NTLDR is missing!
2,188 (0.42/day)
England
Sad times for me, I've got a friends parents PC in to fix and upon deleting the unneeded crap (just) from the add/remove programs and went to restart... now I have the horrible problem of not being able to boot into windows! I'd really like to think there is a fix for this, hence why I'm asking here :D
Anyway a format is pretty far out the question to be honest unless ofcourse I have no other choice but there is a lot of data they would like to keep so that would be painstakingly horrid for me.
Please help me :)
386 (0.08/day)
Romania
Processor Intel Core i5 4570
Motherboard Gigabyte GA-Z87-HD3
Cooling Stock
Memory 8GB Kingston ValueRAM CL9 1333MHz DDR3
Video Card(s) Gigabyte GeForce GTS450OC-1GL
Storage 1TB WD Black + 1.5TB WD Black + Kingston V300 120GB
Display(s) T200HD
Case Delux MZ401
Power Supply Enermax NAXN 500W
Software Windows 8 Pro x64
Myabe there is some utility on hirens boot cd to fix this. I remember seeing it on some utility cds
1,980 (0.41/day)
Mainland Britain
System Name H2o Box
Processor Intel(R) Xeon e5-2690 v2 Stock 3.300 GHz stock
Motherboard MSI X79A-G43 Plus (MS-7760) v3
Cooling CPU EK & Phobya G-Changer 360 V2.0 RAD H2o VGA "AlphaCool M18" Hybrid [pump replaced 18/8/21]
Memory G.Skill TridentX 16Gb 11-12-12-32 2T @ 1866Mhz [locked]
Video Card(s) Zotac GTX 1080ti AMP EXTREME
Storage HyperX Fury 120GB & Savage 480GB SSD, Seagate 250GB,250GB 7200rpm Kingston 64GB SSD
Display(s) Asus TUF Gaming VG32VQR 2560*1440 165Hz VA Panel
Case Corsair O-800D
Power Supply Be Quiet! [Dark Power Pro 11] 1200W CM replaced [7-4-2017]
Mouse Zelotes T-90
Keyboard K66 Mechanical US Layout
Software Win 10 Pro 64Bit v 20H2 / OS [build 19043.1237] WFEP 120.2212.3530.0
Hi
Assuming this is XP
Boot from the windows XP CD
Press any key; boot from the CD
Enter windows XP recovery console
Type the following at the command prompt
fixmbr
remove CD
type exit
press Enter to restart
atb
Law-II
2,188 (0.42/day)
England
Law, that didn't work. :/
Would it make a difference to what Windows XP disc I use for example, discs with no SP or SP2?
1,980 (0.41/day)
Mainland Britain
System Name H2o Box
Case Corsair O-800D
Mouse Zelotes T-90
Hi
Maybe FIXBOOT command [should repair corrupted boot sector]
fixboot
remove CD
type exit
Other possible causes may include corrupt and or misconfigured files; corrupt hard drive sectors; damaged or loose IDE/SATA cables.
Double check the bios is able to see the drive
Double check the bios make sure the hdd is set to primary boot device
Before attempting to recover the drive; remove the hdd slave it to another PC and backup all data / image the drive or write it to another hdd
Note: What was the: "unneeded crap" that was uninstalled
atb
Law-II
2,188 (0.42/day)
England
That stuff was self-installing malware/spyware etc.
fixboot didn't work either, checked the BIOS and all is well there. I guess I'm just going to have to back up the data.
1,980 (0.41/day)
Mainland Britain
System Name H2o Box
Case Corsair O-800D
Mouse Zelotes T-90
Hi
That stuff was self-installing malware/spyware etc. fixboot didn't work either, checked the BIOS and all is well there. I guess I'm just going to have to back up the data.
Backup the data first;
then as a *last resort use windows repair [*I have never known this to go well and really is a last resort]
Windows XP
Insert the Windows XP bootable CD into the computer
When prompted to press any key to boot from the CD, press any key
Once in the Windows XP setup menu press the "R" key to repair Windows
Log into your Windows installation by pressing the "1" key and pressing enter
You will then be prompted for your administrator password, enter that password
Copy the below two files to the root directory of the primary hard drive. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." [This letter may be different on your computer]
copy e:\i386\ntldr c:\
copy e:\i386\ntdetect.com c:\
Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Source here
Note: Other member of the TPU community may have better options and may be able to assist further
best of luck
Law-II
2,188 (0.42/day)
England
So would you believe that's the first thing I tried but wasn't until reading it again here not long ago I noticed I was typing "1386" for the command instead of "i386" ... and specsavers say I don't need glasses anymore wtf?
Thanks once again Law! You've pointed me in the right direction a few times now.
1,048 (0.19/day)
Romania
Processor i7-9700
Motherboard Gigabyte Z390 AORUS PRO
Memory 32GB DDR4
Video Card(s) msi 1080
Storage Samsung SSD 850 pro 2TB+1tb hdd 7200rpm+ 1tb 970pro
Software Mageia 6 + Windows 10
I haved same problem years ago, the
"copy e:\i386\ntldr c:\
restart
(and if it still not working)
copy e:\i386\ntdetect.com c:\"
resolved me...if that will not work, I think you will not escape without reinstall of windows...
6,270 (0.93/day)
New York
Processor INTEL CORE I9-9900K @ 5Ghz all core 4.7Ghz Cache @1.305 volts
Motherboard ASUS PRIME Z390-P ATX
Cooling CORSAIR HYDRO H150I PRO RGB 360MM 6x120mm fans push pull
Memory CRUCIAL BALLISTIX 3000Mhz 4x8 32gb @ 4000Mhz
Video Card(s) EVGA GEFORECE RTX 2080 SUPER XC HYBRID GAMING
Storage ADATA XPG SX8200 Pro 1TB 3D NAND NVMe,Intel 660p 1TB m.2 ,1TB WD Blue 3D NAND,500GB WD Blue 3D NAND,
Display(s) 50" Sharp Roku TV 8ms responce time and Philips 75Hz 328E9QJAB 32" curved
Case BLACK LIAN LI O11 DYNAMIC XL FULL-TOWER GAMING CASE,
Power Supply 1600 Watt
Techtu, glad its looking up for you! Law-II very nice job with your helping assistance and as usual good job.
911 (0.24/day)
System Name BlueKnight
Processor Intel Celeron G1610 @ 2.60GHz
Motherboard Gigabyte GA-H61M-S2PH (rev. 1.0)
Memory 1x 4GB DDR3 @ 1333MHz (Kingston KVR13N9S8/4)
Video Card(s) Onboard
Storage 1x 160GB (Western Digital WD1600AAJS-75M0A0)
Display(s) 1x 20" 1600x900 (PHILIPS 200VW9FBJ/78)
Case μATX Case (Generic)
Power Supply 300W (Generic)
Software Debian GNU/Linux 8.7 (jessie)
You can retrieve your data using another program (e.g.: *Linux live CD) or connecting your hard drive to another machine or using the command line tools included in Windows CD. Losing your data is not going to be a problem...
And make sure your hard drive is healthy, that could be cause by faulty HDD... Or by a program, yourself, another kind of event...
Happy New Year!
