NVIDIA GeForce RTX 20-series Mobility mGPU Lineup Revealed
47,293 (7.53/day)
NVIDIA is giving finishing touches to its first GeForce RTX 20-series Mobility GPUs for notebooks, based on the "Turing" architecture, with product launches expected from Q1-2019. The company could debut the series with a high-end part first, the GeForce RTX 2080 Mobility Max-Q. The rest of the lineup includes the RTX 2070 Mobility Max-Q, RTX 2060 Ti Mobility, RTX 2060 Mobility, RTX 2050 Ti Mobility, and RTX 2050 Mobility. What's interesting about this list is that NVIDIA is limiting the Max-Q design to its top-tier RTX 2080 Mobility and RTX 2070 Mobility parts.
Max-Q is an all-encompassing laptop thermal-design methodology, which allows gaming notebook designers to come up with thinner notebooks with higher performance. One of the key aspects is special Max-Q ready variants of the GPUs, which are probably binned to run the coolest, and least voltages. With a device ID 1eab, the RTX 2080 Mobility Max-Q is based on the TU104M chip, while other SKUs could be carved from the TU106M or a chip even smaller. It's being reported that with this generation, NVIDIA is playing a more active role in helping its partners engineer their Max-Q notebooks, and helping them meet NVIDIA's strict Z-height minimums.
22,654 (6.05/day)
LMAO. RTX heat in a thin and light device. I can't wait to see it perform worse than Pascal. Just add Max-Q and all the noobs think they're buying the good stuff when in fact they are stuck with overpriced performance of a GPU that is two tiers lower than its desktop equivalent. IF its not throttling, that is.
'Nvidia is playing a more active role' - that alone should be read as a big fat warning sign.
2,186 (0.51/day)
Deez Nutz, bozo!
Sounds interesting though the "Mobility" suffix was used in ATI's mobile GPU family 10 years ago... I am stoked to see how the Turing perform in thin & light platform. Hopefully the silicon is mature enough to get a 8nm or 10nm shrink with reasonable yield rate.
3,595 (1.16/day)
I haven't seen any material stating that lower parts will have RTX. Everyone is talking about a picture that doesn't include the "RTX" text at all - just model numbers.
Sure, I'd love an RTX 1050 mobile, but that's really unlikely.
22,654 (6.05/day)
Good point, in fact!
2,186 (0.51/day)
Deez Nutz, bozo!
it's been said that ANY TU10x cores that are "lower" than 104 won't get RT cores or even get the RTX naming convention, so we'll see a "GTX" 2050 or 2060 instead with Tensor & CUDA core present in those toned-down Turing chips.
bug
13,839 (3.96/day)
Processor Intel i5-12600k
Motherboard Asus H670 TUF
Cooling Arctic Freezer 34
Case Raijintek Thetis
Keyboard G.Skill KM780R
Software Arch Linux + Win10
Maybe because lower tier cards don't draw that much power anyway? ;)
T4C Fantasy
CPU & GPU DB Maintainer
2,566 (0.56/day)
Rhode Island
Processor Intel Core i9-12900K @ Default
Motherboard Gigabyte Z690 AORUS Elite AX
Memory Corsair Dominator Platinum 32GB DDR4-3200
Case Thermaltake Core X9 Snow
Audio Device(s) Logitech G935 Headset
Keyboard Logitech G915
Benchmark Scores FFXV: 19329
the thing is, that is all speculation, whether its true or not is not known.
but TU106 has rt cores and that will be 2060Ti and maybe 2060 too.
TU116 may have tensor and rt removed.
2,186 (0.51/day)
Deez Nutz, bozo!
Ah... well, guess we have to find out by December or next year whenever NVIDIA teases us again.
newtekie1
Semi-Retired Folder
28,473 (4.09/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
The performance/watt of Turing is better than Pascal, from what we've seen. So performance in mobile devices should be better for the RTX cards than pascal cards.
1,606 (0.35/day)
Northamptonshire, UK
System Name Main / HTPC
Processor Ryzen 7 7800X3D / Ryzen 7 2700
Motherboard Aorus B650M Elite AX/ B450i Aorus Pro Wifi
Cooling Lian-Li Galahad 360 / Wraith Spire
Memory Corsair Vengeance 2x16 6000MHz CL30 / HyperX Predator 2x8GB 3200MHz
Video Card(s) RTX 3080 FE / ARC A380
Storage WD Black SN770 1TB / Sabrent Rocket 256GB
Display(s) Aorus FO32U2P / 39" Panasonic HDTV
Case Fractal Arc XL / Cougar QBX
Audio Device(s) Denon AVR-X2800H / Realtek ALC1220
Power Supply Corsair RM850 / BeQuiet SFX Power 2 450W
Mouse Logitech G903
Keyboard Drop Sense75 with WQ Studio Morandi's
VR HMD Rift S
Software Win 11 Pro 64Bit
TU106 in RTX2070 has them enabled.
22,654 (6.05/day)
Really now? And this is without RTX ON
7,563 (1.77/day)
Why, you don't "have to" enable RT in games do you? If they've made RTX, with RT in mind, as many have said it'd be foolish to just include it in the high end. Without mid/low range cards having RT in silicon, it'd be a stillborn at best or worse Physx v2 :shadedshu:
3,595 (1.16/day)
Really now?
Do we see a different picture?
2080: 111%
1080: 108%
2080Ti: 99%
1080Ti: 95%
That may not be much, but it's still better.
And then...
RTX and Tensor cores are designed to be way more effective in particular tasks. They'll improve performance/W further in such scenarios. Otherwise they're idle.
22,654 (6.05/day)
2080: 111%
1080: 108%
2080Ti: 99%
1080Ti: 95%
And then...
Yeah thats a whole 2 minutes of extra battery life wooptidoo!
3,595 (1.16/day)
Well... better is better. You didn't say it has to be much better. :)
If you put the RTX and Tensor parts away, it's really just a Pascal refresh.
But the "not worse" result is fairly important for notebooks. This means manufacturers will be able to just replace 10-series with 20-series without much intervention to design of cooling etc.
Pascal gave us a huge jump of GPU performance in ultrabooks and thin gaming laptops. It's great this won't be reverted by the new generation. :)
