Nvidia GTX 960 GPU core clock stucked at 135 MHz, please help me!
Errickson
7 (0.00/day)
Hello,
I am facing a problem with my desktop's GPU Nvidia GTX 960 4gb.
whenever I tried playing the game or in idle, the core stuck at 135mhz. I have already tried uninstalled and installed back the GPU driver but the problem doesn't solve.
it makes my gaming experience worst because of the fps is below 30 although the setting is low!
This is my pc's specs:
Asrock A320M-HDV
ryzen 3 2200g
8gb ddr4 ram hyperX
120gb adata SSDx2
psu 550w
GTX 960 4gb
benq 27inch monitor
18,584 (2.64/day)
System Name AlderLake
What happens when you set windows powerplan to ultimate or maximum performance?
9,793 (3.25/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
Use GPU-z and post a screenshot of the sensors tab.
61 (0.02/day)
Processor Intel core i5 6600k@4.5ghz
Motherboard Msi Z270 Carbon
Cooling Cooler Master T20
Memory Corsair lpx 16gb 2666mhz
Video Card(s) Zotac gtx 1070 8GB
Storage 1tb toshiba hdd Adata su 240gb ssd
Display(s) LG 34UC97 1440P
Power Supply Green gp550a gold
Software Win 10
If you updated windows or drivers recently
You could try the windows recovery options to restore your pc to a point before the update
9,793 (3.25/day)
Case Phanteks NV7
That's what I was afraid of. It's that nasty TDP bug that makes the card down clock itself, see that 105% TDP ? That's your problem.
Here's a thread about this, I don't know how to fix this myself. Unfortunately it's unlikely you'll ever have a perfectly functioning card again.
I believe one last resort would be something called a shuntmod, look it up. I don't know if it will really work and I can't really recommend you try this but there is nothing to lose at this point I guess.
23,723 (6.15/day)
Its dead. This 'TDP bug' (its not a bug, its a feature, I kid you not) is Nvidia's way of saying that while still giving you a way to get a picture on screen.
You can try the fix above, maybe you can revive it for some last gasps of life, but don't expect too much.
44,183 (6.80/day)
What brand of psu?
Also have you tried cleaning the card heatsink and fan?
Have you replaced the thermal paste?
Sounds like a fuse to break the card.
Errickson
7 (0.00/day)
What brand of psu?
sorry for the late reply, my PSU brand is thermaltake litepower 550w.
I don't know how to clean the card heatsink and fan, and I don't know when is the last time the thermal paste has been replaced since this gpu is a used one.
44,183 (6.80/day)
Go on youtube, look for videos
Mmostafa
4 (0.00/day)
Hi , i have the same issue here with my gtx 770 msi oc
It get stuck in 135 mhz
Please tell me if you solved your problem
2,019 (0.62/day)
System Name BOX
Display(s) LG 27GP950-B
Mouse Logitech RX-250
Keyboard HP KB-9970
Check GPU-z, if you also have "Pwr" as limiting factor, your shunt resistor (or power measuring circuit) may be damaged.
You can try vBIOS mod to let more power go into the card (ex. 300-500W), BUT if it's damaged trace - higher current/power limit may cause a short and kill the card permanently.
Mmostafa
4 (0.00/day)
Sorry made a mistake this is without playing a game idle mode
8,245 (2.10/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
Afterburner pic shows that the fan control profile is off, shows 0 fan speed, turn that on and also add 'fan speed %' graph so you can verify the fans are spinning.
This reminds me that this could be a power saving feature, that down clocks the card unless its actually being used by an app.
i have a game running in the back ground so you can see the gpu usage.
rtwjunkie
PC Gaming Enthusiast
14,034 (2.30/day)
Louisiana
Processor Core i9-9900k
I had this problem about a year ago with a 960, after the driver failed while overclocking. Literally a complete uninstall of the driver and a reinstall helped. I know you say you did that but it might not have fully uninstalled.
Try installing a different driver as well. Did you by any chance have an AMD card installed prior?
23,723 (6.15/day)
Another good way to 'reset' your GPU is to remove the device from device manager in Windows. You do need a secondary GPU or IGP then. Remove device and drivers, and then clean install the driver. If that doesn't fix, you will have to look at hardware fixes as mentioned.
Mmostafa
4 (0.00/day)
While playing a game
Plz help me any one who has faced this issue befor and fix it
I did everything reinstall gtx 770 drivers update and install old drivers update widows from 7 to 10
Update VBIOS of gpu nothing worked
LSC Gaming
1 (0.00/day)
Otherwise, there is Display Driver Uninstall, it's a good application to clean all GPu or audio drivers (optional). Just download the Nvidia drivers, use the app (two three black screens) and reinstall the Nvidia driver
23,723 (6.15/day)
Stuck in idle means the card is going into safe mode to keep it 'alive'; or put differently, to still give you an image while being (probably) broken or otherwise unable to achieve higher power states without instability.
This also happens when your OC goes poof. But if it happens on stock, like I said, if software reset doesn't work, your only resort is a small chance for fixing it on the PCB of the card itself with a hardware/shunt mod. Note that this is not a beginner's fix either. Needs some soldering skill probably, too, and results are uncertain.
I can tell you right now though, this ain't software. Its likely your card is dead or dying. Your screenshot while playing shows an idle clock while the perfcap is 'Pwr', in other words, the GPU is unable to get to a higher power state than idle, even though more performance is requested.
Mmostafa
4 (0.00/day)
Thank you mate that's what i thought i was just searching for a confirmation that my gpu is dying tnx
Tatty_Two
Gone Fishing
26,019 (3.70/day)
Worcestershire, UK
Software Win 11 Home x64
Hmmm, interested to know how a 770 is pulling 400W at idle and 410 at load according to the GPU screenies at posts #15 and 19. If that's the bug it has it bad, other guy was worried at 137.5% TDP where this one is 152 ...… sadly I concur, RIP I reckon.
23,723 (6.15/day)
Basically that is what you see throughout the entire sensor log if you monitor TDP on a GPU like this, and also points at power delivery problems. The number doesn't really say anything other than 'its broken'
Tatty_Two
Gone Fishing
26,019 (3.70/day)
Worcestershire, UK
Dunno if this would help, I came across it by accident looking for something else...…………..
