NVIDIA GeForce RTX 5090 Powered by "GB202" Silicon, 512-bit GDDR7, ASIC Pictured
47,407 (7.52/day)
Here is the first picture of what is very likely the GeForce RTX 5090 "Blackwell," the successor to the RTX 4090 "Ada." The picture, its massive GPU, and layout appear to confirm the weekend's bare PCB leak. The RTX 5090 is powered by the "GB202" silicon, the largest gaming GPU based on the "Blackwell" graphics architecture. The silicon in the picture has the ASIC code "GB202-300-A1." From this ASIC code, we can deduce that the RTX 5090 may not max out the silicon (i.e. enable all SM present on it), as maxed-out NVIDIA ASICs tend to have the variant designation "450."
The "GB202" ASIC is surrounded by sixteen GDDR7 memory chips, which reportedly make the 32 GB memory size of the RTX 5090. The chip count, coupled with the large GPU package size (high pin-count), confirm that the "GB202" features a 512-bit wide memory bus. Assuming a memory speed of 28 Gbps, this memory bus should yield a stellar memory bandwidth of 1,792 GB/s. The GPU and memory are surrounded by the card's 24-phase VRM solution. This draws power from a single 16-pin 12V-2x6 power connector. NVIDIA will likely max out the 600 W continuous power-delivery capability of the connector, and give the card a TGP of around 500-550 W, if not more.
30 (0.06/day)
System Name SigmaMATER
Processor Ryzen 7 5800x3d
Motherboard x570 Aorus Master
Cooling Arctic Freezer iii 420
Memory Corsair Dominator Platinum 32gb 3600mz c15
Video Card(s) Rx 7900 xtx
Storage Crucial P5 plus 2tb, Crucial MX500 2tb, Seagate 2tb SSHD, Western Digital 10tb Ultrastar 2x
Display(s) Predator x27 and some lenovo and some other one
Case Corsair 7000D
Power Supply Evga 1600 p2
Mouse Logitech G Pro Wireless
Keyboard Evga z20
Software Windows 11 Enterprise
that is a whole lot wider, gonna guess this will be everyone's favorite space heater.
367 (0.07/day)
System Name Matar Extreme PC.
Processor Intel Core i9-12900KS 5.2GHZ All P-Cores ,4.2GHZ All E-Cores & Ring 4.2GhZ bus speed 100.27
Motherboard NZXT N5 Z690 Wi-Fi 6E
Cooling CoolerMaster ML240L V2 AIO with MX6
Memory 4x16 64GB DDR4 3600MHZ CL15-19-19-36-55 G.SKILL Trident Z NEO
Video Card(s) Nvidia ZOTAC RTX 3080 Ti Trinity + overclocked 100 core 1000 mem. Re-pasted MX6
Storage WD black 1GB Nvme OS + 1TB 970 Nvme Samsung & 4TB WD Blk 256MB cache 7200RPM
Display(s) Lenovo 34" Ultra Wide 3440x1440 144hz G-Snyc
Case NZXT H510 Black with Cooler Master RGB Fans
Audio Device(s) Internal , EIFER speakers & EasySMX Wireless Gaming Headset
Power Supply Aurora R9 850Watts 80+ Gold, I Modded cables for it.
Mouse Onn RGB Gaming Mouse & Logitech G923 & shifter & E-Break Sim setup.
Keyboard GOFREETECH RGB Gaming Keyboard, & Xbox 1 X Controller & T-Flight Hotas Joystick
VR HMD Oculus Rift S
Software Windows 10 Home 22H2
Benchmark Scores https://www.youtube.com/user/matttttar/videos
600Watts if not more WOW looks like for those who have 850W psu and 1000W psu make sure too add a 1200+psu alongside with the 5090 order.
2,263 (1.14/day)
LV-426
System Name Custom
Processor i9 9900k
Cooling corsair h150i
Memory 4x8 3200mhz corsair
Display(s) MSi MAG341CQ
Case Lian Li Pc-011 Dynamic
Mouse Logitech G403
Keyboard Logitech G110
its very neatly packed... but wouldnt it be better if the components was more spread out... looks like the thing will run super hot...
