supply Corsair SF750
Mouse Logitech G pro Wireless
Keyboard Corsair Strafe RGB MK2
Software Windows 11 Pro x64
Hey guys,
I might sell my NH-U12S to my bro so he can have a quiet cooler vs his stock intel. I don't like very big CPU cooler, so I stopped on the Noctua NH-U14S (or if anyone has something to share, but I do not want any AIO)
Stock fan is ugly (yep, I prefer black fans). I'm looking for a silent and good performer fan. I saw the Fractal HP-14 PWM, looks not bad at all.
To compare, my U12S has a Fractal Dynamic X2 GP-12 PWM.
Thanks for any advice
FreedomEclipse
~Technological Technocrat~
24,628 (3.76/day)
(currently) Hong Kong
System Name WorkInProgress
Processor AMD 7800X3D
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
Noctua Redux stuff is pretty good.
7,889 (3.31/day)
California
System Name His & Hers
Storage lots of SSD.
I prefer the ML 120/140 pros. I have a couple Noctua NF-A14 chromax fans but I'm not overly impressed and plan on swapping them for MLs at some point.
I also like the silent wings 3 but they are not ideal In my experiences for pushing air through a fin stack.
You may just want to grab a chromax cooler instead and not have to deal with swapping the fan
Performance difference is pretty negligible and it probably ends up cheaper since you don't have to swap the fan.
5,717 (0.92/day)
Processor Undead CPU
Motherboard Undead TUF X99
Memory GSkill 128GB DDR4-3000
Display(s) 32'' 4K Dell
Case Fractal Design R5
Audio Device(s) BOSE 2.0
Power Supply Seasonic 850watt
Mouse Logitech Master MX
Software Windows 10 P
EK-Vardar EVO 140ER Black BB
23,539 (6.13/day)
The Fractal you saw is a very good one. Can also vouch for BeQuiet SilentWings.
1,246 (0.19/day)
Case SAMA IM01
Right now, the chromax on newegg.ca Is like 109$ + 10$ shipping, not available on amazon.ca with prime or anything at a good price :( The NH-U14S is like 98$, so buying another fan cost me the same thing, except I have a 140mm instead.
Those Corsair are quiet?
7,889 (3.31/day)
California
They are up to about 1200 rpm and perform pretty well, at 1500 rpm you definitely hear the air movement from them, and at 2000 rpm they are usable with headphones lol.... I prefer them over the noctua chromax fans when it comes to noise profile.
They make less noise than my overclocked 2080 ti strix although the fan profile I have set up for it keep it under 69c... I cap my ML at 1500 rpm under heavy load but they sit at 600 rpm when my system is idle or I'm web browsing etc.
I use a corsair commander pro though so I have complete control over what my fans are doing at all times and don't have to rely on my bios doing its job.
If silence is you number one goal the silentwing 3 would be better but the MLs perform better in my experience as either case fans or pushing air through a radiator/fin stack
Ruru
S.T.A.R.S.
13,559 (3.03/day)
Jyväskylä, Finland
VR HMD Oculus Rift CV1
Here in Finland Arctic P12's have became pretty popular as they are cheap AND good.
1,015 (0.19/day)
Processor Intel Core i5 8400
Cooling Silverstone AR05
Display(s) Dell U2415
Case Silverstone RVZ02B
Keyboard Ducky One Red Switch
Software Windows 10 Pro 1909
I've had pleasant experiences with Arctic P series and Silverstone Air Penetrators
1,246 (0.19/day)
Case SAMA IM01
Thanks for all the input. I have ordered hose artic P14, they looks.not bad, at a low price.
If not okay, silent wings will be tested or ml pro. If again not enought, I'll give another go at the fractal, since I can get it for 19$.
I think i will have to rma my u12s aswell, just saw a chip under the heatsink. It makes a spot on the cpu when I remove it (like if it was doing a bad contact)
1,246 (0.19/day)
Case SAMA IM01
Received the noctua. It's quite huge vs the U12S, tight fit with GPU .
Silent vs a 120mm fan, worth it. 2-3C less at full load, with high vcore. That artic is not bad at all
1,246 (0.19/day)
Case SAMA IM01
ended adding a second arctic, they are totally silent, and push a good amount of air, for the silence at full speed. Plus, the static pressure is very nice. The thickness is a little bit more than a fractal 140mm. But for the price, you can't go wrong.
