NVIDIA RTX 4080 12GB and 16GB Based on Different Chips, Vastly Different Shader Counts
47,293 (7.53/day)
When we first got news about NVIDIA's upcoming GeForce RTX 4080 "Ada" coming in 12 GB and 16 GB variants, we knew there was more setting the two apart than just memory size and memory bus-width. Turns out there's a lot more. According to detailed specifications leaked to the web, while the 16 GB variant of the RTX 4080 is based on the same AD103, the second largest chip after the AD102; the 12 GB RTX 4080 is based on the smaller AD104 chip which has a physically narrower memory bus.
It looks like NVIDIA is debuting the RTX 40-series with at least three models—RTX 4090 24 GB, RTX 4080 16 GB, and RTX 4080 12 GB. The RTX 4090 is the top-dog part, with the ASIC code "AD102-300-xx." It's endowed with 16,384 CUDA cores, a boost frequency of up to 2.52 GHz, 24 GB of 21 Gbps GDDR6X memory, and a typical graphics power (TGP) of 450 W, which is "configurable" up to 600 W. The RTX 4080 16 GB is based on the AD103-300-xx" comes with 9,728 CUDA cores, a boost frequency of 2.50 GHz, and 16 GB of 23 Gbps GDDR6X memory across a narrower memory bus than the one the RTX 4090 comes with. This card reportedly has a 340 W TGP configurable up to 516 W.
The GeForce RTX 4090 12 GB is positioned a notch below its 16 GB namesake, but is based on the smaller AD104 chip, with 7,680 CUDA cores running at speeds of up to 2.61 GHz, 12 GB of 21 Gbps GDDR6X memory, and a TGP of 285 W that's configurable up to 366 W. It's interesting how the leak includes not just TGP, but also maximum configurable TGP. The various board partners will utilize the latter as their power limits to achieve overclocked speeds. Even the NVIDIA Founders Edition board is technically "custom design," and so it could feature higher-than-stock TGP.
6,959 (3.03/day)
California
System Name His & Hers
Storage lots of SSD.
Just looking at specs the lower tier 4080 looks like it should be a 4070ti or oem only varient....
Never been a huge fan of two different skus carrying the same name though.
18,584 (2.68/day)
System Name AlderLake
I guess you mean the RTX 4080 12GB....
567 (0.42/day)
System Name Jedi Survivor Gaming PC
Processor AMD Ryzen 7800X3D
Motherboard Asus TUF B650M Plus Wifi
Cooling ThermalRight CPU Cooler
Memory G.Skill 32GB DDR5-5600 CL28
Video Card(s) MSI RTX 3080 10GB
Storage 2TB Samsung 990 Pro SSD
Display(s) MSI 32" 4K OLED 240hz Monitor
Case Asus Prime AP201
Power Supply FSP 1000W Platinum PSU
Mouse Logitech G403
Keyboard Asus Mechanical Keyboard
These are tricks to keep nVidia's outrageous 67 percent gross margin going (or at least attempt to keep the good times going for them, not for us).
RTX 3080 used the top 102 chip, if the 4080 12GB uses AD104 instead of 103 or 102, you are actually paying the same money for 2 tiers lower performance in the stack compared to last gen.
18,584 (2.68/day)
If the performance is there, I have no issues with it, even consuming less power....
6,959 (3.03/day)
California
I agree, if the 4080 is 30-40% faster at the same ish price as the 3080 it'll be fine.
The 600, 700, 1000, 2000 non ti 80 series cards all used the 104 die. Ampere was the first time since the GTX 580 that we got above that for a 80 non ti tiered card.
585 (0.14/day)
"Buy a 4080 today! Starting at $699.99."
Back in the day, these "4080"'s would have been a 4070. Now they want to charge more without saying they've once again upped the price on the tiers, so they're disguising it by calling it a 4080. Far from "who cares if it performs," I'd care because they're charging you more for the performance tier they would have sold you in prior generations for less because it would have been designated a lower tier. This way, they get to reduce tier relative performance because if THIS is considered a 4080 then imagine the 4070 below it. Or the 4060 below that.
5,569 (0.96/day)
System Name Cyberline
Mouse Elecom EX-G
Keyboard Rapoo V700
Sure you can say people buying a gpu will be tech savy enough, but I still feel this is done just to confuse and borderline scam people.
They are already doing too many SKU's but to then also have different versions of cards with the same name.
And yes I know both AMD and Nvidia have done this in the past (which I hated then as well), this needs to stop honestly.
Reviewers now have a lot more work telling people how each version of teh same gpu performs....
982 (0.22/day)
System Name Poor Man's PC
Processor Ryzen 7 9800X3D
Cooling Thermalright Phantom Spirit 120 with Arctic P12 Max fan
Display(s) Xiaomi G Pro 27i MiniLED
Case Asus A21 Case
Mouse Logitech MX Anywhere 3
VR HMD Meta Quest 2
Which one utilize PCIe Express x8?
11,878 (2.20/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
Ad106 afaik not these.
Don't like this personally and they're is likely to be a performance disparity between the 12/16GB parts, how could there not be?!.
Low quality post by Arco
488 (0.58/day)
System Name Firestarter
Processor 7950X
Motherboard X670E Steel Legend
Cooling LF 2 420
Memory 4x16 G.Skill X5 6000@CL36
Video Card(s) RTX Gigabutt 4090 Gaming OC
Storage SSDS: OS: 2TB P41 Plat, 4TB SN850X, 1TB SN770. Raid 5 HDDS: 4x4TB WD Red Nas 2.0 HDDs, 1TB ext HDD.
