NVMe advice
5,223 (3.74/day)
Colorado, U.S.A.
Software Windows 11 Home
I've recently gone from
  • Core 2
  • Windows 10
  • HDD
to
  • Intel i5 10th generation
  • Windows 11
  • MSI Nvidia GeForce GTX 1660 Super
  • 16GB DDR4
  • NVMe M.2
Now I ask advice on which NVMe and size (I presently have a Western Digital Blue 512 GB at 98% life), and any other update advice (I don't game a lot); reliability is a big thing for me, so any form of over-clocking is out, and speed is not an issue (I would have stuck with the Core 2 if it wasn't for not being able to upgrade to Windows 11).
FreedomEclipse
~Technological Technocrat~
24,302 (3.75/day)
London,UK
System Name WorkInProgress
Processor AMD 7800X3D
Display(s) LG GP850-B
Mouse Logitech G502 X
Benchmark Scores ლ(ಠ益ಠ)ლ
Cant go wrong with an 1TB WD SN770. The price for that is always very competitive from what i've seen.
5,223 (3.74/day)
Colorado, U.S.A.
The 2 TB version is the same price ($140) between the
  • WD Black SN770
  • WD Black SN850X
would this change your recommendation?
933 (0.14/day)
Round Rock, TX
Processor 9950x
Motherboard Asus Strix X870E-E
Cooling Kraken Elite 280
Memory 64GB G.skill 6000mhz CL30
Video Card(s) Sapphire 7900XTX Pulse
Storage 1X 4TB MP700 Pro - 1 X 4TB SN850X
Display(s) LG 32" 4K OLED + LG 38" IPS
Case Lian Li o11 Air Mini
Power Supply Corsair RM1000x
Software WIndows 11 Pro
If they are the same price i'd go with the SN850X since it has DRAM and the SN770 does not.
...You'd probably never be able to tell the difference in day to day use, but hey they are the same price as you say.
1,034 (0.66/day)
System Name ASUS TUF F15
Processor Intel Core i7-11800H
Motherboard ASUS FX506HC
Cooling Laptop built-in cooling lol
Memory 24 GB @ 3200
Video Card(s) Intel UHD & Nvidia RTX 3050 Mobile
Storage Adata XPG SX8200 Pro 512 GB
Display(s) Laptop built-in 144 Hz FHD screen
Audio Device(s) LOGITECH Z333 2.1-channel
Power Supply ASUS 180W PSU
Mouse Logitech G604
Keyboard Laptop built-in keyboard
Software Windows 10 Enterprise 20H2
  • WD Black SN770
  • WD Black SN850X
850X is faster. No brain for same price. However, radiator recommended. I have 770. In desktop: works perfectly without radiator; in laptop: radiator is a must-have!
Speeds are Okay but as you said "one price" definitely get better 850X.
5,223 (3.74/day)
Colorado, U.S.A.
The price I quoted was without heatsink (mine is a desktop application)
Is DRAM cache a good idea, in the sense of corruption if there is a power cut? I'm for reliability over speed.
9,580 (3.44/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
The price I quoted was without heatsink, so I now wonder if the heatsink is a good idea (Desktop application)
If your board already has a heatsink it is redundant.
174 (0.33/day)
France
System Name the thing / shit pc
Processor r5 7500f / fx 8350
Motherboard b650 LIveMixer / 990x evo r2
Cooling assassin x 120 se / stock crap w/ 92mm fan
Memory 32gb @6400mt.s cl32 / 16gb
Video Card(s) 6700 xt / w2100
Storage 6.5 tb on 8 drives / 2tb on 4 drives
Case silencio 550 / focus g
Audio Device(s) DT 990 Pro 250 ohm, scarlett 2i2 3rd gen
Power Supply straight power 11 750w / cooler master thingy 550w
Mouse g502
Keyboard corsair something
Benchmark Scores slower than your phone
you could diy something like put caps (capacitors) on the power line on m.2 slot using some kind of middle board that would stick to the mobo between the mobo and the ssd.
I wouln't do this since caps are very sensitive to heat (from what i've seen), as i wouldn't have complete control over temps.
4,762 (0.96/day)
in a van down by the river
Cooling frostier than yours
Storage more ample than yours
Case fancier than yours
Benchmark Scores up yours
  • WD Black SN770
  • WD Black SN850X
SN580 blue is often hard to beat for the price and performance, seems SSD have been increasing in price the last several months from the low fall prices
freeagent
9,277 (4.01/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
I run SN850, SN850X, and SN770. I am satisfied with everything about them. I also have SN750’s running in another system, all good.
tabascosauz
8,203 (2.35/day)
Western Canada
System Name ab┃ob
Processor 7800X3D┃5800X3D
Storage 8TB of SSDs┃1TB SN550
Case Caselabs S3┃Lazer3D HT5
  • WD Black SN770
  • WD Black SN850X
I would not pay a significant premium for the SN850X, but no way I would take the SN770 for the same price. They aren't even close to the same tier. SN770 is a fine representation of what a modern DRAMless drive can achieve, but it's a DRAMless drive.
Any ol' cheap heatsink or motherboard heatsink works fine for the SN850X. Thermally there isn't a crazy difference between most of WD's drives in day-to-day.
