Northbridge cooler
MadCow
544 (0.09/day)
Processor Athlon 64 X2 4400+ @2.6 GHz
Motherboard DFI LanParty UT CFX3200
Cooling 120mm Yate Loon fan intake, 82mm ex-PSU fan exhaust
Memory 2048 mb. of cheap DDR400 RAM w/cheap heatspreaders
Video Card(s) Sapphire+HIS X1950 PRO, Crossfired@635/709
Storage WD 250 GB SATA
Display(s) Samsung 216BW
Case No-name ATX case (modded to hell)
Audio Device(s) SB X-FI OEM
Power Supply Nikao Cool Power 500W (34a@12v)
Software Windows XP PRO SP2
I'm looking for a passive RD580 northbridge cooler for my DFI board. It has the push-pin style mounting method. The problem is, it's a really tight fit because DFI put it right between the PCI-E slots and the back of the Accelero X2 on my HIS card is really close to it. Here's a picture to show you what I mean:
Will the passive Zalman coolers possibly fit? I don't care if I need to cut off a fin or two, that's no problem. And yes, that's not the stock cooler, but it's still too loud for my tastes, especailly since I had to up the NB voltage a bit.
sneekypeet
Retired Super Moderator
29,441 (4.38/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
I had 7600'in SLI on mine(SLI-DR)...second card ran close and rubbed that exact cooler. made about 2*C difference on my NB.
Just keep an eye on the NB tamps and you should be able to easily see if its an issue or not!
265 (0.04/day)
Anaheim, California
Processor i9 9900k
Motherboard MSI MPG Z390 Gaming Plus
Cooling Corsair H105
Memory G Skil Trident Z DDR4 4266
Video Card(s) RTX 3090Ti
Storage WD Black 500gb nvme, Sabrent 2tb nvme
Display(s) Viotek GNV34DBE2, Viotek SUW49DA
Case Hyte Y60
Power Supply EVGA Supernova G3 750w
Mouse Glorious Model O
Keyboard KBDFans Odin V2
Software W10 x64
367 (0.06/day)
Processor Intel E8400 @ 3.6ghz (1.25v)
Motherboard Evga 680i SLI
Cooling ASUS Arctic Square
Memory 4GB GSKILL PI Black (2x2GB) 4-4-4-12 @ 1.8v
Video Card(s) EVGA GTX 275 Superclocked
Storage WD 320GB (B3 revision)/WD 160GB
Display(s) Acer X241W
Power Supply PC Power and Cooling Silencer 750w
How does it plug in to the mobo? If it plugs into a fan slot, you may be able to adjust its speed using Speedfan if you wish. Mine did on my old mobo, that's why I was wondering.
Wouldn't lower it too much though, as heat could build up.
MadCow
544 (0.09/day)
It idles at 46 and goes all the way up to around 65 under load, and when it hits that temp it gets really loud. I can lower it but it gets too hot. That enzotech cooler looks too small.
sneekypeet
29,441 (4.38/day)
System Name EVA-01
65*C under load seems way high TBH. IIRC the SLI-DR neve topped 55*C with SLI and 3.0GHz/300FSB on my Opty170!
I also ran my fan at full 100% in BIOS by temps and made sure using Smart Guardian to keep it there. Noise for performance is why people go water!
MadCow
544 (0.09/day)
Well I don't have the money for that, and I can't stand noise, so I'm kinda screwed. :laugh:
sneekypeet
29,441 (4.38/day)
System Name EVA-01
I didnt mean you had to go water....IIRC that chip isnt supposed to pop until around 80*C so you are OKish. I just dealt with the fan to have the cooler NB, which allowed me to clock further.
I did lap the bottom of mine tho as it isnt very flat from casting.
18,541 (2.72/day)
System Name AlderLake
HTC
4,650 (0.78/day)
Portugal
System Name HTC's System
Processor Ryzen 5 5800X3D
Motherboard Asrock Taichi X370
Cooling NH-C14, with the AM4 mounting kit
Memory G.Skill Kit 16GB DDR4 F4 - 3200 C16D - 16 GTZB
Video Card(s) Sapphire Pulse 6600 8 GB
Storage 1 Samsung NVMe 960 EVO 250 GB + 1 3.5" Seagate IronWolf Pro 6TB 7200RPM 256MB SATA III
Display(s) LG 27UD58
Case Fractal Design Define R6 USB-C
Power Supply Corsair TX 850M 80+ Gold
Mouse Razer Deathadder Elite
Software Ubuntu 20.04.6 LTS
You could consider this one: NC-U6 from Noctua!
The review has pics with it mounted: check it!
18,541 (2.72/day)
"Room temperature was ~19°C during testing, no noise levels were recorded since both the standard Asus cooling and the Noctua NC-U 6 work completely passive. "
"We did not mount a fan directly on the NC-U 6 but did a second test with the case fans running at high speed, the extra airflow gave the Noctua cooler a 2°C lead over the stock cooling."
From http://www.madshrimps.be/?action=getarticle&articID=528
Ok we mentioned some nice heatsinks here, but it simply will not fit in MadCow's system.
