Nvidia 7950 Fan to wide for Asus P5N32 se mobo??
Hunt9506
2 (0.00/day)
Processor Intel Pentium D, 3.6 MHz
Motherboard Asus P5N 32 SLI Deluxe
Cooling Intel LGA775, 3 Red Fans
Memory 2 GB Corsair XMS Pro
Video Card(s) 2 x NVidea 7950 GX2 via SLI Bridge
Storage Raid 0 strip w/ 2x 250GB 32 MB buffers
Display(s) Dell 20" Widescreen
Case X-Cruiser Tower w/Windows & Multimeter Display
Audio Device(s) Creative X-Fi 24
Power Supply Apevia Beast Power 680 Watts ATX
Software Win XP Professional
CyberPowerPC just called me... saying I need to chose either a new mobo (Asus P5N32 delux) ... or a new Grafix card (Nvidea 7950 GX2) ...
because the Fan on the Card is too wide to fit into the 16x slot (blocking the Power connector)???
Has anybody ever heard that, or of probs of that sort??
Cant believe Asus would design that board for NVidea if the friggen card dont fit...
Any comments??
Thanks
KennyT772
3,572 (0.51/day)
System Name Raptor
Processor Intel E8400 Wolfdale @3600
Motherboard Asus P5Q-Pro LGA775
Cooling Zalman CNPS9700
Memory 1024mbx2 Crucial Ballistix DDR800
Video Card(s) XFX 9600GT
Storage Seagate 7200.11 500GB
Display(s) Acer AL2216Wbd and Acer AL1717
Case Gigabyte 3DAurora Black
Audio Device(s) Creative X-Fi Extreme Gamer Faitality
Power Supply OCZ GameXStream 500w
looks like it to me.
tell them that is the config u want as u only need the plug if you are running sli.
see the heatsink? that is what is blocking the molex. you should be able to find a 90degree adapter for it if it is required.
Darksaber
Senior Editor & Case Reviewer
3,103 (0.43/day)
Victoria, BC, Canada
System Name Corsair 2000D Silent Gaming Rig
Processor Intel Core i5-14600K
Motherboard ASUS ROG Strix Z790-i Gaming Wifi
Cooling Corsair iCUE H150i Black
Memory Corsair 64 GB 6000 MHz DDR5
Video Card(s) Gainward GeForce RTX 4080 Phoenix GS
Storage TeamGroup 1TB NVMe SSD
Display(s) Gigabyte 32" M32U
Case Corsair 2000D
Power Supply Corsair 850 W SFX
Mouse Logitech MX
Keyboard Sharkoon PureWriter TKL
yea looks like it does block the power connector.
but a 7900GTX would block it as well?
ask them about a 7900GTX...if they tell you the same...then you know for sure.
cheers
DS
Hunt9506
2 (0.00/day)
thanks guys for your info...
I resolved the problem... there are 2 types of ASUS P5N32 SLI DELUXE BOARDS...
Issue 1 (older) and Issue B (newer Board) The spacing on the newer board is adequate for the 7950 GX2 cards (all models)
The card that is just an Idea wider than the XFX or BFG type is the eVGA card. This card is about an 1/8 " wider than the others, which caused that slight problem. Asus took care of it and advised my builder (CyberPowerPC) which board to use.
And my completed System shipped today :toast:
I will most likely get it on Tuesday w/2 day shipping. Then I will add my 2nd 7950 card and hook up via SLI... :roll:
Hope I can learn all about the Fine tuning of the Board.
Hey guys thanks for the advice. :respect:
Azn Tr14dZ
5,288 (0.76/day)
Processor AMD Athlon 64 3200+
Motherboard DFI LanParty nf4 Ultra-D
Cooling Thermaltake Big Typhoon
Memory 2x512MB GeIL
Video Card(s) ATI Radeon X800XL
Storage 2x80GB Western Digital
Display(s) HP vs17
Case SuperTalent
Audio Device(s) Soundblaster
Power Supply Ultra X-Finity 500 Watt
Have fun w/ the computer!:toast:
Frick
Fishfaced Nincompoop
19,912 (2.87/day)
north
System Name Black MC in Tokyo
Processor Ryzen 5 7600
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
Keyboard Dell SK3205
Heh, with a system that expensive he/she MUST enjoy it. :)
catstone
44 (0.01/day)
p.r.c
Processor AMD 64 ES at 200*7=1.4gig 1mL2cache
Motherboard ABIT NF8 with nforce3 250gb chipset
Cooling ordinary air cooling
Memory 512*2=1gig of different brand with same memory chip D43
Video Card(s) ATI 9800 with 128M at 128bit
Storage IBM scsi ic35l036ucd210
Display(s) PHILIPS 105s5
Case plain
Power Supply 250wt
Software windows xp
gee, now that u get a sli of 7950x2, why not chose concore.
i guess such a system would blow me up to the sky