3,516 (1.18/day)
Processor 9800X3D
Cooling DeepCool AK620
Storage 4TB Samsung 990 Pro
Display(s) 48" LG OLED C4
Case Corsair 5000D Air
Power Supply Corsair HX850
Mouse Razor Death Adder v3
Software win11
It's designed around the flow through PCB that aids the cooling performance, which in turn can make components cooler
4 (0.01/day)
CHINA
System Name NUC9I7QNX
Processor intel core i7 9750H
Motherboard intel nuc
Cooling intel nuc
Memory GLOWAY DDR4 2666 16GB*2
Video Card(s) SAPPHIRE RX6600 8G D6
Storage SAMSUNG 970EVO PLUS 1TB
Display(s) SAMSUNG Odyssey 34G852SC
Case intel NUC9 EXTREME
Audio Device(s) colorful cda m1
Power Supply FSP 500W 1U Flex
Mouse Kensington SlimBlade
Keyboard TOFU 65V2
VR HMD PICO NEO 3
它包装得非常整齐......但是,如果组件更分散不是更好吗......看起来这东西会运行得非常热......
The Graphic Card made in accordance with PCI specifications needs to control a certain volume so that it can be put into the Case. Because Of the 512bits VRam bus, the GPU package will be quite large, which will waste a large part of the space on the PCB, in fact, in this case, the electronic components can not be placed very scattered.
2,100 (0.29/day)
gehenna
System Name Commercial towing vehicle "Nostromo"
Processor 5800X3D
Motherboard X570 Unify
Cooling EK-AIO 360
Memory 32 GB Fury 3666 MHz
Video Card(s) 4070 Ti Eagle
Storage SN850 NVMe 1TB + Renegade NVMe 2TB + 870 EVO 4TB
Display(s) 25" Legion Y25g-30 360Hz
Case Lian Li LanCool 216 v2
Audio Device(s) Razer Blackshark v2 Hyperspeed / Bowers & Wilkins Px7 S2e
Power Supply HX1500i
Mouse Harpe Ace Aim Lab Edition
Keyboard Scope II 96 Wireless
Software Windows 11 23H2 / Fedora w. KDE
I have the PSU for that thingi - but I guess I will have to rob a bank before I can afford that GPU ;)
1,141 (0.24/day)
South-Africa
Processor AMD Ryzen 9 5900X
Cooling Noctua NH-D15 G2
Video Card(s) ASUS GTX 1650 TUF
Storage SAMSUNG 990 PRO 2TB
Display(s) Dell S3220DGF
Case Corsair iCUE 4000X
Yes, well, hate to be "that guy" but people that can afford these GPUs, care little for power consumed and definitely have air conditioning to not care about the heat being put out. :)
1,936 (0.61/day)
System Name BOX
Display(s) LG 27GP950-B
Mouse Logitech RX-250
Keyboard HP KB-9970
Run it at 0.5 - 0.7V voltage, and I bet it's going to be fine on 2-slot air cooling :D
5,613 (0.97/day)
System Name Cyberline
Mouse Elecom EX-G
Keyboard Rapoo V700
One of them "watercool it and put the radiator in the other room" type of deals
3,691 (2.51/day)
Slovenia
Processor i5-6600K
Motherboard Asus Z170A
Memory 16GB DDR4-2400
Video Card(s) IGP
Storage Samsung 850 EVO 250GB
Power Supply Seasonic G-360
Software Oldwin
Wires prefer to be short because that improves speed and efficiency. That's why companies take extreme efforts to design and build GPUs and AI processors in 3D (to various degrees, called 2.5D or 2.3D or 2.1D for example). Systems will only get more concentrated, not less.
True or false. If you buy one, chances are you're going to put it to work 24/7/365. That would eat up 2,400 € worth of electricity in three years where I live (at 0.15 €/kWh). Not something to ignore (but highly dependent on country/region of course).
