NVIDIA GeForce RTX 50 Cards Spotted with Missing ROPs, NVIDIA Confirms the Issue, Multiple Vendors Affected
47,513 (7.48/day)
TechPowerUp has discovered that there are NVIDIA GeForce RTX 5090 graphics cards in retail circulation that come with too few render units, which lowers performance. Zotac's GeForce RTX 5090 Solid comes with fewer ROPs than it should—168 are enabled, instead of the 176 that are part of the RTX 5090 specifications. This loss of 8 ROPs has a small, but noticeable impact on performance. During recent testing, we noticed our Zotac RTX 5090 Solid sample underperformed slightly, falling behind even the NVIDIA RTX 5090 Founders Edition card. At the time we didn't pay attention to the ROP count that TechPowerUp GPU-Z was reporting, and instead spent time looking for other reasons, like clocks, power, cooling, etc.
Two days ago, one of our readers who goes by "Wuxi Gamer," posted this thread on the TechPowerUp Forums, reporting that his retail Zotac RTX 5090 Solid was showing fewer ROPs in GPU-Z than the RTX 5090 should have. The user tried everything from driver to software re-installs, to switching between the two video BIOSes the card comes with, all to no avail. What a coincidence that we had this card in our labs already, so we then dug out our sample. Lo and behold—our sample is missing ROPs, too! GPU-Z is able to read and report these units counts, in this case through NVIDIA's NVAPI driver interface. The 8 missing ROPs constitute a 4.54% loss in the GPU's raster hardware capability, and to illustrate what this means for performance, we've run a couple of tests.
In the first test, "Elden Ring" at 4K UHD with maxed out settings and native resolution (no DLSS), you can see how the Zotac RTX 5090 Solid falls behind every other RTX 5090 we tested, including the NVIDIA Founders Edition, a de facto reference-design that establishes a performance baseline for the RTX 5090. The Zotac card is 5.6% slower than the FE, and 8.4% slower than the ASUS ROG Astral RTX 5090 OC, the fastest custom design card for this test. Officially, the Solid is clocked at 2407 MHz rated boost frequency, which matches the Founders Edition clocks—it shouldn't be significantly slower in real-life. The interesting thing is that the loss of performance is not visible when monitoring the clock frequencies, because they are as high as expected—there's just fewer units available to take care of the rendering workload.
A ROP (Raster Operations Pipeline) unit in the GPU processes pixel data, handling tasks like blending, antialiasing, render-to-texture, and writing final pixel values to the frame buffer. In contrast, a shading unit, aka "GPU core" is responsible for computing the color, lighting, and material properties of pixels or vertices during the rendering process, without directly interacting with the frame buffer, so the performance hit of the eight missing ROPs depends on how ROP-intensive a game is.
For example, in Starfield, the performance loss is much smaller, and in DOOM Eternal with ray tracing, the card actually ends up close to its expected performance levels.
We've also put the card through a quick 3DMark Time Spy Extreme graphics score run.
  • NVIDIA Founders Edition: 25439
  • Zotac Solid: 22621
  • Gigabyte Gaming OC: 26220
This should be a number that you can test easily for yourself, if you're one of the lucky RTX 5090 owners. The quickest way is definitely to just fire up GPU-Z and look at the ROP count number, it should be "176."
So far, we know only of Zotac 5090 Solid cards that are affected, none of our review samples from ASUS, Gigabyte, MSI, Palit, and NVIDIA exhibit this issue, all 5090 owners should definitely check their cards and report back.
This is an issue with quality assurance at both NVIDIA and Zotac. NVIDIA's add-in card partners (AICs) do not have the ability to configure ROP counts, either physically on the silicon, or in the video BIOS, and yet the GPU, its video BIOS, and the final product, cleared QA testing at both NVIDIA and Zotac.
We are working with Zotac to return the affected card, so they can forward it to NVIDIA for investigation. At this time Zotac was unable to provide a statement, citing the fluidity of the situation. As for possible fixes. We hope the issue is localized to a bug with the driver or the video BIOS, so NVIDIA could release a user-friendly BIOS update tool that can run from within Windows and update the BIOS of the affected cards. If, however, the ROPs were disabled at the hardware-level, then there's little that end-users or even AIC partners can do, except initiating a limited product recall for replacements or refunds. If the ROPs really are disabled through fuses, it seems unlikely that NVIDIA has a way to re-enable those units in the field, because that would potentially provide details to how such units can be reactivated on other cards and SKUs from the company.
Update 14:22 UTC:
Apparently the issue isn't specific to Zotac, HXL posted a screenshot of an MSI RTX 5090D, the China-specific variant of the RTX 5090 with nerfed compute performance, but which is supposed to have 176 ROPs. Much like the Zotac RTX 5090 Solid, it has 8 missing ROPs.
Update 16:38 UTC:
Another card has been found, this time from Manli.
