- Apr 2, 2023
- 108 (0.13/day)
Processor | AMD Ryzen 5 5600G |
Case | NX |
Mouse | Razer Viper 8khz, |
Keyboard | Rapoo |
Greetings!
I need your help because for some reason the game doesn't want to be smooth, I changed everything from my computer, put in a processor, motherboard, video card, ssd, changed rams, changed monitors.
For some reason There used to be one https://www.backoffice.be/prod_uk/P...illiance_109p20_display_crt_19_dquote_192.asp
with this, the game was very smooth until this monitor died, after that it was a TV monitor, but because of the input lag I had to change a Acer GN246HLBbid UM.FG6EE.B06 144hz monitor, and I thought the game would be smooth, and it really could be smoother, somehow I felt as if it was even smoother, then about 1 hour passed and I played and the game was no longer smooth at that time it was still the old hardware config, then it was a period when (maybe I took the power out and plugged it in again, I don't know anymore, but then the game was very smooth again.
Then, since it didn't get any better, I thought I'd switch to a bigger 165 Hz monitor.here, too, I felt as if the game was more smooth, and then it went away as if there had been a delay.
That's why I decided to change the config and see if it would be good, but there was no change. at that time I also changed the mouse (logitech pro x superlight) , it was also faster at the beginning, then not anymore.
So I switched to a 240hz monitor, but unfortunately I experienced this there as well, and I bought a 360hz monitor a few weeks ago, thinking it should be good here, but it's as if I have input lag.
Processor: AMD Ryzen 5 5600g 6 Core 12 Threads
Motherboard: ASUS PEMIUM B550-PLUS
RAMS: 2x8gb(KIT) Kingston FURY Beast 16GB DDR4 3200MHz KF432C16BBK2/16
Videocard: GIGABYTE GeForce GTX 1660 SUPER 6GB
SSD: (IN WINDOWS AND 2 GAME): Samsung SSD 850 EVO 250GB
HDD1: TOSHIBA DT01ACA100
HDD2: TOSHIBA DT01ACA050
Monitor: BenQ ZOWIE XL2566K 9H.LKRLB.QBE Monitor
when it was once, it should be like this
And one more note, for some reason, if I use it only with the video card integrated in the processor, it is much smoother, but not 100%
I would like to ask for your help! thank you!