But a http://www.thermaltake.com/product/Cooler/VGAnCHIPnMEM/cl-c0034/cl-c0034.asp might fit?:)
Or a Thermaltake "Tiger 1"..
Hmm, you sure have not much space left there..
HTC
4,650 (0.78/day)
Portugal
How about this review?
MadCow
544 (0.09/day)
I don't need something massive like that. The RD580 is a cool running chip, nothing like Intel northbridges.
1,192 (0.19/day)
scotland
System Name spuds K8-X2
Processor amd athlon X2 4200+ toledo s939 2794mhz 254x11 1.4 vcore
Motherboard MSI K8N Neo4-F v1.0 (MS-7125) nforce4 sata2 mod, laptop cpu heatpipe copper nb cooler
Cooling akasa evo "blue" + 90mm fan, 2x120mm front, 250mm side, 120mm rear, 120mm in psu, pci slot exhaust.
Memory OCZ Platinum XTC DDR PC3200 4GB(4x1024) @254mhz 3-3-3-8 2T
Video Card(s) sapphire HD3870 512mb GDDR4 vf900cu, several ramsinks on components / nvidia 7300gt 256mb secondary
Storage hitachi 160gb (slightly fried) / hitachi 120gb ATA / Seagate 160gb / 2x ps3 seagate 60gb
Display(s) CTX EX1300F 20" flat CRT, 1280x1024@100hz / 19" benq FP91G X / 19" hanns-g (all free)
Case mesh server/gaming black case, 9x 5.25' drive bays, silvestone auto fan controller
Audio Device(s) onboard realtek alc850 7.1/soundblaster LIVE! ct4780 + kxaudio - sony home theatre surround
Power Supply winpower 650w, system draws around 470-500w under load(+all screens)
Software win7 64bit
Benchmark Scores ~16m trips/sec using mty trip generator. triple monitor gaming using SoftTH. 3840x1024
i had a similar prob with my nb, still managed to make a zalman fit with the help of a vice hehe,
echo75
456 (0.08/day)
Denmark
System Name Main
Processor Q6700 @ 3.5Ghz (with 1.50 Vcore)
Motherboard P5K
Cooling Xigmatek HDT S1283 (amazing performance)
Memory Corsair 800mhz 4GB @ 864mhz
Video Card(s) Asus 8800GT@ 720/1800/2100,blue Pcb with 92cm Glaciator cooler(4870 still under testing)
Storage Seagate 250GB SATA , 500GB eSATA
Display(s) LG Flatron 19"
Case Antec Designer (modded)
Power Supply Corsair VX 550W
Software Win XP Pro SP2
Benchmark Scores 3Dmark06 = 15,253 for 8800GT, 3Dmark06 = 15,807 for HD 4870
Eclecticos
96 (0.02/day)
Florida
I made a cube out of plexiglass
. .and cut out the area for a heatsink on the bottom and installed a fan on top.
Id recommend cutting out air slots if you choose to try this out.
Its an old picture, but a northbridge cooler none the less.
spearman914
3,338 (0.56/day)
Brooklyn, New York 11223
System Name Mine | Dad + Mom
Processor E8500 E0 Wolfdale @ 4.6GHz 1.5V | E2180 M0 Allendale @ 3.0GHz 1.3V
Motherboard Asus Maximus Formula (X48) w/ Rampage BIOS | Asus P5Q Pro (P45)
Cooling Xigmatek Rifle HDT-S1283 w/ SFF21F Fan | Arctic Cooling Freezer 7 Pro
Memory G.Skill Pi Black 2x2GB 1.02GHz CL5 | OCZ Reaper 2x2GB 1.05GHz CL5
Video Card(s) Sapphire 4870X2 2GB 820/1020MHz | Sapphire 4850 1GB 700/1100MHz
Storage WD VR 150GB 10K RPM + WD 500GB 7.2K RPM | WD 200GB 7.2K RPM
Display(s) Acer P243WAID 24" 1920x1200 LCD | Acer V193W 19" 1440x900 LCD
Case Cooler Master HAF 932 Full-Tower | Antec Twelve Hundred Mid-Tower
Audio Device(s) Fatal1ty Xtreme Gamer w/ Z-5500 5.1 | On-Board Audio w/ S-220 2.1
Power Supply PC Power and Cooling 750W Non-Modular | Corsair HX-520W Modular
Software Windows Vista Home Premium X64 | Windows Vista Home Premium X64
Benchmark Scores Not Wasting Time!
MadCow
544 (0.09/day)
Again, space is the main issue here, it's right between the 2 video cards and right under a double slot cooler. I think I'm just gonna buy a Zalman and cut/bend the fins to fit.
sneekypeet
29,441 (4.38/day)
System Name EVA-01
5,250 (0.88/day)
IRAQ-Baghdad
System Name MASTER
Cooling Corsair H100i
Video Card(s) 2X EVGA GTX680
Case CoolerMaster Chosmos II
Software Win7 64bit Ultimate
tkpenalty i see you like this cooler do you try it cuz i want one but i think in water
