Nvidia GeForce GT 520
  • Thread starter Deleted member 191766
  • Start date
I have an ASUS GeForce GT 520 and was disappointed that it could not drive 2560 x 1440 without some tricks and that
NVIDIA has disabled some shading units on the GeForce GT 520 to reach the product's target shader count. It features 48 shading units, 8 texture mapping units and 4 ROPs
Is there anyway to overcome either of these shortcomings? enable all 96 shaders or have it support 2560 x 1440 naturally?
I already know the trick of using the Nvidia Control Panel to set up a custom resolution and had the card running 2560 x 1440, but wanted a way to achieve this without work arounds.
It runs BIOS 75.19.1B.00.01 and I tried some others to no avail.
847 (0.34/day)
Haswell, USA
System Name Bruh
Processor 10700K 5.3Ghz 1.35v| i7 7920HQ 3.6Ghz -180Mv |
Motherboard Z490 TUF Wifi | Apple QMS180 |
Cooling EVGA 360MM | Laptop HS |
Memory DDR4 32GB 3600Mhz CL16 | LPDDR3 16GB 2133Mhz CL20 |
Video Card(s) Asus ROG Strix 3080 (2100Mhz/18Ghz)|Radeon Pro 560 (1150Mhz/1655Mhz)|
Storage Many SSDs, ~24TB HDD/8TB SSD
Display(s) S2719DGF, HP Z27i, Z24n| 1800P 15.4" + ZR30W + iPad Pro 10.5 2017
Case NR600 | MBP 2017 15" Silver | MSI GE62VR | Elite 120 Advanced
Audio Device(s) Lol imagine caring about audio
Power Supply 850GQ | Apple 87W USB-C |
Mouse Whatever I have on hand + trackpads (Lanchead TE)
Keyboard HyperX Origins Alloy idk
Software W10 20H2|W10 1903 LTSC/MacOS 11
Benchmark Scores No.
The max res is 2560x1600, so its likely a cable or adapter thats causing a issue. There is no way to unlock the card, wouldnt be much point given how utterly useless it is.
3,152 (0.91/day)
Argentina
System Name Ciel / Akane
Keyboard VSG Alnilam / Dell
Plus thermals would be a problem if it could be unlocked.
See if you can sell it and get a GT1030.
3 (0.00/day)
I happened to see your post on homepage. I registered just to reply to you.
GT520 can drive a 2560 x 1440 display like a breeze. No, I haven't used any tricks. Just plug the display in, voilà, the resolution is re-adjusted to 1440p by itself.
I have be using it with my 2560 x 1440 display for years.
Frick
Fishfaced Nincompoop
19,999 (2.86/day)
norr
System Name Black MC in Tokyo
Processor Ryzen 5 7600
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
Keyboard Dell SK3205
Hey, I wouldn't say that. I played a whole lotta WoW (WoD) with it plus a e8400. Sluggish but it definitely worked fine.
What is the refresh rate when running at 2560 x 1440? I could not get up to 60Hz even with tricks (on another video card there were no problems using the same cable).
With the huge heatsink on the fan-less ASUS it would probably be OK; I actually have two GT 1030 units that are running just fine.
Low quality post by eidairaman1
44,177 (6.80/day)
Get a 960, 520 is ancient
3 (0.00/day)
60hz
Perhaps you have the GeForce GT 520 with all 96 cores active?
What BIOS version are you running?
I may have found out why you don't see the problem
seems DVI-DVI can support 2560 x 1440 (on the GT 520), but not HDMI-DVI or HDMI-HDMI
On a GT 1030 I have no such problem.