There are plenty of other options out there, but as someone who had to RMA a SN750, it's just easy to deal with WD support. SN550, SN570, SN750, SN850X all treated me well, but the SN750 was a bit slow.
3,694 (2.51/day)
Slovenia
Processor i5-6600K
Motherboard Asus Z170A
Memory 16GB DDR4-2400
Video Card(s) IGP
Storage Samsung 850 EVO 250GB
Power Supply Seasonic G-360
Software Oldwin
The onboard DRAM is is not a write cache. It holds a copy of the drive's FTL and possibly other metadata, which is permanently stored in NAND memory. In that sense, it's a read cache.
3,399 (1.09/day)
Cooling Noctua NH-D15 Chromax
Memory 32GB DDR5 6000 CL30
Case Thermaltake Core X9
Mouse PMM P-305
Keyboard Wooting HE60
VR HMD Valve Index
Software Win 10
Unless the SSD specifically advertises PLP (power loss prevention), there is always a chance of data corruption during a power event. There are only a few consumer SSDs that offer PLP while it's very common in the enterprise space.
5,223 (3.74/day)
Colorado, U.S.A.
It's getting to feel a lot like Christmas.
Now that I finally have a Windows 11 machine, I may, perhaps, could be... stop hankering on about Windows 10
3,694 (2.51/day)
Slovenia
Processor i5-6600K
Video Card(s) IGP
Software Oldwin
Also don't forget about the WD Red SN700. About the same price as the 850X, older, lower performance (PCIe 3.0), but great TBW rating.
5,223 (3.74/day)
Colorado, U.S.A.
$202 is quite a bit up on $140 for 2TB although the higher endurance is very tempting.
  • WD Black SN770 $140
  • WD Black SN850X $140
  • WD Red SN700 $202
  • WD Blue SN580 $120
tabascosauz
8,203 (2.35/day)
Western Canada
System Name ab┃ob
Is that 2TB vs. 2TB? or 4TB SN700?
I wouldn't put too much stock in the SN700 endurance rating unless you are literally torturing your drive with writes to actually make use of it. Otherwise it's a nice refreshed SN750 which is a solid drive, but only for the right price.
It's made for the long run in performance too, so if you're transferring huge files all the time then great, but performance is rather low if that's not what you're doing. SN750 didn't exactly impress in performance, even when it was new. The efficiency isn't bad, but is basically irrelevant outside of laptops.
5,223 (3.74/day)
Colorado, U.S.A.
All 2TB, unless I made a mistake (amazon.com); the 4TB Red SN700 is $330
The SN750 does not seem available (on amazon.com); I have an SN550 500GB at the moment.
418 (1.75/day)
System Name Kuro
Processor AMD Ryzen 7 7800X3D@65W
Motherboard MSI MAG B650 Tomahawk WiFi
Memory Corsair DDR5 6000C30 2x48GB (Hynix M)@6000 30-36-36-76 1.36V
Video Card(s) PNY XLR8 RTX 4070 Ti SUPER 16G@200W
Storage Crucial T500 2TB + WD Blue 8TB
Case Lian Li LANCOOL 216
Power Supply MSI MPG A850G
Software Ubuntu 24.04 LTS + Windows 10 Home Build 19045
Benchmark Scores 17761 C23 Multi@65W
In my experience those "huge flash chip" WD SSDs that looked alike (SN570 etc.) tended to run very much cooler than most others (970 EVO Plus, T500 which is admittedly a PCIe 4.0 drive), that a laptop's flimsy heat spreader or a thermal padded and passively-cooled external enclosure (had one in both) are more than sufficient to cool them. Though I haven't verified those onboard thermometer sensors, other than by touch.
They are also more than fast enough, though the SN570 has a small SLC cache or some other limiting mechanism, and speed drops off fast if you copy large files. Interestingly, SN570 and SN770 seemed to have almost the same part numbers on their components, apparently the same board except for the colour, and the SN770 does not appear to have the same problem in benchmarks.
Still, a DRAM drive will be even faster.
7,265 (4.90/day)
São Paulo, Brazil
Display(s) 55-inch LG G3 OLED
Software Windows 10 Pro 22H2
I have to cheap out somewhere on my builds and I admittedly tend to do this with storage. I find that a high-quality Gen 3 NVMe drive with DRAM is all you'll ever need. While it's preferred to have it, DRAM or no DRAM has not been as much of a dealbreaker as it was in the past since modern DRAMless NVMe SSDs have HMB support.
Pretty much any SSD will do, you won't be able to tell them apart 99% of the time. Check W1zz's reviews and see something that fits on your budget well. There have been a few models that have been highly reviewed that you can find at a low price nowadays.
45 (0.19/day)
if you store fotos videos documents ... more than 128 GB , you should also have a HDD or SSD to manually copy them , just in case the NVME fails
or use RAID 1
5,223 (3.74/day)
Colorado, U.S.A.
I have had two solid state drives fail on me so far, and that was out of a rather small number.
7,265 (4.90/day)
São Paulo, Brazil
Only one really died on me, I've had them malfunction though, but all were fixed with a secure erase command. The remarkable for me is Seagate. It's my bad luck charm, a 100% failure rate. Every single Seagate HDD I have ever owned has died.
174 (0.33/day)
France
Mouse g502
In France the nv2 2tb is at 125 bucks rn.
