- Aug 19, 2017
- 2,781 (1.02/day)
Recent engineering prototype leaks reveal NVIDIA's power delivery design for its RTX 5090 flagship GPU featured a jaw-dropping quad 12V-2x6 connector configuration. The prototype board, while not publicly photographed, is significantly different from the final version we have today. The quad-connector design serves multiple purposes beyond raw power delivery. Each 12V-2x6 connector, capable of delivering up to 600 W individually, creates a theoretical power ceiling far beyond reasonable requirements. More likely, the implementation allows for separate voltage rails and enhanced power stability, crucial for the card's reported 575 W TDP - a 125 W increase from the RTX 4090's specifications. This overengineered piece follows NVIDIA's historical engineering practices, where early prototypes typically feature expanded power delivery systems that are later optimized for production.
The timing of this leak happens just in time with ongoing discussions about 12V-2x6 connector reliability, particularly following documented failures. While the quad-connector design may seem excessive, it distributes power load more evenly across multiple connection points, potentially addressing thermal concentration issues that plagued single-connector implementations. Board partners like ASUS have already implemented sophisticated current monitoring solutions in their custom designs, using shunt resistors to detect overcurrent conditions across individual pins. Established hardware leaker, Panzerlied confirmed the prototype's existence on Chinese forums, alongside images of other engineering samples featuring similar power delivery experiments across multiple GPU generations.