WOW
dgianstefani
TPU Proofreader
5,348 (2.03/day)
Swansea, Wales
Processor Ryzen 9800X3D @ 5.5ghz all core 1.2 V, Thermal Grizzly AM5 High Performance Heatspreader/1185 G7
Benchmark Scores Legendary
Noctua NF A12x25 is the best 120mm fan on the market. Outperforms some 140mm fans in both airflow and noise.
Regeneration
NGOHQ.COM
3,148 (0.44/day)
Buy a loud, hi-perf, hi-airflow fan and use the BIOS' smart fan feature to keep it quiet.
Should only be loud when stress testing.
Corsair AF, Scythe Ultra Kaze, Noctua NF, or anything else with PWM and 100 m3/h and above.
Noctua NH-U1x series aren't that awesome. NH-D series are a lot better.
dgianstefani
TPU Proofreader
5,348 (2.03/day)
Swansea, Wales
The NH-U12A is within 5% of the performance of the NH-D15, while being smaller and quieter.
Regeneration
NGOHQ.COM
3,148 (0.44/day)
Not when used with hi-airflow fans, the difference between the two gets bigger. Stock Noctua 2500 RPM fans are bad.
dgianstefani
TPU Proofreader
5,348 (2.03/day)
Swansea, Wales
Why would you use high RPM fans on a cooler designed to be extremely quiet? My NH-U12A cools a 3900x at load whisper quiet and a 8700k OC'd to 5.3ghz. It comes preinstalled with the NH-A12x25 which, once again, is arguably by most metrics the best 120mm fan.
If you want your PC to sound like a vacuum cleaner so you can get the extra 15% cooling that twice the airflow gives you - go right ahead.
Regeneration
NGOHQ.COM
3,148 (0.44/day)
Most modern motherboards do a good job controlling the fan speed via PWM according to the CPU Tjunction temperature.
If adjust properly, you won't hear it unless you run a stress test app or long period encoding. That's the best balance between performance and acoustics.
1,246 (0.19/day)
Case SAMA IM01
Since I use also the CPU at 100% for World Community Grid, I like when the computer is still quiet.
All my fans are PWM. I'm always searching for best Performance/noise ratio.
As for NH-D, yeah they are nice, but too big. I don't like them, I find them ugly. My U12S served me well, 2700k @ 4.6ghz, tested a 5.1ghz run, 4770k @ 4.5ghz, Ryzen 1700, 2600x and my 3600x. changed to U14S, because I give my 12S to my bro.
dgianstefani
TPU Proofreader
5,348 (2.03/day)
Swansea, Wales
If you're buying high RPM fans then using the mobo to keep them at low RPM - it's an oxymoron - no point to buying high RPM fans.
Regeneration
NGOHQ.COM
3,148 (0.44/day)
That's the way to maintain high OC.
Most graphic cards have loud, high RPM fans that you'll only hear on a rare occasion.
There are just a few tasks that'll push a CPU to it's limits.
hdtvguy
9 (0.01/day)
So I just built 2 Ryzen 9 3900X systems and each got a new NH-U14S. I added a second NF15A and I run both fans at full speed. The second fan had a noticeable whine that appeared to be probably from the fan trying to pull air through the fins. I figured I would buy a Redux 120mm 1700rpm fan for the second fan and with that at full speed I really no longer hear a whine. It got me thinking. The Redux 120mm 1700rpm fan has only slightly better air movement than the stock NF15A, but the big difference is the Redux 120mm has a substantially higher static pressure which for me thinking it would move more air through the radiator fins than the stock fan. So I got more Redux fans and now run the Redux 120mm 1700rpm fans as primary and secondary on the NH-U14S and to my surprise the temps are down about 2C under max load and same at low idle load. That and swapping out the Noctua paste for Artic MX4 gained me about 3-4C overall improvements in load and idle temps. Before I would run all course at 4.1GHz and get temps around 75-76C for 20 minutes. Now same test tops out around 71-72C and ideas in the mid 35-39C or lower at times. Sure there is no overall difference in CPU performance and both before and after are 20C below thermal limits, but keeping CPU as cool as possible means less abuse to CPU and hopefully longer life.
2,062 (0.35/day)
Volos, Greece
System Name ATLAS
Display(s) DELL U2311H
Keyboard Microsoft Wired 600
This is a very wise question, especially for 14 PWM fan the reasonable top rpm this should not be more than 1300.
Additionally some models of the GELID PWM fans they have also fixed low rpm speed (20% PWM) at about 700 rpm.
Therefore it makes sense obtaining such a fan which can do 700~1300 rpm.