1,936 (0.61/day)
System Name BOX
Keyboard HP KB-9970
157 (0.09/day)
Exactly the opposite. Given the hard limit on the 12vhpwr connector, with a safety factor of 1.1, the card cannot exceed its power rating.
It basically needs the same PSU as this 350w card.
553 (3.31/day)
Are you sure? Which technical device limits the short time current over a connector? Please explain.
Just enlight me about the cannot exceed its power rating statement also. Please explain.
1,029 (0.63/day)
System Name Dirt Sheep | Silent Sheep
Processor i5-2400 | 13900K (-0.02mV offset)
Motherboard Asus P8H67-M LE | Gigabyte AERO Z690-G, bios F29e Intel baseline
Cooling Scythe Katana Type 1 | Noctua NH-U12A chromax.black
Memory G-skill 2*8GB DDR3 | Corsair Vengeance 4*32GB DDR5 5200Mhz C40 @4000MHz
Video Card(s) Gigabyte 970GTX Mini | NV 1080TI FE (cap at 50%, 800mV)
Storage 2*SN850 1TB, 230S 4TB, 840EVO 128GB, WD green 2TB HDD, IronWolf 6TB, 2*HC550 18TB in RAID1
Display(s) LG 21` FHD W2261VP | Lenovo 27` 4K Qreator 27
Case Thermaltake V3 Black|Define 7 Solid, stock 3*14 fans+ 2*12 front&buttom+ out 1*8 (on expansion slot)
Audio Device(s) Beyerdynamic DT 990 (or the screen speakers when I'm too lazy)
Power Supply Enermax Pro82+ 525W | Corsair RM650x (2021)
Mouse Logitech Master 3
Keyboard Roccat Isku FX
VR HMD Nop.
Software WIN 10 | WIN 11
Benchmark Scores CB23 SC: i5-2400=641 | i9-13900k=2325-2281 MC: i5-2400=i9 13900k SC | i9-13900k=37240-35500
512 bit will be the challenge, I think AMD did something like that way back with the R9 290X and it lead to a very hot pcb layout.
Anyway, this GPU hyper performance will be only matched by its unattainable cost.
13,430 (6.13/day)
Midlands, UK
Cooling Yes
Storage A lot
Display(s) Monitors and TVs
Case The smaller the better
Mouse Wireless
Keyboard Mechanic
VR HMD Not yet
This thing is massive. Expect prices in the $2000 range. It's only GeForce in name now.
Ruru
S.T.A.R.S.
13,158 (2.98/day)
Jyväskylä, Finland
Processor AMD Ryzen 7 5800X / Intel Core i7-8600K
Audio Device(s) Sony WH-CN720N / TV speakers
VR HMD Oculus Rift CV1
I wouldn't be surprised that if it starts from 2500EUR (incl. VAT). Even the cheapest 4090 cards are still starting from 2055EUR here.
1,231 (1.22/day)
It's always been GeForce in name only for the Titan and X090 series. It's a prosumer card for data stuff at home hence the specs especially VRAM. 2000 even 4000 is still cheap to that crowd. The heat doesn't matter nor does the power consumption as really what these are going to see is the same as the 4090 and prior cards. 4-8 of them slapped into a box with waterblocks (Camino had those out before we knew the cards specs and was taking orders) dual PSUs, Threadripper/Xeon platforms with massive internal radiators or what's becoming the norm ports out to external radiators with the option for a rackmount of the same product.
All the way back to the 8800gtx nvidia was stating CUDA was their future. When the first Titan hit the selling point was it's use in professional instances it wasn't until companies like Falcon NW decided it was SLI in a card slammed into an ITX case and people like Linus started buying them up that it being a "gaming" card took hold.
