zekrahminator
McLovin
- Jan 29, 2006
- 9,066 (1.33/day)
- My house.
Processor | AMD Athlon 64 X2 4800+ Brisbane @ 2.8GHz (224x12.5, 1.425V) |
Motherboard | Gigabyte sumthin-or-another, it's got an nForce 430 |
Cooling | Dual 120mm case fans front/rear, Arctic Cooling Freezer 64 Pro, Zalman VF-900 on GPU |
Memory | 2GB G.Skill DDR2 800 |
Video Card(s) | Sapphire X850XT @ 580/600 |
Storage | WD 160 GB SATA hard drive. |
Display(s) | Hanns G 19" widescreen, 5ms response time, 1440x900 |
Case | Thermaltake Soprano (black with side window). |
Audio Device(s) | Soundblaster Live! 24 bit (paired with X-530 speakers). |
Power Supply | ThermalTake 430W TR2 |
Software | XP Home SP2, can't wait for Vista SP1. |
NVIDIA's "ace-in-the-hole" is not a driver tweak: it's an unlocking of the G80 core. While the current offerings from NVIDIA using the G80 core, the 8800GTS and the 8800GTX, use an already impressive 96/128 unified shaders, respecfully, NVIDIA claims the G80 shipped with more. NVIDIA says that they will make the 8900GTX have 25% more shaders than the 8800GTX, meaning NVIDIA's DirectX 10 offering will have 160 shaders at it's disposal. The unlocked G80 core can be clocked at no higher than 630MHz on air, and 680MHz on water (according to NVIDIA). The Inquirer is guessing that this monster card will ship around the same time as ATI's R600.
