NVCleanInstall knocks out Oculus?
MrDamage-42
2 (0.00/day)
Hello.
Anyone else having trouble getting their Oculus headset to work after using NVCleanInstall? The headset (Rift S) was recognised and fully working as far as the games were concerned, but I got a completely black screen.
I reinstalled the original Nvidia driver and it fixed the problem. I later used NVCleanInstall again and it gave me problems untill I selected "Full install" and then later just unchecked the "Telemetry and Advertising" option, which is now working perfectly.
Anyone know which options to enable/disable?
Thanks.
W1zzard
Administrator
28,154 (3.72/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
First time I hear of this. Is the Oculus connected to your graphic card's USB-C? in that case you'll probably need the USB-C driver
3,127 (2.36/day)
Motherboard Apple proprietary
Cooling Apple proprietary
Case Apple proprietary
Mouse Apple Magic Trackpad 2
Software macOS Sonoma 14.7
The Oculus Rift S has two cables, one for graphics, the other for data (mostly sensors I assume).
The graphics cable is DisplayPort and connects directly to the GPU. The data cable has a USB-A connector and connects to one of the computer's USB-A ports (Oculus specifies a port with USB 3.0 speed).
There is no USB-C connection.
Only Turing cards had USB-C shaped VirtualLink ports; the VR industry did not adopt this standard which is why the port is gone in Ampere and RDNA2 cards. When I was using my Rift S with my 2070 SUPER FE, I never touched the VirtualLink port on the GPU.
I have never used NVCleanstall so I can't confirm whether or not the utility is at fault.
Mindweaver
Moderato®™
8,345 (1.45/day)
Charleston, SC
System Name Tower of Power / Delliverance
Processor i7 14700K / i9-14900K
Motherboard ASUS ROG Strix Z790-A Gaming WiFi II / Z690
Cooling CM MasterLiquid ML360 Mirror ARGB Close-Loop AIO / Air
Memory CORSAIR - VENGEANCE RGB 32GB (2x16GB) DDR5 7200MHz / DDR5 2x 16gb
Video Card(s) ASUS TUF Gaming GeForce RTX 4070 Ti / GeForce RTX 4080
Storage 4x Samsung 980 Pro 1TB M.2, 2x Crucial 1TB SSD / NVM3 PC801 SK hynix 1TB
Display(s) Samsung 32" Odyssy G5 Gaming 144hz 1440p, 2x LG HDR 32" 60hz 4k / 2x LG HDR 32" 60hz 4k
Case Phantek "400A" / Dell XPS 8960
Audio Device(s) Realtek ALC4080 / Sound Blaster X1
Power Supply Corsair RM Series RM750 / 750w
Mouse Razer Deathadder V3 Hyperspeed Wireless / Glorious Gaming Model O 2 Wireless
Keyboard Glorious GMMK with box-white switches / Keychron K6 pro with blue swithes
VR HMD Quest 3 (512gb) + Rift S + HTC Vive + DK1
Software Windows 11 Pro x64 / Windows 11 Pro x64
Benchmark Scores Yes
Hello.
Thanks.
Can you show us a screen shot of what you have select to install for when you get the error? I have never had any issues with my Rift S or Quest 2 after installing. I'm pretty sure you have to have "Microsoft Visual C 2017 Runtimes" and "HD Audio via HDMI" installed. I would test it out but my office pc has AMD.
MrDamage-42
2 (0.00/day)
Thanks for all the replies.
Hi Mindweaver. I selected the "recommended" setting -
And as Valdes said, the Rift S uses the Mini DP and a USB3 port to connect. My only suggestion is that maybe that "NVContainer" has something to do with VR, or the "Virtual Host Controller" - but that's just guessing.
I re-ran the tool and selected "All", then at the next window I only deselected the Telemetry, and it's now working perfectly.
My laptop is an MSI GS73VR, with an Nvidia 1070MaxQ and (..sadly unswitchable) Optimus.
I mean, everything is under control now, I just thought it might help others if they found themselves in the same situation.
Regards.
Mindweaver
Moderato®™
8,345 (1.45/day)
Charleston, SC
Regards.
No problem! Welcome to TPU! The Rift S uses a regular DP and USB3 port are you saying you use a Mini DP port to your laptop? That shouldn't matter as long as the Mini-DP to DP works. I have a Rift S and Quest 2 with an RTX 2070 and when I use NVCleanstall I always select "Display Driver (required)", "HD Audio via HDMI", "Microsoft Visual C 2017 Runtimes", "Optimus", "USB-C Driver" and "FrameView SDK". I have never had an issue with those settings. Just for SNG can you try with just those settings? Also, if I had a RTX 3000 GPU I wouldn't install USB-C Drivers. I only install that driver because it's on the RTX 2000 series gpu. It's funny I've never used that port either.. lol
3,127 (2.36/day)
The Rift S includes a DisplayPort-to-mini-DP dongle in the box. Clearly OP is using this accessory to connect to their notebook PC.
The Nvidia driver installer won't install the USB-C driver on the 3000-series cards since there's no USB-C port on Ampere discrete graphics cards.
I used the VirtualPort USB-C connector for a short time when my 2070 SUPER FE was connected to an LG monitor with a USB-C display input port. I stopped doing this because this particular connection downgraded the USB data connection to USB 2.0; I went back to separate DisplayPort and USB cables.
Mindweaver
Moderato®™
8,345 (1.45/day)
Charleston, SC
I don't understand what you are trying to tell me other than repeating what I've said. Also, pay attention to where I said I own a Rift S and a Quest 2. Also, I do not own a RTX 3000 gpu so like I said I would not check the box to install the usb c driver. I didn't say it would install either way.
3,127 (2.36/day)
You exhibited surprise that OP was connecting their Rift S via mini-DP. That led me to believe that you didn't fully understand the basic connection possibilities of the Rift S since the thing comes with the dongle.
My main contribution here is that *NOT* using NVCleanstall preserves the Oculus software for use with a 2070/3080/3080 Ti discrete card. I'm not into identifying creative ways of destroying software stability.
Anyhow, I bow out of further discussion on this topic. OP has a VR configuration that works and I don't use NVCleanstall anyhow.
Carry on.
Mindweaver
Moderato®™
8,345 (1.45/day)
Charleston, SC
Carry on.
Wow, you seem really upset over this.. lol Clearly you are not paying attention. I was only replying to where he said "Valdes said, the Rift S uses the Mini DP and a USB3 port to connect.". It's literally the first sentence that I quoted to him. You didn't even say that about the Rift S. You said DisplayPort.. lol I'll be honest I was heading out the office and I did not read the full thread. I just wanted to let him know what I use and using my selection works fine with my Rift S and Quest 2. I'm glad that you bow out of further discussion because I don't have the time for this back and forth.. lol
So don't carry on. ;)
EDIT: I would like to hear if using my selection works for OP.
