Not enough space on flash drive
fullinfusion
Vanguard Beta Tester
9,909 (1.58/day)
I have an ADATA 16GB usb 3.0 thumb drive that when formatted it's showing 14.6GB in size.
I cant copy a movie to it, says not enough space, what gives?
588 (0.08/day)
System Name Blue Beast 2.0
Processor AMD Ryzen 9 3900XT
Motherboard Gigabyte X570 AORUS MASTER
Cooling EK EK-AIO 360 D-RGB
Memory G.Skill Trident Z Neo 32 GB (2 x 16 GB) DDR4-3600 CL16
Video Card(s) EVGA RTX 3090 Ultra Gaming Hybrid
Storage Seagate FireCuda 520 500GB NVME, Western Digital SN750 1TB NVME, Western Digital SN850 1TB NVME
Display(s) AOC AG271QG, Dell UltraSharp U2414H
Case Lian Li PC-O11 Dynamic - Black
Audio Device(s) Asus Xonar DGX PCI-E 5.1
Power Supply Corsair HX850i
Mouse Logitech G502 HERO
Keyboard Corsair Strafe MK.2 Cherry MX Silent
Is it formatted to FAT32? If so format it to NTFS and copy it. FAT32 has a limit of 4GB file sizes.
907 (0.12/day)
La Quinta, CA
System Name The Shroomiest One!
Processor AMD Ryzen 9 5950x
Motherboard ASRock x570 Taichi
Memory 2x16gb T-Create Expert 3600C14
Video Card(s) NVidia RTX 3090 Founder Edition
Storage WD_BLACK SN850X 2tb, 2 x Team Group MP34 4tb
Display(s) LG 34GP83A-B
Case Meshify 2 XL
Audio Device(s) EVGA NuAudio
Power Supply EVGA 1000w Supernova
Mouse Glorious Model D
Keyboard Glorious GMMK Pro
VR HMD Valve Index
that actually is 16gb. just like hard drives when you buy a 500 gb you are only really getting like 478gb or something like that.
3,051 (0.60/day)
System Name The SwagMachine / The Sister
Processor Core i5 3570K @5.2ghz 1.3V/ 1100T
Motherboard ASUS P8Z77-V / ASUS M5A99X EVO
Cooling Phanteks PH TC14PE / Corsair H40
Memory M379B5273DH0-YK0 2X4GB + PVI316G213C1QK 2X4GB / 2x4GB Patriot 2133
Video Card(s) PNY 780Ti /Windforce 7950
Storage 2xSamsung 840 EVO 250gb+WD10EZEX + WD30EZRX/ 1x WD1500 Black
Display(s) AOC Q2963PM+Acer S200HL / Acer S200L+ LG 22LD350
Case Fractal Define R4 / NZXT Trinity
Audio Device(s) Asus Xonar DG / Asus Xonar DG
Power Supply Seasonic 750X / ROSEWILL RG630-S12 630W R
Mouse Razer Deathadder Chroma / Roccat Kone+
Keyboard Razer Blackwidow 2013 Stealth / Roccat Isku
Software Windows 8.1 Pro / Windows 7 Ultimate
Benchmark Scores one time I scored a 3 on 3dmark 11
^ What he said. Right click on it then click on format
fullinfusion
9,909 (1.58/day)
Yup FAT32, NTFS is working just fine and thank you!
Whats the deal with fat32 and ntfs? anything I should know?
3,051 (0.60/day)
Aquinus
Resident Wat-man
13,191 (2.74/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Software MacOS 15.3.1
It's just how the files are stored. FAT32 is an older standard with NTFS(5) being a newer one.
"No one will ever need more than 64k of memory!"
Clearly this is why we're not using 16-bit anymore. :p
588 (0.08/day)
No problem man.
Just like Kevinheraiz and Aquinus said, it's an older standard and and transfers data faster at lower capacities. Afaik it's also compatible with more OS's than NTFS.
brandonwh64
19,542 (3.44/day)
Here explains it quite well
FAT32
The original File Allocation Table (FAT) file system was introduced in 1977 and generally applied to floppy disk storage. It was later modified to work with hard disks and other removable media. FAT had a problem however; it could only manage spaces up to 2GB in size. As Windows came into being and programs became larger, the 2GB barrier became a serious problem. Thus, in 1996, with the OEM Service Release 2 (OSR2) of Windows 95 (also known as Windows 95b) came a FAT enhancement known as FAT32.
The two major features of FAT32 that improved upon the original FAT (or FAT16 as it's sometimes known) are the disk efficiency and size of the disk supported.
Files are stored in clusters on the disk. The size of the clusters depends on the size of disk. Under FAT, drives over 1.2GB used clusters that were 32K in size as the file allocation table itself could not track more clusters because of it's 16-bit structure. The 32-bit structure in FAT32 allows disks of that size to use 4K per sector. This improves efficiency as a file, no matter how small, will always use at least one cluster and the space in the cluster not used is wasted. FAT32 doesn't start to use 32K clusters until the disk goes over 60GB in size and can handle disks up to 2TB (terabyte or trillion bytes); though not all operating systems can deal with disks that size even if the file system can.
There are many other features changed between the two but these are the major ones to be concerned with.
The problem that many encounter now is one of the limits of FAT32 that's being run into: file size. The original FAT (FAT12) had a maximum file size of 32MB, FAT16 has a maximum file size of 2GB, and despite the much larger hard disk size supported by FAT32, the maximum file size only doubled to 4GB.
This is largely why a movie file larger than 4GB in size might not be able to be copied to a hard disk with lots of space. The hard disk is probably formatted using FAT32. There is no quick solution short of converting the hard disk to the NTFS file system.
Source
9,921 (1.81/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
143 (0.03/day)
Germany
System Name Blackbox
Processor Core i7-2600k @ 4.8
Motherboard ASRock Fatal1ty P67 Performance
Cooling Thermalright Macho Rev.A
Memory 32GB Crucial Ballistix Sport VLP DDR3-1600
Video Card(s) KFA² (Galax) GTX970 EXOC Black Edition
Storage Bunch of 1-2TB WD RE4 + WD Red
Display(s) Samsung Syncmaster 2333T
Case Fractal Design Arc Midi
Power Supply Seasonic S12 II 430
Mouse Logitech MX518 Refresh
Keyboard Tesoro Colada G3NL (MX Brown)
Software Win7 Ultimate
On USB sticks:
If you need to store big (over 4GB) files -> NTFS
If you need guaranteed compatibility with older machines and other OS's -> FAT32
FAT32 is far more compatible, but has several limitations, one being the max. filesize of 4GB.
NTFS supports large files and lots of other features like compression, but may not be easily usable on all machines (older ones or ones using other/obscure operating systems with no or just partial NTFS support)
exFAT was supposed to be a compromise between the two, but it's pretty much a total flop due to even worse compatibility (Vista only since SP1, XP only with an extra patch, ...)
