NZXT H630 Simple Build
JackBone
2 (0.00/day)
Specs:
PC SPEC:
CPU: AMD FX 8320
MOBO: FX 990 GIGABYTE UD3
RAM: VENGEANCE BLACK 16 GB
GPU: R9 290X CF
HD/SSD: 1 TB/120 GB
KEYBOARD: AIVIA OSMIUM GIGABYTE
MOUSE: AIVIA M8600 GIGABYTE
WC SPEC:
WB CPU EK SUPREMACY AMD
WB GPU EK FCR9 290X x2
EK RES 250 X3
DUAL PUMP LAING D5
360 RAD x2
MONSOON CHAINGUN FITTING
Mods:
PAINT (BLUE):
-TOP & FRONT PANEL
-RADIATOR
-FANS
CUTTING & DRILLING:
-PSU FULL COVER
-TOP & SIDE PANEL COVER WITH ACRYLIC
-SIDE ACRYLIC LED COVER
-BACK COVER ACRYLIC
*MOST ACRYLIC COVER WITH CARBON STICKER
Hi, Fellow Modders.. i want introduce my first build,
NZXT H630 Simple Build.
the goal: simple, shinny and clean lookin build
please rate, critics and comment my build, so i can be better in my next build.. thanks!!
9,871 (1.88/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
looks nice and clean but why you cover the rear fan?
your temp could better if you use the rear fan and you can cover it with mesh to make it clean
JackBone
2 (0.00/day)
@micropage7 thanks for vote and comment... you are so correct.. i test ed it yesterday and find the temps higher than before i mod the case (idle before about 25-30 now it can reach 43), i will put rear fans and see how the temps goin...