Update 17:30 UTC:
ComputerBase reports that their Zotac RTX 5090 Solid sample is not affected and shows the correct ROP count of 176. This confirms that the issue isn't affecting all cards of this SKU and probably not even all cards in a batch/production run.
Update 17:36 UTC:
Just to clarify, because it has been asked a couple of times. When no driver is installed, GPU-Z will use an internal database as fallback, to show a hardcoded ROP count of 176, instead of "Unknown." This is a reasonable approximation, because all previous cards had a fixed, immutable ROP count. As soon as the driver is installed, GPU-Z will report the "live" ROP counts active on the GPU—this data is read via the NVIDIA drivers.
Update 19:18 UTC:
A card from Gigabyte is affected, too.
Update Feb 22nd, 6:00 UTC:
Palit, Inno3D and MSI found to be affected as well
Update Feb 22nd, 6:30 UTC:
NVIDIA's global PR director Ben Berraondo confirmed this issue. He told The Verge:
NVIDIA said:
We have identified a rare issue affecting less than 0.5% (half a percent) of GeForce RTX 5090 / 5090D and 5070 Ti GPUs which have one fewer ROP than specified. The average graphical performance impact is 4%, with no impact on AI and Compute workloads. Affected consumers can contact the board manufacturer for a replacement. The production anomaly has been corrected.
Very interesting—NVIDIA confirms that RTX 5070 Ti is affected, too.
While NVIDIA talks about "one ROP unit," this really means "8 ROPs" in our context. Many years ago, marketing decided that higher numbers = better, so they started to report the number of pixels that can be processed per unit, instead of the actual unit counts. So in this case, one hardware unit is disabled, which mean eight pixels per clock less can be processed, resulting in a loss of "8 ROPs".
Update Feb 25th:
In the meantime, some RTX 5080 GPUs with missing ROPs were found, too, NVIDIA provided the following statement to TechPowerUp:
NVIDIA said:
Upon further investigation, we've identified that an early production build of GeForce RTX 5080 GPUs were also affected by the same issue. Affected consumers can contact the board manufacturer for a replacement.
6,151 (0.84/day)
Ikenai borderline!
System Name Firelance.
Processor Threadripper 3960X
Mouse Logitech G604
Keyboard Razer Pro Type Ultra
OMFG NVIDIA, what are you DOING?
23,365 (6.12/day)
These 5090 cards are rapidly becoming a complete meme at this point.
What the fck
Now let's imagine a fantasy world where AMD actually did release a high end offering with improved RT capability, 3x 8 pin pcie and you know, just something that's properly engineered. I know its a big ask, but... They would likely be able to make a killing.
283 (0.36/day)
Processor AMD Ryzen 7 7800X3D (4.2Ghz base, 5.0Ghz boost, -30 PBO offset)
Video Card(s) PowerColor Radeon RX 7900 XTX Red Devil OC 24GB (2.39Ghz base, 2.99Ghz boost, -30 core offset)
Mouse Logitech G502 X LIGHTSPEED Wireless Gaming Mouse
Keyboard Keychron K4 Wireless Mechanical Keyboard
Software Arch Linux
Wow, i'm greatly interested to see what the response from Nvidia/Zotac is. I highly doubt this is some cost-cutting measure because that's non-sensical, manufacturing defect maybe?
23,365 (6.12/day)
Calculated risk. These chips are expensive. What's 8 rops, hopefully customer won't notice, profit.
Its the same lame low-effort production method as what we've seen on 12VHPWR. Bare minimum, and actually, not even that. On halo products. You can't even make it up. What used to be hidden behind just the unified product lines, is now showing its true nature because these cards have crossed every line of common sense. High wattages to cover up zero progression; a new gen that offers literally nothing new, etc. A 5090 is nothing other than a cheap ass x60 except with more cores and chips around it. Everything Geforce is now in the low-effort budget segment for Nvidia.
Enjoy that thought while you pay >2000 for your graphics card.
2,406 (2.72/day)
Braziguay
Processor AMD Ryzen 7 5700X3D
Case Lian Li Lancool 216
Mouse Razer Viper Ultimate
Zotac pulling a Point of View?
According to the mentioned thread, though, using the standard MS drivers the ROP count is shown correctly, it only goes down after installing NV's drivers. What the hell is going on?
23,365 (6.12/day)
Hope the idiots users go after JHH & his bread/butter ~ this is most definitely class action lawsuit territory :rolleyes:
Technically you can't do that without at least differentiating the product(SKU) name, although a lot more depends on your national/consumer laws!
Technically you can't call 0.5GB of VRAM that runs over just 32-bit bus part of the 4GB on a GTX 970 either, but yet.. you can.
2,406 (2.72/day)
Braziguay
Let's just make Gpu-Z illegal to use. And voilà.
Nah, there's something easier. Make it so the cards don't report ROP count anymore, just like they don't report hotspot temperatures.
Out of sight, out of mind.
spladam
1 (0.00/day)
This is a very interesting story, there might be more to this. Did NVIDIA know....?
