NVME SSD Temperature Questions
160 (0.04/day)
Australia
Processor Intel Core i5 14600K
Motherboard Asus Z790-AYW Wifi W
Cooling Thermalright Peerless Assassin 120 SE White + Noctua NT-H1
Memory Corsair Vengeance DDR5 6000MHZ CL 30-36-36-76
Video Card(s) Gigabyte RTX 4080 Super Windforce V2 16GB
Storage Crucial T500 NVMe 4.0 1TB
Display(s) Asus TUF VG27AQ1A
Case Lian Li Lancool 207 White
Audio Device(s) Onboard > Logitech Z623 / Denon DRA-295 > JM Lab Cobalt 810
Power Supply Cooler Master MWE V2 850W White
Mouse Ducky Feather + Corsair MM300
Keyboard Ducky One 2 TKL MX Silver
The second drive in that picture is my Crucial 1TB P1 NVME ssd, Drive Temp 5 has a high reading and i'm wondering if its safe.
I contacted Crucial and they said safe temp range is up to 70 celsius, which i think is for Drive Temp or Drive Temp 2. From research the lower temps are maybe the Controller and the higher temp is the Memory Chips, which are supposedly meant to run warm.
In the Crucial software it only shows temp readings for Drive Temp and Drive Temp 2, but no mention of the hotter running Drive Temp 5, so Crucial don't want an average Joe to see the third reading? I did aim a 120mm fan directly at the NVME and average temp came down about 10 degrees.
My temps were obtained whilst playing Doom 2016 which is installed on the NVME.
newtekie1
Semi-Retired Folder
28,473 (4.07/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
Not sure where you got this, but under use the controller is always hotter than the NAND chips.
I'd guess Drive Temp 5 is the on die sensor for the controller, or a sensor very close to the center of the controller. Which is why it is hotter, but I wouldn't worry about it at all. It's kind of like the on die sensors in AMD graphics cards. AMD didn't show those temps to users, until just recently, because the average user really doesn't need to see them and would likely freak out to see 100°C+ temps. But the reality is it is perfectly normal to see those temps directly in the GPU die. I'd assume that is why Crucial isn't showing Drive Temp 5 in their software as well. Without knowing what that sensor really is, or where it is located, the temp reading is pretty meaningless, so the average user shouldn't be worried about it.
924 (0.18/day)
System Name future xeon II
Processor DUAL SOCKET xeon e5 2686 v3 , 36c/72t, hacked all cores @3.5ghz, TDP limit hacked
Motherboard asrock rack ep2c612 ws
Cooling case fans,liquid corsair h100iv2 x2
Memory 96 gb ddr4 2133mhz gskill+corsair
Video Card(s) 2x 1080 sc acx3 SLI, @STOCK
Storage Hp ex950 2tb nvme+ adata xpg sx8200 pro 1tb nvme+ sata ssd's+ spinners
Display(s) philips 40" bdm4065uc 4k @60
Case silverstone temjin tj07-b
Audio Device(s) sb Z
Power Supply corsair hx1200i
Mouse corsair m95 16 buttons
Keyboard microsoft internet keyboard pro
Software windows 10 x64 1903 ,enterprise
Benchmark Scores fire strike ultra- 10k time spy- 15k cpu z- 400/15000
my both nvme drives are under a behemoth heatsink of the asus hyper m2 v2 card, and even though I manually switched the fan of the card to off, they run super cool, maybe too cool if that is a thing
newtekie1
Semi-Retired Folder
28,473 (4.07/day)
Indiana, USA
9,652 (3.46/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
I have the same M2 card thankfully the temp that it reports is not the temp of the controller but the chips. There is no way the controller would be at 35 C during heavy write cycles as that is what i saw when monitoring the drives.
22,991 (6.08/day)
I don't generally get nervous about temps, but hot storage... dunno. Going to need some more easing into that I think.
924 (0.18/day)
Yeah, the nvme's controller like to get toasty, as to the memory chips, they like it cooler, And if the manufacturer does not supply heatsinks, I would not worry about it, or just slap those 1$ ebay tape-on parts. my hdd's on the other hand, always were on the hot side but worked reliably many years despite this.
18,028 (2.44/day)
As I've posted elsewhere, NAND flash has better data retention if it's written to at higher temperatures, as long as it gets to cool down to a more reasonable temperature before power is cut.
This is based on data from Intel. If the data was written at 40 degrees C, with the SSD left to cool down to 30 degrees C, the data retention is 52 weeks. As you can see, the data retention period increases as the temperature during write increases. However, if you turn off your PC straight away, with the NAND at say 50 degrees, then you have a data retention of 9 weeks, if it was written at 50 degrees as well.
Source: https://www.anandtech.com/show/9248/the-truth-about-ssd-data-retention
22,991 (6.08/day)
Very interesting!
tabascosauz
8,207 (2.34/day)
Western Canada
System Name ab┃ob
Processor 7800X3D┃5800X3D
Storage 8TB of SSDs┃1TB SN550
Case Caselabs S3┃Lazer3D HT5
Other way around. M.2 heatsinks began popping up as a response to the need to keep NVMe controllers cool, as they can put out a surprising amount of heat, and prefer not to run hot, as with most electronics.
NAND, on the other hand, likes it warm when the computer is on. Not a ball-busting 100°C, but if run too cool, bad things start happening.
160 (0.04/day)
Australia
Thanks for all the replies.
Kirsebaer
4 (0.00/day)
Hi, I need to correct this incorrect information, in case someone reads this while searching for the same information as I. I don't think you've read the article you post, or at least not very well.
The final paragraph: "Remember that the figures presented here are for a drive that has already passed its endurance rating, so for new drives the data retention is considerably higher, typically over ten years for MLC NAND based SSDs. If you buy a drive today and stash it away, the drive itself will become totally obsolete quicker than it will lose its data
3,746 (1.72/day)
UK, Midlands
System Name Main PC
Processor 13700k
Cooling Noctua NH-D15S
Memory 32 Gig 3200CL14
Display(s) LG 27GL850
Case Fractal Define R4
Software Windows 10 21H2 LTSC
I read an article which I think the reviewers sourced their info from, the endurance temps are not just for when the power is out, but its for the entire time the data is been stored (even when powered up) as well as when its read so in other words lets say e.g. your NAND is been written to for 10 seconds, but then the next 40 seconds the drive is idle, and then the next 10 seconds after that the data is been read.
For optimal conditions you would want high temperatures for the first 10 seconds, but then low for the next 50, so in short cooler temps are better, unless for some reason your drive is mostly doing writes when powered up which would be highly unusual for a consumer workload.
My 970 EVO is about to be RMA'd and the data it cannot read is data that was put on there before I started cooling it.
The data became unreadable in the space of about 12.5 months. It was written early in the drive's life and never rewritten after.
