O11 Mini Air or O11 Mini or O11 Evo - PSU Chamber depth?
53 (0.01/day)
System Name Nebula
Processor Ryzen 7 3700X
Motherboard Gigabyte x570 Aorus Elite Wifi
Cooling Custom Cooling Loop - Corsair XR7 54mm Rad + Byskski 38mm Rad + Bykski Pump
Memory Adata XPG D60G 4x8 32GB 3600@C17 Ram
Video Card(s) Asus Strix 3080 10G
Storage Adata XPG S40G 1TB, Crucial MX500 1TB, Crucial MX500 500GB , Seagate Barracuda 2TB
Display(s) Acer XV272U + DellU2414H
Case PC O11 Dynamic White
Audio Device(s) Altec Lansing 2.1 300w
Power Supply Phanteks Revolt Pro 850W
Mouse Cooler Master MM720
Keyboard Dell
Software Win 10 x64
Hey Guys!!,
I'm planning to build a PC for my beloved, i already have some hardware with me.
I'm leaning towards buying Lian Li Brand for cases, since i have been using PC o11 Dynamic for 2 years now.
I aleady have these hardware:
1. Deecool Castle 360EX AIO
2. Antec Earth Watts Gold 750Watts PSU
AIO that i can fit and it has radiator length of 402mm so o11 air is bit out of spec. :/ .
So o11 mini is adequate option bit it did not support ATX PSUs.
My Query is regarding PSU fitment in Lian li o11 Mini [Normal Version] Link with Antec Earth Watts Gold 750Watts Link
I know o11 mini fits SFX and SFX-L form factor, and Antec Earth Watts Gold 750Watts has Semi ATX type dimensions 150mm[L] X 140mm[W] X 86mm[H],
Length has no issue since o11 mini supports upto 165mm, and this has 150mm Length
So right question is show much depth did lian li o11 mini has for psu mounting in the second chamber? Can it fit 86mm depth PSU ?
If some one has it please let me know.
Secondly, o11 Evo is quite expensive considering it's quite new, so it's kind'a hard to justify.
Help me with buying decisions, Please suggest.
Regards,
Jayant
2,999 (2.57/day)
Motherboard Apple proprietary
Cooling Apple proprietary
Display(s) LG 27UL850W (4K@60Hz IPS)
Case Apple proprietary
Mouse Apple Magic Trackpad 2
Software macOS Sonoma 14.5 (with latest patches)
Your post is confusing. You mention the Antec is a "semi-ATX" dimensioned unit with a 86mm[H] and then go ask if the case will fit a 86mm depth PSU. Even more bizarre is that this isn't a "semi-ATX" PSU.
This is a standard ATX PS/2 power supply unit:
I have the O11D Mini with a Silverstone SX800 SFX-L PSU
The PSU dimensions are: 125 mm (W) x 63.5 mm (H) x 130 mm (D). The dimensions of a standard SFX unit 125 mm (W) x 63.5 mm (H) x 100 mm (D). It's the extra depth (130mm) my SFX-L PSU that makes it a "long" one. The standard SFX units are constrained to a 90mm fan. It's the SFX-L unit's extra depth that lets it accommodate a larger fan.
There's no extra room for a taller PSU. This case will only accommodate SFX and SFX-L power supply units.
108 (0.05/day)
Processor Intel® Core™ i9-13900K Processor
Motherboard ASUS ProArt Z790-CREATOR WIFI
Cooling EKWB EK-AIO 360 D-RGB
Memory Corsair VENGEANCE® RGB 32GB (2x16GB) DDR5 DRAM 6600MHz C32 Memory Kit — Black
Video Card(s) EVGA GeForce GTX 1070 FTW GAMING
Storage Samsung 1TB 990 PRO
Display(s) ASUS ROG Swift PG279Q x2
Case Lian Li O11 Dynamic EVO
Audio Device(s) Corsair VOID RGB Wireless Premium Gaming Headset
Power Supply Corsair RMi Series RM850i High-Performance ATX Power Supply
Mouse Corsair SCIMITAR RGB Optical MOBA/MMO Gaming Mouse
Keyboard Corsair STRAFE RGB Mechanical Gaming Keyboard — CHERRY® MX Silent
Software Microsoft Windows 11 PRO
Lian Li O11 Mini Case DOESN'T support your PSU. SFX/SFX-L PSU are thinner than ATX PSUs, so you can't fit your ATX PSU inside the case.
If you want to use your PSU, you MUST buy Lian Li O11 Mini Air case. With Air, Lian Li changed PSU support from SFX/SFX-L to ATX PSU.
You can see the difference between SFX and ATX PSU in the picture below.
87 (0.09/day)
System Name Sys:1 Streacom BC1 Mini v2 - Sys:2 SFF FormD T1 v1.1
Processor i5-13600K Delidded - i7-13700KF
Motherboard Msi Mag B760m Mortar Max DDR4 Wifi(mATX) - Msi MPG z790i Edge (mITX)
Cooling 13600K Delidded (EK Velocity2 DD Kit) - 13700KF Aquanaut Basic LowProfile Pump\Block kombo
Memory G.Skill Ripjaws V 3200C14 2x16GB DualRank - G.Skill 7600c36 2x16GB SingleRank
Video Card(s) Gigabyte RTX3080 Xtreme WaterForce WB (Rev 2.0) - EVGA Black RTX2080ti
Storage Samsung970 Evo Plus 500GB - Samsung 990 Pro 1TB
Display(s) Samsung Odyssey G7 240Hz 1440p VA Panel.
Case Streacom BC1 Mini v2(Silver) - FormD T1 v1.1 (White)
Audio Device(s) SteelSeries Arctis Pro Wireless With SteelSeries DAC
Power Supply SilverStone SX1000 SFX-L 80+Platinum - Asus Loki 1000w SFX-L 80+Platinum
Mouse Logitech G Pro Superlight
Keyboard -
O11Mini Air supports Normal ATX. O11Mini Dynamic does not.
7,012 (1.02/day)
USA
Cooling Noctua NH-D15S, 2xThermalRight TY-143, 4xNoctua NF-A12x25,3xNF-A12x15, 2xAquacomputer Splitty9Active
Storage 1x Samsung 970 Pro 512GB NVMe (OS), 2x Samsung 970 Evo Plus 2TB (data), ASUS BW-16D1HT (BluRay)
Case Lian Li O11 Air Mini
Mouse Zowie EC3-C
Software Win 10 LTSC 21H2
O11 Air Mini is actually a fairly large case, it is roughly on par with most mid towers. I have the O11 Air Mini.
O11 Dynamic Mini only takes small form factor power supplies. Anything larger will require customization. The O11 Dynamic Mini can run a larger radiator than the O11 Air Mini, however I think the 360 rad option only works with smaller motherboards (itx). You can replace the glass front with an aftermarket grill but it is expensive. I don't think that it is ideal for your hardware.
For what you are doing the O11 Dynamic Evo makes the most sense. For maximum compatibility, I'd do the O11 Dynamic Evo.