GeForce doesn't even really mean gaming. Tons of companies deploy GeForce based laptops that will never game but use the GPUs for other professional things that do not need the Quadro drivers or the price associated with those.
wolf
Better Than Native
8,336 (1.29/day)
System Name MightyX
Processor Ryzen 9800X3D
Motherboard Gigabyte X650I AX
Cooling Scythe Fuma 2
Memory 32GB DDR5 6000 CL30
Video Card(s) Asus TUF RTX3080 Deshrouded
Storage WD Black SN850X 2TB
Display(s) LG 42C2 4K OLED
Case Coolermaster NR200P
VR HMD Meta Quest 3
The Titan(s), for whatever cumulative reasons but surely price for one, didn't sell well enough apparently.
Reintroduce that tier of card as a XX90 and start the price lower, then gradually ratchet it up.
411 (0.26/day)
Texass
System Name EXTREME-FLIGHT SIM
Processor AMD RYZEN 7 9800X3D 4.7GHZ 8-core 120W
Motherboard ASUS ROG X670E Crosshair EXTREME BIOS V.2506
Cooling be quiet! Silent Loop 2 360MM, Light Wings 120 & 140MM
Memory G. SKILL Trident Z5 RGB 32MBx2 DDR5-6000 CL32/EXPOⅡ
Video Card(s) ASUS ROG Strix RTX4090 O24
Storage 2TB CRUCIAL T705 M.2, 4TB Seagate FireCuda 3.5"x7200rpm
Display(s) Samsung Odyssey Neo G9 57" 5120x1440 120Hz DP2.1 #2.Ulrhzar 8" Touchscreen(HUD)
Case be quiet! Dark Base Pro 900 Rev.2 Silver
Audio Device(s) ROG SupremeFX ALC4082, Creative SoundBlaster Katana V2
Power Supply be quiet! Dark Power Pro 12 1500W via APC Back-UPS 1500
Mouse LOGITECH Pro Superlight2 and POWERPLAY Mouse Pad
Keyboard CORSAIR K100 AIR
Software WINDOWS 11 x64 PRO 23H2, MSFS2020-2024 Aviator Edition, DCS
Benchmark Scores fast and stable AIDA64
Already there with RTX4090. Another 150watts? I'm gonna need a bigger fan for the "Sim" room. Maybe a ceiling fan. We'll cross that bridge when we come to it.
157 (0.09/day)
It's all about the reliability of the new connector which wasn't a thing back in the days with 6+2 pci-ex connectors.
Nvidia already hard locked the power draw, spikes wise, on the 4090 when you bring the PL to 600w.
Nvidia barely took advantage of the pci-express slot power delivery on the RTX 4000 serie, they could bring it back with an additional ~50w contribute from it. But it isn't a game changer and they probably stopped using it as a safety measure.
1,686 (0.23/day)
Maribor, Slovenia, EU
System Name Core i9 rig / Lenovo laptop
Processor Core i9 10900X / Core i5 8350U
Motherboard Asus Prime X299 Edition 30 / Lenovo motherboard
Cooling Corsair H115i PRO RGB / stock cooler
Memory Gskill 4x8GB 3600mhz / 16GB 2400mhz
Video Card(s) Asus ROG Strix RTX 2080 Super / UHD 620
Storage Samsung SSD 970 PRO 1TB / Samsung OEM 256GB NVMe
Display(s) Dell UltraSharp UP3017 / Full HD IPS touch
Case Coolermaster mastercase H500M
Audio Device(s) Onboard sound
Power Supply Enermax Platimax 1700 watt / Lenovo 65watt power adapter
Mouse Logitech M500s
Keyboard Cherry
Anyone got an idea how much a 5090 will cost?
6,822 (1.40/day)
Case NZXT PHANTOM410-BK
Power Supply Corsair 850W
Mouse Logitech Hero G502 SE
3,516 (1.18/day)
Processor 9800X3D
Software win11
Oh well my 4090 churns through games @ 4K barely using 250-300W (stock FE clocks & undervolted). Not sure if the 5090 will even break a sweat running today games @ locked 4K 144hz, would definitely need a 4K 240hz monitor to stress the 5090.
