Not sure if SSD heatsink will fit in laptop
172 (0.28/day)
Motherboard Asus Strix B550-A
Cooling Be Quiet! Dark Rock 4
Memory Gskill Trident Z DDR4-3200 (16GB x 2)
Video Card(s) Sapphire Pulse RX 7900 XT 20GB
Storage Samsung 970 Evo Plus NVME 1TB (Boot), Samsung 970 Evo Plus NVME 2TB, Samsung QVO Sata 2Tb
Display(s) Aoc 31.5" 1440p 75hz; Asus 24" 1080p 75hz (secondary)
Case Be Quiet! Silent Base 802 White
Power Supply Corsair RM750X 2021 w/ Corsair Type 4 Sleeved Red Cables
I've got a TUF A15 with RTX 4060 and it only has a 512gb NVME included. I wanted to upgrade it to 32gb RAM (easy enough, I've done this on laptops before) and add a 2tb NVME.
However to save money I was going to use a 970 Evo plus from my desktop that has an EK NVME heatsink attached to it. This makes the SSD a bit "taller" but I don't know how much clearance the laptop shell gives. Does anyone know if it will fit?
2,920 (0.65/day)
Fort Worth, TX
System Name LGA775 | BoX-Server
Processor Xeon E5450 OC3.6GHZ from 3GHZ | i3 3.4GHZ
Motherboard ASUS PQ5-EM | ASRock
Cooling 120MM Heatsink (2-FANs) | Custom HSK 90mm
Memory DDR2 2GB-x4=8GB | 8GB 2x4GB=8GB
Video Card(s) NVIDIA Quadro K2200 4GB | Intel
Storage 500\500/240/240GB SSDs 120GB Laptop IDE
Display(s) Asus 24"
Case DIYPC N1e-SPORT | CoolerMaster 110
Power Supply EVGA 550WATT | Rosewill 530WATT
Mouse Rosewill RGB
Keyboard Rosewill RGB
Software WiN10ET/WiN11ET
CHATGBT
Would a heatsink on a M.2 fit in a TUF A15
ChatGPT said:
The ASUS TUF A15 typically has enough space for an M.2 NVMe SSD with a heatsink, but it depends on the size and thickness of the heatsink.
Key Considerations:
M.2 Slot Location:
The TUF A15 often has an M.2 slot under a metal shield (especially near the GPU or CPU), which might limit the available height for a heatsink.
The second M.2 slot (if available) may have more clearance.
Heatsink Size:
Slim, low-profile heatsinks (about 5-6mm in height) are generally safe.
Larger, bulkier heatsinks could obstruct nearby components or the laptop's bottom panel.
Thermal Pads/Pre-installed Shields:
The TUF A15 may already include a built-in thermal pad or heat spreader for the M.2 slot. If so, adding a separate heatsink may be unnecessary or could cause fitment issues.
Recommended Solution:
For best results, use a low-profile M.2 heatsink designed for laptops, such as the EK-M.2 NVMe Heatsink or similar models.
If the TUF A15 includes a pre-installed thermal pad or cover, that should suffice unless you're dealing with high temps.
Would you like guidance on installing one or checking clearance inside the laptop?
FreedomEclipse
~Technological Technocrat~
24,635 (3.76/day)
(currently) Hong Kong
System Name WorkInProgress
Processor AMD 7800X3D
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
These types of copper heatsinks are fairly cheap and usually used where super low profile is required
597 (2.79/day)
Texas, USA
System Name Obliterator
Processor Ryzen 7 7700x PBO
Motherboard ASRock x670e Steel Legend
Cooling Noctua NH-D15 G2 LBC
Memory G.skill Trident Z5 Neo 6000@CL30
Video Card(s) ASRock rx7900 GRE Steel Legend
Storage 2 x 2TB Samsung 990 pro nmve ssd 2 X 4TB Samsung 870 evo sata ssd 1 X 18TB WD Gold sata hdd
Display(s) LG 27GN750-B
Case Fractal Torrent
Audio Device(s) Klipsch promedia heritage 2.1
Power Supply FSP Hydro TI 1000w
Mouse SteelSeries Prime+
Keyboard Lenovo SK-8825 (L)
Software Windows 10 Enterprise LTSC 21H2 / Windows 11 Enterprise LTSC 24H2 with multiple flavors of VM
I like those too.
15,216 (6.74/day)
Midlands, UK
Cooling be quiet! Dark Rock 4
Case Kolink Citadel Mesh
Mouse Logitech MX Master 2S
Keyboard Logitech G413 SE
You've already got the laptop, and you've already got the SSD. What keeps you from trying it?
It would probably take you less time do undo the two screws you need to undo than it would take me to Google your question.
172 (0.28/day)
Dunno, just afraid of pulling it all apart, putting it together, and hearing some kind of crunch.
I also don't have the set of screwdrivers required as I've only recently moved out of home, so I was planning on doing the RAM + SSD upgrade when I next visit my parents as my dad has the full set of tiny screwdrivers. So I was trying to figure out if it will fit or whether I should buy a new SSD that doesn't have a huge HS stuck to it (the EK heatsinks are difficult to install and twice as difficult to remove)
15,216 (6.74/day)
Midlands, UK
Don't force it and you should be fine. :)
Then get the screwdrivers. ;) They're a must have in any PC geek's home. You can't install any SSD without them anyway, which makes your question pointless.
The thing is, how would anyone know whether your specific custom-cooled SSD will fit your specific laptop? Only you can try that.
As a general rule of thumb, though, laptops don't usually have space for thick bulky SSD heatsinks.
172 (0.28/day)
I have a big bulky screwdriver that goes fine for the desktop I brought with me but yeah you're right, I really do need a screwdriver kit. Before one of the screws in my head comes loose..
