NVCleanstall |Hardware ID Template | Help?
DamnSpyware
12 (0.02/day)
The latest version of NVCleanstall appears to force users to enter a hardware id template if we decide to configure advanced settings. In older versions this was not needed.
I have absolutly no idea what an hardware id template is.
Question is, how do i know what template i must select for my specific GPU? There are multiple templates for each GPU so how do i figure out which one to select?
In my case it's a 1080 Ti, the templates (see the screenshot below) show different numbers/ids, but no explenation on what they do and why you might choose one over another?
Other settings in NVCleanstall show a blue button "Help" pressing that will open the default webbrowser and show an explenation on what the setting does, would be great if such a button can be added to gpu templates.
W1zzard
Administrator
28,136 (3.72/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
Uncheck "Add Hardware Support", GTX 1080 Ti is already supported by the regular drivers.
W1zzard
Administrator
28,136 (3.72/day)
Memory 48 GB
DamnSpyware
12 (0.02/day)
I must have pressed that button by mistake,:
These are the settings i normally use.
Not sure about interrupt policy and priority, recommendations?
Is there any way to export program settings to import them later? It's somewhat time consuming taking care of all these programs each time a new driver is installed.
W1zzard
Administrator
28,136 (3.72/day)
Memory 48 GB
Update your NVCleanstall to the newest version. Once you've completed the Tweaks page, on the second run there will be a "previous settings" button. This was added in 1.11 or something, check the changelogs
DamnSpyware
12 (0.02/day)
I dont have nvcleanstall installed, only used it to install the modified nvidia driver.
So without installing the software itself, theres no "previous settings button"?
And may i ask is there software like nvcleanstall for amd drivers?
W1zzard
Administrator
28,136 (3.72/day)
Memory 48 GB
There is, but you need to run 1.13 or newer, you're running 1.10. Only 1.13 and up will save your choices "Choices made on the Tweaks page will be saved and can be restored with one click on subsequent runs"
Not that I'm aware of, I certainly don't make any. Maybe some day, when I have a lot of free time ;)
1,634 (0.99/day)
Maybe the "Add Hardware Support" label could have a better title?
just explain that its to install unorthodox driver combinations, like a gameready one on an A2000 or something (ie things that will work due to architecture, but nv just doesnt want you to do ... for some reason).
