NVIDIA RTX 4090 "Ada" Founders Edition Cooler Spied, Retains Dual-Axial Flow-Through Design
47,421 (7.51/day)
In what is a sign that the July 2022 rumored debut of NVIDIA GeForce RTX 4090 "Ada Lovelace" graphics card is on track; the first spy pictures of its Founders Edition cooler surfaced on ChipHell forums. The cooler appears to be an evolution of the Dual-Axial Flow-Through cooling architecture NVIDIA debuted with the RTX 30-series "Ampere" Founders Edition cards, where air is drawn in from one end of the card, flows through the cooling solution that's a series of aluminium fin-stacks skewered by a series of heatpipes; and ventilated through the back of the card, with a second fan in "pull" configuration.
From the looks of it, the aluminium fins on the RTX 4090 Founders Edition cooler appears to have a dark-grey matte finish, which could indicate some form of ceramic surface-treatment that improves heat-dissipation; while the cooler's base making primary contact with the GPU and memory chips, appears to be a vapor-chamber plate with a nickel-plated copper surface. From the location and sizes of the thermal pads for the memory chips, we guess that the GPU is surrounded by 10 memory chips, which could indicate a 320-bit memory interface, making this card a possible successor to the original RTX 3080. The cooler itself is more than 2 slots thick, and appears to be as thick as the RTX 3090 FE cooler.
qubit
Overclocked quantum bit
17,865 (2.86/day)
Quantum Well UK
System Name Quantumville™
Cooling Noctua NH-D14
Case Cooler Master HAF 922
Power Supply Corsair AX1600i
Keyboard Yes
The styling makes it look like a beast of a cooler.
8,223 (2.14/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
270 (0.06/day)
Canada
System Name custom
Processor intel i7 9700
Motherboard asrock taichi z370
Cooling EK-AIO 360 D-RGB
Memory 24G Kingston HyperX Fury 2666mhz
Video Card(s) GTX 2080 Ti FE
Storage SSD 960GB crucial + 2 Crucial 500go SSD + 2TO crucial M2
Display(s) BENQ XL2420T
Case Lian-li o11 dynamic der8auer Edition
Audio Device(s) Asus Xonar Essence STX
Power Supply corsair ax1200i
Mouse MX518 legendary edition
Keyboard gigabyte Aivia Osmium
VR HMD PSVR2
Software windows 11
6,144 (2.85/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
I sure hope they do a better job cooling that GDDR6X.
Deleted member 24505
What a stupid looking cooler. Can't believe people are happy to have these turds in their rigs. I'll stick to my single slot water block thx
6,144 (2.85/day)
Poland
Given the market situation for the past two years it was the only viable option for some users. It's good enough, it could be improved with better heat transfer between memory chips.
dgianstefani
TPU Proofreader
5,194 (2.01/day)
Swansea, Wales
System Name Silent/X1 Yoga
Benchmark Scores Legendary
I think the FE design is very tasteful and aesthetic. Many people do. I am surprised though they didn't really change it in the new generation, normally it's updated.
The only reason they have to have such stupid sized coolers on GPUs now is they just can't stop making them consume such idiotic amounts of power. Whatever GPU I use, I will always put a water block on it instead of one of these massive lumps in my case spewing 400+ watts of heat into the case.
Tasteful :laugh:
ppn
1,231 (0.36/day)
looks like 4+4+3 memory chips. but I can't see it as 10.
18,013 (2.44/day)
Will Nvidia include a GPU support in the box?
Tasteful :laugh:
Careful, if someone brings out a more efficient GPU that comes with a "basic" looking cooler, people won't buy it, because it can't be good because it has a tiny cooler.
2,615 (1.99/day)
Tasteful :laugh:
Actually one of the things the FE coolers did well this generation was spew a fair ammount of the heat directly out the case like a blower card would do. Was a pretty nice design for an air cooled card all things considered (not counting for cooking the gddr on the back in the case of the original 3090 but Ti fixed that at least :D)
18,013 (2.44/day)
8,223 (2.14/day)
SE Michigan
System Name Dumbass
Just spoke to someone in the "industry" that mentioned that there will be 4.5 slot cards.
J.F.C.
Guess the mini crowd will be crying about that. :cry:
209 (0.14/day)
Tasteful :laugh:
Wouldn't that be the case with a waterblock + intake radiator as well?
18,013 (2.44/day)
8,223 (2.14/day)
SE Michigan
System Name Dumbass
6,144 (2.85/day)
Poland
819 (0.53/day)
Isn't AD103 256bit memory bus design according to leaks?
So if we are talking for 10 memory ICs or more, this would be AD102 based, a cut down version of AD102 and if the cooler appears to be as thick as the RTX 3090 FE cooler, then are we going to have a cut down AD102 at maybe 350-360W or this is too optimistic?
Edit: i just read the article, so according to Videocardz report this is 4090 and according to Wccftech 4090ti? Does the cooler appear to you to be only as thick as the RTX 3090 FE cooler?
2,977 (1.15/day)
System Name System V
Processor AMD Ryzen 5 3600
Motherboard Asus Prime X570-P
Cooling Cooler Master Hyper 212 // a bunch of 120 mm Xigmatek 1500 RPM fans (2 ins, 3 outs)
Memory 2x8GB Ballistix Sport LT 3200 MHz (BLS8G4D32AESCK.M8FE) (CL16-18-18-36)
Case NZXT Source 210
Power Supply Corsair CX650M
Benchmark Scores Corona 1.3: 3120620 r/s Cinebench R20: 3355 FireStrike: 12490 TimeSpy: 4624
Well, why not just bundle a PSU with the GPU too, while we're at it? holy crap lol
18,013 (2.44/day)
3,222 (2.40/day)
Processor Ryzen 5 5700x
Motherboard B550 Elite
Power Supply MSI 750w
Mouse G502
Either the dude has really small hands or it's one enormous beast.
"I think we need a bigger case"
1,147 (0.24/day)
South-Africa
Processor AMD Ryzen 9 5900X
Cooling Noctua NH-D15 G2
Video Card(s) ASUS GTX 1650 TUF
Storage SAMSUNG 990 PRO 2TB
Display(s) Dell S3220DGF
Case Corsair iCUE 4000X
Mmm yes, those were my first thoughts as well. nVidia's new coolers are good, but they still have room for improvement. I just hope board partners and nVidia would stop using cheap thermal pads on their GPU coolers in the future.