It does seem like their is a yield issue with the GB200 series chips. The supply issue and retail markup makes it feel like NVIDIA is hiding something.
1,746 (1.41/day)
System Name Raspberry Pi 7 Quantum @ Overclocked.
This is basically a scam. Imagine a scenario where Zotac decides to purchase some defective chips at a discount...
9,713 (3.27/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
Here's your 3000$ card sir.
Oh man, this keeps getting better and better.
No worries though, they got away with this before, they'll get away with it again.
7,752 (1.79/day)
1,620 (2.13/day)
France
System Name KLM
Motherboard B-650E-E Strix
Video Card(s) 4070-ti PNY
Case 4000D Airflow
Power Supply Shift 1000
Mouse 502 Hero
Keyboard K68
VR HMD Steam Deck OLED
Software EMDB
Benchmark Scores 0>1000
Somebody stolen a part !?
182 (0.04/day)
Medina, Ohio
System Name Daily driver
Processor i9 13900k
Motherboard Z690 Aorus Master
Cooling Custom loop
Memory 2x16 GB GSkill DDR5 @ 6000
Video Card(s) RTX4090 FE
Storage 2x 2TB 990 Pro SSD 1x 2TB 970 evo SSD, 1x 4TB HDD
Display(s) LG 32" 2560x1440
Power Supply beQuiet Dark Power 12 1000W
Mouse Razer Death adder
Keyboard Razer blackwidow v3
VR HMD n/a
Software Windows 11 pro
Benchmark Scores Heaven 4.0 @ 2560x1440 270.5 FPS
HOLY SHIT. melting connectors is one thing, i can look past that, but this would have me FUCKING PISSED. someone has some serious explaining to do.
3,610 (4.93/day)
Russian Wild West
Processor i5-12400F
Cooling Laminar RM1
Memory 32 GB DDR4-3200
Storage Yes.
Display(s) MSi G2712
Audio Device(s) Yes.
Software Windows 11 / 10 / 8
"We raised the prices to 1500 USD per 3090."
"Are they buying it?"
"They still are."
"Now 4090 is 1600 USD. We also shrinkflated every other SKU by a lot."
"And how are the sales?"
"Let's say profits are comfortable."
"Now 5090 is $2000 and some units miss 8 ROP. We also made lower tier SKUs even worse."
"And it still sells?"
"No idea, we only made like 15 GPUs this time."
"6090 will be..."
"Let's get it straight: either you come up with bad enough shitposting or I do that myself!"
"But sir..."
"What?"
"Let me finish. 6090 will be non-existent. We will sell 6090 Super Duper for 35 hundred dollars and it'll be available in prohibitively low amounts."
"Nah, you're fired. I'm selling this GPU division to AMD. They know how to do it."
2,406 (2.72/day)
Braziguay
1,474 (0.59/day)
Maybe it's the new SKU, and AIBs just haven't updated their marketing material?
What's the opposite of Titanium? Something that's not cutting edge tech, that's brittle and cheap?
RTX 5090 Pb?
Although lead isn't exactly cheap.
RTX 5090 Zamac?
:p
Or the opposite of Super:
RTX 5090 Awful
RTX 5090 Abysmal
Or my favourite, people might even miss the difference:
RTX 5090 Subpar
:-D
1,190 (0.78/day)
System Name Dust Collector Mower 50
Processor E5-4627 v4
Motherboard VEINEDA X99
Memory 32 GB
Video Card(s) 2080 Ti
Storage NE-512
Display(s) G27Q
Case MATREXX 50
Power Supply SF450
Just activate everything that works inside the chip, and sell it to the highest bidder using synthetic results as a scale.
14,367 (3.80/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
I was going to say the same thing. :toast:
14 (0.35/day)
System Name Windows 11 Pro & Arch Linux Dual Boot Gaming PC
Processor AMD Ryzen 7 9800X3D
Motherboard MSI MPG X870E CARBON WIFI
Cooling Lian Li Hydroshift 360 AIO
Memory G.Skill DDR5 32GB PC 6000 CL30
Video Card(s) ASUS Dual GeForce RTX 4060 OC Edition
Storage 4 x Samsung 990 PRO 1TB
Display(s) LG UltraGear 4K Gaming Monitor 27GR93U
Case Lian Li Lancool 207
Power Supply Lian Li EDGE 850w 80 Plus Platinum
Mouse Razer DeathAdder V3 Pro
Keyboard Wooting 80HE
Fake frames, fake MSRP's and now fake ROP count.
I was looking forward to this release (the 50 series in general) because my system is in need of a GPU upgrade, however, with how the release has gone I'm staying well clear of anything Nvidia!
I am now looking to switch to the AMD 9070 XT, If that should happen to turn out to be another miserable release then I'll stick to my 4060 until the next generation and turn graphics features lower were I have to.
3,610 (4.93/day)
Russian Wild West
Processor i5-12400F
Cooling Laminar RM1
Storage Yes.
