System Name | AlderLake |
Processor | Intel i7 12700K P-Cores @ 5Ghz |
Motherboard | Gigabyte Z690 Aorus Master |
Cooling | Noctua NH-U12A 2 fans + Thermal Grizzly Kryonaut Extreme + 5 case fans |
Memory | 32GB DDR5 Corsair Dominator Platinum RGB 6000MT/s CL36 |
Video Card(s) | MSI RTX 2070 Super Gaming X Trio |
Storage | Samsung 980 Pro 1TB + 970 Evo 500GB + 850 Pro 512GB + 860 Evo 1TB x2 |
Display(s) | 23.8" Dell S2417DG 165Hz G-Sync 1440p |
Case | Be quiet! Silent Base 600 - Window |
Audio Device(s) | Panasonic SA-PMX94 / Realtek onboard + B&O speaker system / Harman Kardon Go + Play / Logitech G533 |
Power Supply | Seasonic Focus Plus Gold 750W |
Mouse | Logitech MX Anywhere 2 Laser wireless |
Keyboard | RAPOO E9270P Black 5GHz wireless |
Software | Windows 11 |
Benchmark Scores | Cinebench R23 (Single Core) 1936 @ stock Cinebench R23 (Multi Core) 23006 @ stock |
System Name | Pioneer |
Processor | Ryzen R9 9950X |
Motherboard | GIGABYTE Aorus Elite X670 AX |
Cooling | Noctua NH-D15 + A whole lotta Sunon, Phanteks and Corsair Maglev blower fans... |
Memory | 64GB (2x 32GB) G.Skill Flare X5 @ DDR5-6000 CL30 |
Video Card(s) | XFX RX 7900 XTX Speedster Merc 310 |
Storage | Intel 5800X Optane 800GB boot, +2x Crucial P5 Plus 2TB PCIe 4.0 NVMe SSDs |
Display(s) | 55" LG 55" B9 OLED 4K Display |
Case | Thermaltake Core X31 |
Audio Device(s) | TOSLINK->Schiit Modi MB->Asgard 2 DAC Amp->AKG Pro K712 Headphones or HDMI->B9 OLED |
Power Supply | FSP Hydro Ti Pro 850W |
Mouse | Logitech G305 Lightspeed Wireless |
Keyboard | WASD Code v3 with Cherry Green keyswitches + PBT DS keycaps |
Software | Gentoo Linux x64 / Windows 11 Enterprise IoT 2024 |
Ran with NSudo as System, as I had suspected it did not solve the issue. Please run DDU and try install 441.66 with the latest NVcleaninstall. See if nvidia control panel installs properly.
I never had this issue before, i believe it has something to do with the new drivers. Nvidia's driver installer failed tduring a 441.41 driver update. After that, ALL nvidia driver updates failed to install, both previous versions and the latest, even after DDU... the only driver that worked was via windows update. Others complained of the same problem, the solution came from the next nvidia driver package update 441.66... so I suspect changes in their package.
System Name | Apex Raptor: Silverback |
Processor | Intel i9 13900KS |
Motherboard | z790 Apex |
Cooling | LT720 360mm + Phanteks T30 |
Memory | 32GB |
Video Card(s) | RTX 4090 |
Storage | 990 PRO 4TB |
Display(s) | Neo G8 / C1 65" |
Case | Antec Performance 1 |
Audio Device(s) | DT 1990 Pro / Motu M2 |
Power Supply | Prime Ultra Titanium 1000w |
Mouse | G502 X Plus |
Keyboard | K95 Platinum |
Processor | Ryzen 7 5800X3D |
Motherboard | Gigabyte X570 Aorus Elite |
Cooling | Thermalright Phantom Spirit 120 SE |
Memory | 2x16 GB Crucial Ballistix 3600 CL16 Rev E @ 3600 CL14 |
Video Card(s) | RTX3080 Ti FE |
Storage | SX8200 Pro 1 TB, Plextor M6Pro 256 GB, WD Blue 2TB |
Display(s) | LG 34GN850P-B |
Case | SilverStone Primera PM01 RGB |
Audio Device(s) | SoundBlaster G6 | Fidelio X2 | Sennheiser 6XX |
Power Supply | SeaSonic Focus Plus Gold 750W |
Mouse | Endgame Gear XM1R |
Keyboard | Wooting Two HE |
@R-T-B, NO! Oh, waiiiiiit a minute;; 441.66-desktop-win10-64bit-international-dch-whql
yep! YOURE A F**ING GENIOUS; problem is the only driver offered by nvidia's website is dhc; is the 660 gtx no longer supported?
