NZXT Kraken X-52 thermal paste.
Eastw00d
1 (0.00/day)
Hello,
I am about to build my new rig with the Kraken X-52 as my CPU cooler.
My question is simple, is it true its better to replace the thermal paste that comes pre-applied with the unit ?
Thank you
340 (0.11/day)
Processor 8700k OC @ 5GHz (1.35 V)
Motherboard ASUS Prime Z390-A
Cooling Corsair H100i v2
Memory 16GB DDR4 OC @ 3000MHz
Video Card(s) EVGA RTX 2070 XC Ultra
Storage 4 x 250GB PNY SSD & WD BLACK 1TB HDD
Display(s) Samsung UHD 4K / BenQ RL2455HM
Case NZXT H500i
Power Supply Corsair 750W
Pre-Applied pastes tend to be good recently, but I always quickly clean it with isopropyl alcohol and reapply with MX-4 or Kryonaut.
Its a quick practice and guarantees good paste.
9,781 (2.22/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
It's a practice of preference,you don't need to unless you want to
2,047 (0.37/day)
Republic of Texas
Processor R9 5950x
Motherboard Asus x570 Crosshair VIII Formula
Cooling EK 360mm AIO D-RGB
Memory G.Skill Trident Z Neo 2x16gb (CL16@3800MHz)
Video Card(s) PNY GeForce RTX 3090 24GB
Storage Samsung 970 EVO Plus 1TB NVMe | Intel 660p 2TB NVMe
Display(s) Acer Predator XB323QK 4K 144Hz
Case Corsair 5000D Airflow
Audio Device(s) Objective2 Amp/DAC | GoXLR | AKG K612PRO | Beyerdynamic DT880| Rode Pod Mic
Power Supply Corsair AX 850w
Mouse Razer DeathAdder Elite V2
Keyboard Corsair K95 Platinum RGB "Cherry MX Brown"
VR HMD Oculus Rift
Software Window 11 Pro
I didnt replace mine and its doing a good job but i do plan to replace it when i move setup into a new case (eventually)
372 (0.06/day)
Where the beer is good
System Name Karl Arsch v. u. z. Abgewischt
Processor i5 3770K @5GHz delided
Motherboard ASRock Z77 Professional
Cooling Arctic Liquid Freezer 240
Memory 4x 4GB 1866 MHz DDR3
Video Card(s) GTX 970
Storage Samsung 830 - 512GB; 2x 2TB WD Blue
Display(s) Samsung T240 1920x1200
Case Bitfenix Shinobie XL
Power Supply Cougar G600
Mouse Logitech G500
Keyboard CMStorm Ultimate QuickFire (CherryMX Brown)
Software Win7 Pro 64bit
It's always good to have a bit of aftermarket thermal paste laying around if you build your own PC. Sometimes you just screw up or you might need to reseat the cooler (false orientation, pump noise ...).
sneekypeet
not-so supermod
29,549 (4.35/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
Most of the pre-applied paste is MX2 or a knockoff brand of it with the same transfer properties. Inspect it, if it is free of debris in the paste, use it. That's my 2 cents.
41,922 (6.61/day)
Thermalpads used on hsf are a mixedbag, at least when you have a spare tube you know what you are putting on.
peche
Thermaltake fanboy
6,709 (1.84/day)
San Jose, Costa Rica
System Name Athenna
Keyboard Tt eSports KNUCKER
Software windows 10x64Pro
i like to re-paste, never use stoc paste....