Display(s) 42C3PUA, some dinky TN 10.1 inch display.
Case Fractal Torrent
Audio Device(s) PC38X
Power Supply GF3 TT Premium 850W
Mouse Razer Basilisk V3 Pro
Keyboard Steel Series Apex Pro
VR HMD Pimax Crystal with Index controllers
488 (0.58/day)
Processor 7950X
Cooling LF 2 420
Why not just call it a 4070ti and avoid confusion, unless it's the aim.
Always the aim, why not make 30 cards with very similar names and then make people get an inferior card.
797 (0.53/day)
Lol regarding model rumors for full AD104, we went from RTX 4070 12GB (best case) to RTX 4080 12GB (worst case)
So from 3070 successor ($499) we went to 3080 successor ($699) skipping 3070Ti successor ($599) price level entirely.
So I don't know what pricing level this rumor suggests, maybe something like the below scenario:
$999-$799 16GB cut-down AD103 based
$799-$649 12GB Full AD104 based
$649-$499 10GB cut-down AD104 based
If true, pricing seems to be getting worst by the day!
488 (0.58/day)
Processor 7950X
Cooling LF 2 420
Oof, do the black Friday deals change the prices at all much?
797 (0.53/day)
Don't take too seriously the rumors (and more so the prices I quoted since I don't have any info and the reply was spontaneous without much though)
In less than one week, we will probably have the real deal from Nvidia themselves at GTC.
488 (0.58/day)
Processor 7950X
Cooling LF 2 420
Yeah, the rumor mill going strong. Personally, I'm building my first setup on Black Friday to get the best deals I can. When are we going to get 6 slot coolers or better yet.
289 (0.06/day)
Processor i5 4670K @4.4GHz 1.239V
Motherboard Asus Z87M-PLUS
Cooling High Pressure Fan System
Memory 24GB DDR3 2400MHz
Video Card(s) AMD R9 290 4GB
Storage 256GB Samsung 830, 500gb WD Blue 7200rpm
Display(s) 23inch Dell LCD
Case Silverstone Sugo SG10B
Power Supply Antec TP-750
Another generation of GPUs I won't be buying because it costs more than my mortgage.
I don't know why people buy them at this price. £250 maximum is a sensible amount to spend on a GPU in mh opinion.
488 (0.58/day)
Processor 7950X
Cooling LF 2 420
If my build wasn't delayed like 2 years that would be the case for me. But I have to buy basically another setup excluding mic, mouse, and keyboard. So I might as well go insane and get a great setup with upgrade options. (Due to AM5, ATX3.0, DDR5, and PCIE5.)
8,217 (2.16/day)
SE Michigan
System Name Dumbass
Power Supply Corsair HX1000i
Software windows 10 H
I have to agree with the 12GB that it should be labeled a 3070/Ti, calling it a 3080 is more like a bait and switch cash grab. :shadedshu:
929 (0.62/day)
System Name 1. Glasshouse 2. Odin OneEye
Processor 1. Ryzen 9 5900X (manual PBO) 2. Ryzen 9 7900X
Motherboard 1. MSI x570 Tomahawk wifi 2. Gigabyte Aorus Extreme 670E
Cooling 1. Noctua NH D15 Chromax Black 2. Custom Loop 3x360mm (60mm) rads & T30 fans/Aquacomputer NEXT w/b
Memory 1. G Skill Neo 16GBx4 (3600MHz 16/16/16/36) 2. Kingston Fury 16GBx2 DDR5 CL36
Video Card(s) 1. Asus Strix Vega 64 2. Powercolor Liquid Devil 7900XTX
Storage 1. Corsair Force MP600 (1TB) & Sabrent Rocket 4 (2TB) 2. Kingston 3000 (1TB) and Hynix p41 (2TB)
Display(s) 1. Samsung U28E590 10bit 4K@60Hz 2. LG C2 42 inch 10bit 4K@120Hz
Case 1. Corsair Crystal 570X White 2. Cooler Master HAF 700 EVO
Audio Device(s) 1. Creative Speakers 2. Built in LG monitor speakers
Power Supply 1. Corsair RM850x 2. Superflower Titanium 1600W
Mouse 1. Microsoft IntelliMouse Pro (grey) 2. Microsoft IntelliMouse Pro (black)
Keyboard Leopold High End Mechanical
I think we need to stop seeing the 4080 as being a direct replacement upgrade for the 3080. It's not. It won't be. It's marketing. Whatever Nvidia chooses to name a GPU it should be reviewed on price for performance alone.
Ruru
S.T.A.R.S.
12,958 (2.95/day)
Jyväskylä, Finland
System Name 4K-gaming / media-PC
Processor AMD Ryzen 7 5800X / Intel Core i7-6700K
Motherboard Asus ROG Crosshair VII Hero / Asus Z170-K
Cooling Arctic Freezer 50 / Alphacool Eisbaer 240
Storage 3.3TB of SSDs / several small SSDs
VR HMD Oculus Rift CV1
Truly some ugly mismarketing. I feel bad for those who doesn't know that much about computers, and gets the cheaper one just because "12GB is fine for me" and the card is actually way slower than the similarly named one.
