[Solved] Noob question again: Will these 6+2 pins work on an 8 + 6 pin gpu, or?
645 (0.11/day)
Norway, which means Amazon is not available...
System Name Winter v3.2024
Processor Intel i7 12700K (since november 2021)
Motherboard Gigabyte Z690 Gaming X (since november 2021)
Cooling Air Liquid Freezer II 360 with LGA1700 kit (since november 2021)
Memory Crucial Ballistix 2x16gb 3600mhz C16 (since november 2021)
Video Card(s) Gigabyte RTX 3060 Ti Gaming OC Pro LHR - Rev3.0 (since july 2022)
Storage 1x 1TB WD Blue SN570 SSD, 1x Seagate 4TB SATA
Display(s) 1x 55" LG C1 4k OLED, 1x Gigabyte 32" M32Q and 2x AOC 27" CG1
Case Fractal Design Define R6 (since 2018 and still working like a charm!)
Power Supply Corsair RM850x black (since august 2022)
Mouse Razor Deathadder v2 (since december 2021)
Keyboard Varmilo VEA109 v2 MX Silent Red (since august 2022)
See picture below. I used this cable for my 970 ti, which had 6 + 6 pin setup. But now i am trying to connect a 3060 ti, which has 8 + 6... but as you can see, this cable does have 2 additional pins that would add 8 to one side and 6 to the other, which is already plugged in... will this work or do i need a different cable..?
Pardon for another noob question but i hope someone can help/advise me on this.
Edit: Well, the 2 pin definitely fit into the place, as you can see. Is it good to go now or..?
18,584 (2.67/day)
System Name AlderLake
Edit: You need a better PSU "EVGA SuperNOVA G3 550W (for now...)", isn't good enough for your hardware.
You should be fine with that, I have a 2070 Super with 8+8 pin one cable connected, no issues, I have a 750 Watt PSU though.
Just be sure your PSU can handle your latest upgrades.
5,974 (0.82/day)
Ikenai borderline!
System Name Firelance.
Processor Threadripper 3960X
Mouse Logitech G604
Keyboard Razer Pro Type Ultra
It's fine, but the minimum recommended PSU for a 3060 Ti is 600W. Your 12700K is probably already pushing that a bit.
18,584 (2.67/day)
It's fine, but the minimum recommended PSU for a 2070 SUPER is 650W.
OP has a 3060Ti, but yes he needs a new PSU with that setup.
The "EVGA 550 (for now)" doesn't cut it.
43,439 (6.76/day)
Yeah thats a run of mill unit those specs are basted upon, garbage units are overrated, high end units are underrated.
5,974 (0.82/day)
Ikenai borderline!
Mouse Logitech G604
Urgh, read your card as his card. Fixed, thanks.
4,824 (0.97/day)
in a van down by the river
Cooling frostier than yours
Storage more ample than yours
Case fancier than yours
Benchmark Scores up yours
gaming wise he should be around 375w and can hit 475w at load. The PSU can handle it although the fan noise from the PSU may be bothersome to the OP. If it was me I would use the PSU for now while ordering a new one (or saving up for one) since I hate fan noise.
645 (0.11/day)
Alright. It did work to just do as i initially thought. Thanks for the advises anyways!
Hmmm, is that so? In that case, perhaps you lot can suggest me a new PSU in this thread then? I'd greatly appreciate that! I am a bit lost in the world of PSU, so some pointers there would be nice.