thank you for all the good work you do, merry christmas
Ok, so I downloaded the non dch 441.66 version. Your app and nvidia.com don't allow me to do that... I had to use a third party. 441.66 ended up installing an older driver 432.00... of control panel and the driver itself; reverting from my previous 441.66 version... there is a control panel in windows control panel, but it is not accessible in the context menu on desktop, and windows 10 keeps on saying you must install it from the store.
Nvidia is playing some kind of funky game with the DCH drivers. I still don't know what they plan to do for servers. It's messed up.
Ok, on a second attempt with NVslimmer, this time set to clean install, 446.11 installed properly with the control panel. Thanks for your help man, huge!
Processor | Ryzen 7 5700X |
Memory | 48 GB |
Video Card(s) | RTX 4080 |
Storage | 2x HDD RAID 1, 3x M.2 NVMe |
Display(s) | 30" 2560x1600 + 19" 1280x1024 |
Software | Windows 10 64-bit |
I'm not making NVSlimmer, I make NVCleanstallThank w1zzard more. He wrote that program, I just guessed your issue.
You need to manually search now for the non DCH driver on nvidia's site. Microsoft is pushing a new driver system that forces control panels to be only available through their store.
Processor | Core i9-9900k |
Motherboard | ASRock Z390 Phantom Gaming 6 |
Cooling | All air: 2x140mm Fractal exhaust; 3x 140mm Cougar Intake; Enermax ETS-T50 Black CPU cooler |
Memory | 32GB (2x16) Mushkin Redline DDR-4 3200 |
Video Card(s) | ASUS RTX 4070 Ti Super OC 16GB |
Storage | 1x 1TB MX500 (OS); 2x 6TB WD Black; 1x 2TB MX500; 1x 1TB BX500 SSD; 1x 6TB WD Blue storage (eSATA) |
Display(s) | Infievo 27" 165Hz @ 2560 x 1440 |
Case | Fractal Design Define R4 Black -windowed |
Audio Device(s) | Soundblaster Z |
Power Supply | Seasonic Focus GX-1000 Gold |
Mouse | Coolermaster Sentinel III (large palm grip!) |
Keyboard | Logitech G610 Orion mechanical (Cherry Brown switches) |
Software | Windows 10 Pro 64-bit (Start10 & Fences 3.0 installed) |
I mother&%£&!%# HATE MS!You need to manually search now for the non DCH driver on nvidia's site. Microsoft is pushing a new driver system that forces control panels to be only available through their store.
Processor | i7-13700k |
Motherboard | Asus Tuf Gaming z790-plus |
Cooling | Coolermaster Hyper 212 RGB |
Memory | Corsair Vengeance RGB 32GB DDR5 7000mhz |
Video Card(s) | Asus Dual Geforce RTX 4070 Super ( 2800mhz @ 1.0volt, ~60mhz overlock -.1volts) |
Storage | 1x Samsung 980 Pro PCIe4 NVme, 2x Samsung 1tb 850evo SSD, 3x WD drives, 2 seagate |
Display(s) | Acer Predator XB273u 27inch IPS G-Sync 165hz |
Audio Device(s) | Logitech Z906 5.1 |
Power Supply | Corsair RMx Series RM850x (OCZ Z series PSU retired after 13 years of service) |
Mouse | Logitech G502 hero |
Keyboard | Logitech G710+ |
https://www.nvidia.com/Download/Find.aspx?lang=en-us <--- non-dch is right as an option@R-T-B, NO! Oh, waiiiiiit a minute;; 441.66-desktop-win10-64bit-international-dch-whql
